Results 1 to 8 of 8
Thread: Updated E53 SP-Daten to Resolve SAS Coding Error
    Dec 2017
    Melbourne, Australia
    2005 BMW X5 E53
    Hi folks, I would be very grateful if someone could send me a link to SP-Daten files for 2005 E53 dated AFTER 1 Dec 2009.
    I believe I need files dated after 1 Dec 2009 in order to be able to code the VIN to a new Steering Angle Sensor (SAS) I have installed to replace the original one that failed. The new SAS is a different P/N to the original and was released on 1 Dec 2009. When trying to write the VIN using my current SP-Daten files (dated 21 Feb 2006) I get the following error message during the final "SG-Codeirn" job execution step using NCS Expert:
    "Error in CABD" "Look at CABI.ERR and ERROR.LOG
    COAPI-2060: coding faulty (general) C_LWS5, C_C_AUFTRAG: BUSY"
    Given that my current SP-Daten work ok with the original SAS, my assumption is that the new SAS must need new SP-Daten files. If someone has other thoughts on a resolution I am all ears!
    Thanks very much.
    Cheers, Grant
    2005 BMW X5 E53
    INPA 5.0.2
    EDIABAS 6.4.3\
    SP-DATEN 21/2/2006
    NCSEXPERT 3.1.0
    Dec 2017
    2005 BMW X5 E53
    Anyone able to help me here? Pointers as to where/how I might be able to get the updated files at least?
    Jul 2004
    Houston, TX
    36 Cylinders
    I don't think it's necessarily a daten error. There haven't been to many E53 updates in the last few years.
    Did you check the error.log file as it asked? It will give you more info. Located in C:\NCSEXPER\BIN
    Seeing that you may have 2006 daten, maybe it would help, but it isn't guaranteed.
    -Abel
    - 2000 Z3: Many Mods.
    - 1999 S52 Estoril M Coupe
    - 2016 Mini Cooper S
    Dec 2017
    2005 BMW X5 E53
    Thanks so much for the updated files Abel! I've downloaded them and will try them in the morning ... coming on midnight here in Oz.
    I'm a complete noob at this stuff but given I have spent a gazillion hours trying everything else I thought I had better try the updated SP-Daten to eliminate that as the issue. The error log (screenshot attached) didn't provide any clues to me but if it does to you please let me know what you think.
    Thanks again. You are a legend!
    Jun 2018
    Gatineau
    BMW X5 2E53
    I am experiencing the same issue ( DSC Module that failed and I replaced it with a new one. )
    I am Using NCS Dummy and the software is looking for the daten file
    Dec 2017
    2005 BMW X5 E53
    A quick update to close out my original post. It turns out that the errors were not due to outdated Daten files. With some minor changes in the procedure I was following to be consistent with that described at http://blog.obdii365.com/2016/04/28/...-angle-sensor/ and ensuring that I had the Battery Charger connected during the procedure, the errors disappeared and I was able to successful update the SAS with the VIN. I was then able to calibrate/initialise the SAS using INPA as per the many existing procedures that describe how to do this.
    Appreciate the help of those who responded.
    Cheers, Grant
    2005 BMW X5 E53
    INPA 5.0.2
    EDIABAS 6.4.3\
    SP-DATEN 21/2/2006
    NCSEXPERT 3.1.0
    Sep 2019
    mexico city
    bmw x5 e53
    Hello, I hope you are well, I have been investigating little by little about the update that can be done to the E53, I currently have one and I would like to be able to update the modules, would you help me get the DATEN to update? ... Best regards.
    Nov 2021
    Ottawa
    2020 M5 Comp (+ others!)
    Quote Originally Posted by Ramst3r View Post
    Hi @Ramst3r, I know this is an old post, but do you have those Daten updates still?
    Thanks!!
  1. advise how to resolve inpa reading error
    By alvinpalone in forum 2006 - 2012 (E90, E91, E92, E93)
    Last Post: 07-15-2017, 07:00 AM
  2. Code 2882/2883 how to resolve
    By trapi100 in forum 1999 - 2006 (E46)
    Last Post: 04-27-2015, 03:35 PM
  3. Need immediate help. Auto to manual SA codes
    By MalibuMafiaV in forum General BMW and Automotive Discussion sponsored by Intercity Lines
    Last Post: 03-17-2012, 07:55 PM
  4. Update NCSExpert 3.1 with sp-daten from ISTAv40?
    By einhirsch in forum Diagnostic Software
    Last Post: 02-21-2011, 07:11 AM
  5. Dummies guide to upgrading SP-daten files
    By noxid in forum Diagnostic Software
    Last Post: 02-20-2011, 03:06 PM
