VRSF E92 BMW M3 Stainless Steel Bypass Track Pipes
For your 2008 - 2013 BMW M3 with the S65 Engine
We are proud to introduce our VRSF bypass pipes for the E90/E92 M3 which are the best bang for the buck mod available for your S65, with gains from 25hp & 25tq when tuned. By eliminating the restrictive 400 cell catalytic converters in the factory downpipes, backpressure is reduced significantly which results in an increase in power & a more aggressive exhaust note. Our bypass pipes are constructed from mandrel bent, 304 grade stainless steel and are designed to work with the OEM exhaust. Welding is not required for installation, just cut and bolt into place using supplied exhaust clamps.
Aftermarket software is required to prevent check engine light.
Features:
- Adds 20-25 HP to the wheels & 20-25 TQ to the wheels.
- Includes neccessary clamps for install.
- Hand made from mandrel bent, tig welded 2.5" 304 grade stainless steel.
- Smooth radius bends to decrease turbulence and increase flow.
- Fits RHD and LHD models with no modification neccessary.
- VRSF Lifetime Warranty against defects and fitment.
This item fits the following BMWs:
- 2008 - 2013 E90/E92 BMW M3
Note: Fits both Left Hand Drive & Right Hand Drive Models
