I see there are a million choices on Amazon or ebay, but not sure what spec to look for. I am sure there are junk and decent in that pile of choices.
TIA
1997 740iL; 5/96 build. Purchased 12/04. Off the road build project 2013 - 2021. back on road 3/2021. Became daily driver (only vehicle) 6/12/2021. Still not completed. Stay tuned as the adventure continues.
Depstech. I just got one and it works very well. It was on Amazon for $37 but went on sale for $30.
E38 6spd, 4.6is, VF Engineering Supercharged, Dinan HFM/TB, 3:64Quaife, VAC Motorsport underdrive pulleys, SuperSprint headers/mufflers, Smile factor.
01 740i, Imola Red, stock.
98 318ti, beater.
97 540i, yard art.
Thanks Fixr,
I did a bunch of reading since I knew nothing about these borescopes. Came up with a wish list of specs and just pulled the trigger on a, what sounds like a sweet Depstech unit, for $47.
Here is link: https://www.amazon.com/Depstech-Semi...ct_top?ie=UTF8
The specs that seemed to matter:
semi-rigid cable
15 feet long
8mm dia camera size max
6-8 LEDs that are adjustable
WiFi (this way don't have to have phone, tablet or PC connected to the scope)
HD - 1200P
30FPS
Focal Length 2 inches to 14 inches............this is huge because most scopes have a focal length of 1 -2 inches
battery life - this one has 1800mAh (lasts a few hours)
It will be here in a couple days.
I bought this Depstech borescope to look into the cylinder. Couldn’t see jack with the mirror on. Mirror off it seems fine. Amazon has a $199 one that will bend to look up at 180 degrees.
You bought the one like I bought?
I had an idea in my head instead of the mirror. Why not tie a fish line to the camera and once inserted into the cylinder pull on the fish line to turn the head to look up at the valves? would that work?
I have only played with mine in the living room so far. lol. but I really like the focal length of 1 to 14 inches.
Actually I bought the yellow one from amazon, probably the exact same thing. That string trick might work. I pushed it in and tried to bend it back around by pressing it on the piston to get a little better angle. Didn’t work and the mirror came loose in the housing. It’s a slick tool though, hope I find a use for it!
https://www.amazon.ca/gp/product/B07...?ie=UTF8&psc=1
I have that one, it's good =)
|| 1995 740i || M60B40 || DUDMD || ̶o̶r̶i̶e̶n̶t̶ ̶b̶l̶u̶e̶ Mercedes Brilliant Blue Metallic || Style 168 Wheels 1" Spacers ||
