RM European Auto Parts
Page 4 of 7 FirstFirst 1234567 LastLast
Results 76 to 100 of 160
Thread: E46 M3 will not start please help
  1. #76
    Aug 2017
    Berlin CT
    2004 BMW M3 Laguna Seca
    Quote Originally Posted by Breeze1 View Post
    You should have a look at that man, just to be sure. Your issue sounds like a fuel pressure one, and in my mind it's pointing to the above or something that went wrong when you replaced the fuel pump...
    My mind is pointing that way too unfortunately. I did drive the car for a couple hundred miles after I replaced the pump which is sad if it's a dud now. Any way, if its the pump Ill be happy to return the OE for a OEM this time around.
  2. #77
    Aug 2017
    Berlin CT
    Sorry for the delay. Today I replaced the fuel pump and fuel pump relay along with ignition fuses and various others. Even replaced the battery as the old was flat. Runs much better however it still stalls out. Especially when at low idle or putting it into gear. It runs way better when MAF is plugged in for sure. When unplugged it acts the same but rougher idle.
    I did notice something new.. When shutting the car off Im noticing a "tic" sound by or under the brake booster. Sounds as if its sparking or shorting out. I only hear it when shutting the car off. Could that be the cause?
    I'm also thing possible bad injector(s)? Thoughts?
  3. #78
    Dec 2013
    Chicagoland area
    EXOTICS
    Clear codes,
    Reset adaptations.
    Scan for new codes after symptoms reappear.
  4. #79
    Northern VA
    97 M3/4/5; 04 M3 6M
    If disconnecting the MAF didn't change anything, I have to put a new test at the top of the list, before a smoke test. You need to connect a fuel pressure gauge to the schrader valve on the fuel rail, run the hose under the back of the hood, and clip the gauge under a wiper, or tape it to the windshield. Then drive the car until the symptoms manifest, and look at the gauge. It should say 51 psi; if it's half that or less, replace the fuel pump.
    This is ingenious. One for the memory bank.
  5. #80
    dworthy's Avatar
    Nov 2010
    Grafenwoehr, Germany
    16 220i 05 325it 05 M3
    The tick by the brake booster will be a main relay unloading, so don't worry about that.
    Like noted above, any new codes?
    Darin
    Current:
    Past:
    79 525 euro Green/Green RIP
    M-Flight Member
  6. #81
    Aug 2017
    Berlin CT
    Cleared old codes. Currently no CEL no new codes. I do not want to chance it getting stuck on the side of the road but I can see if I can have it run for a little while to see if any new codes come up?
  7. #82
    Dec 2013
    Chicagoland area
    EXOTICS
    I would remove and clean out the IACV, as you seem to be stalling only at idle.
  8. #83
    Aug 2017
    Berlin CT
    Quote Originally Posted by MIKYZZ4 View Post
    I thought that could be the culprit but I did clean it thoroughly. I also cleaned the intake manifold as well.
    Could the timing have skipped or valves out of adjustment?
  9. #84
    Dec 2013
    Chicagoland area
    EXOTICS
    Could be,
    but doubt it, as I believe rough running conditions would be across all ranges, not just idle.
  10. #85
    Aug 2017
    Berlin CT
    Could be,
    Very true. Thats why this is so frustrating. As of now what I have done..
    IACV - Cleaned and free
    Intake manifold - Cleaned
    MAF - New (Bosch)
    Fuel Pump - New
    Fuel Pump Relay - New
    Ignition Fuses - New
    Smoke Tested - No leaks
    No current CEL or Codes
    If there is anything that you guys can think of to have have looked please let me know.
  11. #86
    Aug 2017
    Berlin CT
    P.S. Throttle body - Cleaned
  12. #87
    Dec 2013
    Chicagoland area
    EXOTICS
    You've been pretty thorough,
    so I'm going to suggest somethings that improve an engines overall running condition.
    Proper sparkplugs - BMW DCPR8EKP Spark Plug - NGK 7415,
    in good condition/gap- (set removed w/photo would be helpful).
    Locate and cleanup all engine grounds.
    Inspect battery cables and check all associated connections are clean&tight.
    Send out injectors for cleaning:http://www.rcfuelinjection.com/Store...ector-cleaning
    If cause still not found, maybe time to suspect/inspect DME.
    I'm stumped also, just suggesting some options that may improve idle conditions,
    hopefully others can improve on my suggestions.
  13. #88
    Northern VA
    97 M3/4/5; 04 M3 6M
    Quote Originally Posted by DugiHowser View Post
    ...Today I replaced the fuel pump and fuel pump relay along with ignition fuses and various others....
    Did you take note of how much fuel was in the tank when you had the pump out? I just went through the entire thread and, while the fact that it runs sometimes would seem to indicate sufficient fuel, I can tell you from recent experience that low fuel condition exhibits some of the characteristics you're reporting. So, regardless of what the gauge says, are you certain you have at least a couple gallons of fuel in the tank? If not, go and get some.
  14. #89
    Jul 2004
    Houston, TX
    36 Cylinders
    Has the car had any water damage to the DME, or water entry into DME box somehow?
    Having fixed a few BMWs with dme issues from water entry lately, I am currently fixated on that. I do have an extra MSS54HP that I can send you if needed, I can do the ews delete if you need.
    -Abel
    - 2000 Z3: Many Mods.
    - 1999 S52 Estoril M Coupe
    - 2016 Mini Cooper S
  15. #90
    Aug 2017
    Berlin CT
    I hear ya and much appreciated.
    New Battery (replaced yesterday) but I will double check the connections.
    New spark plugs NGK Pre-gapped (replaced less than 200 miles ago).
    I will check the grounds.
    Update: I reset adaption and started it up. Did NOT stall out! However it did have an uneven idle. I did pull it out of the garage keeping low RPM and it held. Forward and reverse it held until it stalled out once. Backed it back into the garage without issue. Rev'd it high a couple times and it held. Im not sure if that means anything but its as if it improved little.
    Im going to pick some fuel stabilizer / injector cleaner hoping it will help with the idling. A quick question; would a faulty injector throw a code or CEL?
    Quote Originally Posted by HighandFast View Post
    3/4 of a tank full. If the gauge is wrong I can confirm fuel in the tank. Enough to submerge the pump entirely upon install.
  16. #91
    Aug 2017
    Berlin CT
    I hate to sound like a noob but by DME do you mean ECU?
    The car is not a flood car so I will have to say no. It is a vert and there was a little bit of water in the cab due to the windows not lining up and allowing water in. Could that be an issue?
  17. #92
    Jul 2004
    Houston, TX
    36 Cylinders
    Yes, I mean engine ECU. I hate jumping to blaming the ECU (they don't just fail, unless some event happened), but it seems you've thoroughly tested so much.
    -Abel
  18. #93
    Jun 2002
    Aberdeen, NC (yes, again)
    E39M5, E500 4WD
    Hang On, Dugi.....
    Sure, you put a new fuel pump in it....but you still haven't monitored the fuel pressure, with symptom manifesting. I'm not sure that you've had a professional smoke test, either? You haven't watched live data for the MAF, long term fuel trim, and other parameters.
    And how old is the gas?
    And .....water, oh crap. Yeah, water's never good. IS THE DME BOX DRY ??? You need to inspect this carefully, and unplug the computer(s), examine and clean the electrical plugs, both sides, with electrical contact cleaner.
    Yes, DME = Digital Motor Electronics = ECU = Engine Control Unit. In BMWs, this is a DME..
    I believe you might be best served by allowing a BMW specialist pro to lay hands on your car for an hour or two. As much effort as you've put into fixing it, I'm not convinced that definitive diagnostics have been completed yet.
    Chris Powell
    BMWCCA 274412
  19. #94
    Mar 2003
    St. Joseph, Mo.
    95 m3+, 03 ZHP, Mk4 Tdi
    Hang On, Dugi.....
    this, absolutely. was thinking many of the same things myself...
  20. #95
    Aug 2017
    Berlin CT
    Hang On, Dugi.....
    -Last I smoke tested it, I found a leak coming from the throttle body boot which since has been fixed and smoke tested again with no noticeable leaks.
    -Water did get into the cab yes but it was not flooded. Engine compartment dry. DME box dry.
    -I will try to connect to the fuel line to read fuel pressure.
    I do not disagree with you. I am not a professional however I feel as though I'm making some progress as its running not stalling out like it was prior. Anyway your right, at this point might as well spend the money and give it to a professional..
    Hang On, Dugi.....
    Fuel is about 5 months old however, the is right about the time the issues started.
  21. #96
    Jul 2013
    Casablanca, Morocco
    2001 e46 323i
    From the updates you posted, you definitely seem to be getting closer!
    My 2 cents:
    - dump the old fuel and replace it with a fresh one*
    - start the car and let some of the new fuel go through the system to get rid of whatever is remaining from the old one
    - change the fuel filter (which might already have been clogged by the fuel, if it is at fault)
    - if the symptoms persist even slightly, send your injectors for cleaning, as advised by bmwdirtracer
    - if none of that works, write down all the parts you have changed and all the steps you have already taken and take the car to a pro (the list will allow him to narrow things down and not waste time on stuff already done)
    * I would have advised to add some injectors cleaning additive to help, had I not recently blown the engine of my car literally 10 miles after putting one in my fuel tank Maybe it was at fault, maybe not, but I have to admit that I made 2 mistakes: confusing between STP and some cheapo lookalike brand AND only putting only 3 gallons of gasoline with it, instead of a full tank.
  22. #97
    Aug 2017
    Berlin CT
    My 2 cents:
    Ok I will get on that. I will dump the old fuel for new. FYI: Fuel filter changed 500 miles ago and I did use fuel additive last fill up. Reason for additive is that I suspected to have some water in my tank so I used HEET fuel treatment. Recently I put in another bottle of fuel treatment this time around I used Techtron by Chevron (after reading reviews it was highly recommended over it's competitors). Regardless I will flush out the old fuel with new and start there. If nothing changes I will get the injectors cleaned next.
    And if all that doesn't do the trick I will bring it to the shop.
  23. #98
    Jul 2013
    Casablanca, Morocco
    2001 e46 323i
    If you hadn't changed the fuel before changing the filter it might have clogged the new one as well, in case it was contaminated with dirt... Since you already put 2 additives I think it would be a waste (maybe even harmful) to put a third one. At this point fuel change + filter a few miles later, and then injectors.
    Edit: you could also reset the DME right after performing the above (before starting the car after you've changed the filter). I'm not sure if that would help, but as far as I know it couldn't hurt either that it "unlearns" whatever error codes were thrown at it, to start from a clean slate. The procedure is easy: disconnect the battery for an hour or so...there is a quicker way of doing it (joining the "+" and "-" cables for a few secs, after disconnecting the battery), but as your car is an SMG and I have never owned one, I would rather not take the chance. The more electronics the more careful you ought to be...
  24. #99
    Dec 2013
    Chicagoland area
    EXOTICS
    Very important clue, don't see how I missed it, but Breeze1 caught it!
    With this new info, I agree with him-Remove and replace that fuel!
    Clear all codes - reset adaptations - bring engine up to temp.
    Since you have stalling issue,bring engine up to temp by starting and idling in your driveway,
    if it hasn't stalled - attempt a short trip around the block, if still no stall - a little further.
    Post back with results.
  25. #100
    Jul 2004
    Houston, TX
    36 Cylinders
    Disconnecting the battery and touching the two leads together simply resets your clock and trip odometer.
    All adaptations and codes are stored in non-volatile memory, meaning that they will not erase unless a diag request was done to clear them.
    -Abel
  1. E46 Will not start...please help!!!
    By ToedRaindrop in forum 1999 - 2006 (E46)
    Last Post: 06-27-2012, 11:43 AM
  2. 528i Will not start, please HELP!
    By gradyjoseph in forum 1996 - 2003 (E39)
    Last Post: 06-15-2009, 05:18 PM
  3. 95 E36 Will not start Please help!
    By clicked82 in forum 1991 - 1999 (E36)
    Last Post: 09-23-2008, 02:42 PM
  4. 1999 Z3 will not start, please help
    By jjessie1 in forum 1996 - 2002 Z3 (E36/7, E36/8)
    Last Post: 07-17-2007, 05:29 PM
  5. Car will not start, please help!!!
    By Jordanst2 in forum Car Audio & Electronics sponsored by Bavsound
    Last Post: 03-05-2006, 10:50 PM
