BAVToys
Results 1 to 6 of 6
Thread: Headlight Indicator Problems???
    Apr 2018
    Dallas, TX
    2009 BMW 135i
    Just picked up a black beauty over the weekend (2009 135i) and inherited a driverís side front blinker/indicator problem.
    I switched out the bulb for a new one (fail #1) then I traded the left bulb and sleeve (?) for the right one.
    The driverís side works on the passenger side and the previously working passenger side bulb and sleeve did NOT work on the driverís side (fail #2).
    So Iíve narrowed it down to the driverís side headlight housing... maybe?
    Iím hoping I donít have to replace the entire headlight housing - though Iíve heard you can get a headlight casing and transfer the working parts over...?
    Anyone have any idea whatís broken/out of alignment?
    Thank you for your help!
    Jan 2016
    Ca
    2001 525it
    Your on the right track look inside the housing of the headlight and see if there are burnt contact marks where the socket makes its contacts if is burnt is part of the headlight
    Apr 2018
    Dallas, TX
    2009 BMW 135i
    Tyank you! Iíll work on that next!
    May 2018
    California
    2017 BMW 5 Series
    I have a situation where I'm doing wiring for the dashboard of a vehicle. For whatever reason, the turn signal/headlight switch on this vehicle outputs a 6 volt signal on the high beam wire when the low beam is on and a 12 volt signal when the high beam is on. The headlights work as they're supposed to, but the high beam indicator led is activated when the low beam is on since 6 volts is enough to activate it. Does anyone have a simple solution to make the indicator only turn on ShowBox Kodi Lucky Patcher when there is a 12 volt signal and not when it's a 6 volt signal?
    May 2018
    CALGARY
    Bmw F11
    Hello, Please Give Me advice How To Change it? or repair?
    Please See Images this Link
    Sep 2018
    WOODBINE,MD,US
    BMW 320d
    Solution
    Quote Originally Posted by gabrielallred View Post
    I think your problem is about the wiring. I think the wiring might have been damaged over the years.BobbyMovie Try checking all the wiring first before replacing the parts. See if there is any loose ends , if the current is flowing properly or not. Blokada
  1. Strange headlight/indicator problem. Help appreciated.
    By Wreckanic in forum 1975 - 1983 (E21)
    Last Post: 06-24-2009, 05:29 PM
  2. Weird headlight wiring problem
    By mbanks21 in forum 1992 - 1999 M3 (E36)
    Last Post: 07-28-2005, 11:11 PM
  3. Indicator problem with automatic shifter panel. How to fix???
    By RenaissanceMan in forum 1999 - 2006 (E46)
    Last Post: 01-09-2005, 11:05 PM
  4. turn signal indicator problem
    By Johnnyvolvo in forum 1983 - 1991 (E30)
    Last Post: 10-09-2004, 10:30 AM
  5. indicator problems help
    By daz 585 in forum 1992 - 1999 M3 (E36)
    Last Post: 03-04-2004, 02:39 PM
