For sale is Brembo 6-Piston 355mm Front Big Brake Kit for the E46.
Originally, it was a E46 330 BBK, but I bought the caliper brackets for the M3 kingpin when I completed my S54 swap. Kit ran just fine between the 330 and the M3 master brake cylinder. This sale includes both the caliper mounting brackets. The 330 bracket did get milled down in order to increase the tolerance between the wheel barrel and the caliper. The M3 bracket is unmodified and original.
The reason I am selling the kit is because the car has turned into primarily a track car, so I bought the N15Designs Big Brake Kit to better fit the primary usage of the car.
The negatives of this kit is the caliper surface facing the wheel barrel is scraped up from the tight gap between the caliper and the wheel barrel with my first wheel set. The positive is the surface visible behind the wheel spoke is in pretty good condition. The piston seals are in good condition as you can still see the letter printing on the seals.
I have 79 photos, so I uploaded them up into my Flickr account to keep this post from being picture heavy. Links are posted below to the albums.
Picture of the BBK Caliper and Hardware =
https://flic.kr/s/aHskvCtDLk
The brake rotors are Brembo Type III and have ~75% of rotor life.
- New Thickness = 32mm. Minimum Thickness = 30mm.
- Measurement Thickness of Left Rotor = 31.56mm
- Measurement Thickness of Right Rotor = 31.53mm
This sale includes the following brake pads:
1) Hawk High Performance Street 5.0 (USED)
https://flic.kr/s/aHsm9ndqDL
- New Pad Thickness = 16.764mm
- Pad 1 Thickness = 16.13mm
- Pad 2 Thickness = 15.97mm
- Pad 3 Thickness = 16.15mm
- Pad 4 Thickness = 16.12mm
- Largest Pad Metal Backing = 5.9mm
- Pad Life Remaining = ~92%
2) Hawk High Performance Street 5.0 (NEW)
https://flic.kr/s/aHsmfpFBo8
- Pad 1 Thickness = 15.95mm (I feel like I got ripped off on this one after this measurement. Lol.)
- Pad 2 Thickness = 16.78mm
- Pad 3 Thickness = 16.65mm
- Pad 4 Thickness = 16.62mm
- Life Remaining = 100%
3) Hawk DTC-60 (USED)
https://flic.kr/s/aHskyJByuy
- Pad 1 Thickness = 12.79mm
- Pad 2 Thickness = 12.35mm
- Pad 3 Thickness = 13.06mm
- Pad 4 Thickness = 12.21mm
- Largest Pad Metal Backing = 5.8mm
- Life Remaining = ~58%
4) Race Technologies/Brembo RE10 (USED)
https://flic.kr/s/aHsmgZGZoQ
- New Pad Thickness = 17.00mm
- Pad 1 Thickness = 15.11mm
- Pad 2 Thickness = 14.86mm
- Pad 3 Thickness = 15.05mm
- Pad 4 Thickness = 14.86mm
- Largest Pad Metal Backing = 5.7mm
- Life Remaining = ~81%
5) Brembo FM1000 (USED)
https://flic.kr/s/aHsmdobVV9
- Pad 1 Thickness = 9.37mm
- Pad 2 Thickness = 10.05mm
- Pad 3 Thickness = 9.31mm
- Pad 4 Thickness = (Missing, Sorry)
- Life Remaining = ~32%
Price: $2100 SHIPPED within continental 48 states and PayPal fee included. Zelle is also accepted.
Left Caliper
Right Caliper
Brake Rotors
Hardware (M3 Caliper Bracket Pictured)
Hawk DTC-60 (USED)
