Results 1 to 4 of 4
Thread: MAP thermostat stuck open.
    Apr 2018
    Pennsylvania
    2013 x3
    Hello, I have a 2013 X3 F25 with the N20 engine. I have been getting the generic code P0128, thermostat stuck open. I recently purchased a Carley to check codes and parameters. I checked the codes and had a BMW code 1d2008 MAP thermostat stuck open. I replaced the thermostat and then had BMW do it a second time. I also replaced the only temp sensor I could find with a BMW part. The Carley shows the engine fan duty cycle at 99.61% all the time, even when its not running. It also shows the engine temp at 143C all the time. I have noticed over time the engine light will go out. When I turn the defrost on before putting the vehicle in drive the temp gauge will not move off 160F on the dash, pegged low, and the engine cooling fan will be at full speed when I pull over. If I stop the car and restart it the fan will shut down. The fan is so loud people comment on how I should get my car checked. If I do not put the defrost on the car warms up as normal, the code will go away after a few start and stops, and the engine fan will not act up. Any ideas? What happens on defrost that wouldn’t any other time? Is there another temp sensor? Thanks for any help.
    Dec 2019
    Canada
    X3 F25
    Hello,
    I’ve the same problem as you mentioned.
    Can you tell me what have you done to resolve it?
    Thank you
    Jan 2016
    Ca
    2001 525it
    Chec for faults for the electric water pump
    Feb 2009
    United States
    2002 Z-8; 1974 2002
    Was this ever resolved?
  1. Thermostat stuck open, Ideas?
    By Xz Dark Star zX in forum 1996 - 2003 (E39)
    Last Post: 06-23-2010, 03:35 PM
  2. 155k miles, thermostat stuck open and radiators hoses
    By meetom in forum 1991 - 1999 (E36)
    Last Post: 12-04-2009, 12:36 AM
  3. Is my thermostat stuck open?
    By trayson in forum 1991 - 1999 (E36)
    Last Post: 08-17-2007, 10:42 AM
  4. thermostat "stuck open"
    By funk53daba in forum 1991 - 1999 (E36)
    Last Post: 06-06-2007, 03:05 PM
  5. Thermostat stuck open?
    By Titanium98m3 in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 02-11-2003, 06:00 PM
