RM European Auto Parts
Page 1 of 7 1234567 LastLast
Results 1 to 25 of 160
Thread: E46 M3 will not start please help
    Aug 2017
    Berlin CT
    2004 BMW M3 Laguna Seca
    Hello all,
    I have been searching high and low for some help trouble shooting my M3. Recently the car the had trouble starting up to the point that it will not start at all. It cranks and turns over for a second only to shut off again. I recently replaced the fuel pump and MAF sensor yet the problem persists. I did do a scan on the car and codes are:
    P0301 - Misfire detected
    P0463 - Fuel Level Sensor A Circuit High
    P0113 - Intake air temp sensor 1 circuit high
    P0171 - System too lean bank 1
    P0175 - System too rich bank 1
    P1717 - Hydraulic unit switch-on period
    P1434 - Diagnostic module tank leakage malfunction
    P0174 - System too lean bank 2
    If anyone can share insight on what the issue can be I would greatly appreciate it. Thank you all in advance!
    dworthy's Avatar
    Nov 2010
    Grafenwoehr, Germany
    16 220i 05 325it 05 M3
    I can see a large vacuum leak, from the lean/rich codes, so you will need to get the intake smoke tested.
    Is this a SMG equipped car?
    Darin
    Current:
    Past:
    79 525 euro Green/Green RIP
    M-Flight Member
    Aug 2017
    Berlin CT
    Yes it is a SMG tranny. I was told to replace the intake air temp sensor as well as that could have something to do with it so I will do that asap.
    I did hear a hissing noise around the intake toward the manifold come to think of it. Ill take off the intake hopefully I can spot the leak without needing to tow it for a smoke test.
    Jul 2004
    Houston, TX
    36 Cylinders
    You need a better scanner. It looks like your SMG is not allowing the start.
    Unless it always cranks?
    SMG light/cog light on?
    -Abel
    - 2000 Z3: Many Mods.
    - 1999 S52 Estoril M Coupe
    - 2016 Mini Cooper S
    Jun 2002
    Aberdeen, NC (yes, again)
    E39M5, E500 4WD
    First, allow me to say that Abel (328Power04) fixed two incredibly dissimilar race-car issues, from 1500 miles away, this past weekend., allowing TWO instructor's cars to continue providing enjoyment, when they would have otherwise had to go limping home....or not start at all!
    All said, you need a fuel pressure test, a smoke test, disconnect the fuel pump fuse for several minutes of cranking, and read the codes via an actual BMW capable diag computer, not p-codes, which really suck.
    WildAssedGuess: The engine is flooded. Pull the fuel pump fuse, squirt a teaspoon of oil in each cylinder, and work the starter for a little while before plugging the fuse in again..
    Chris Powell
    BMWCCA 274412
    Jul 2004
    Houston, TX
    36 Cylinders
    Thank you! I can't take all the credit... I do have some wonderful contacts that were pitching ideas. Among them a BMW employee at BMW engineering, a genius programmer/disassembler/all around expert, and a very experienced large shop owner.
    The 1M was a difficult case. Strange spontaneous wiring/module failure WITH a bricked dme at the same time, caused by the former. It was pretty cool to get the car running remotely though.
    We all help each other, and are happy to.
    -Abel
    Jun 2002
    E39M5, E500 4WD
    Yeah, it's never good when someone (the 1M owner) tries programming with 12 volts....then decides everything's working too slowly, and unplugs the damned programmer in the middle of everything/
    PLUS a toasted FRM, and a CAS not providing a wake-up signal!
    Not quite sure exactly what went on there, but let's just say that the grateful instructor had a fun weekend, instead of a disaster, thanks to you, Abel.
    As for my own M5, and the other E39M5 I dealt with last week, I now know that ISTA and other diag computers see Fuel level sensor 1 and fuel level sensor 2 as REVERSED.....and I'll keep over half a tank in the car when tracking it!
    DugiHowser: hook up a good scan tool; P-codes just don't cut it.
    Chris Powell
    BMWCCA 274412
    Mar 2003
    St. Joseph, Mo.
    95 m3+, 03 ZHP, Mk4 Tdi
    umm, yeah, "industrial control" type systems - loosely that's what i would consider the computers in our vehicles - absolutely do not like having their programming interrupted. in my world, that would be written up as "fails to recover from interruption gracefully."
    Aug 2017
    Berlin CT
    NO SMG light on at all but you may be on to something! I started taking things apart and noticed that my SMG fluid reservoir was very low because it started to leak out of the cap from what I can tell. Is this a common problem with these reservoir caps? I topped off the fluid and had the pump prime a few times and it started up. Possible that its a safe switch for the car to not run when low on SMG fluid?
    I started taking things apart and noticed that my SMG fluid reservoir was very low because it started to leak out of the cap! Is this a common problem with these reservoir caps? I topped off the fluid and it started up. Possible that its a safe switch for the car to not run when low on SMG fluid?
    From reading up more I gathered that when you get Lean codes it usually pertains to VAC leak. I will continue to look for a leak and while I'm pulling things apart I'm going to clean the ICV and throttle body. Is there anything else that is pron to leak or fail that I should be looking into?
    At the moment I do not have access to a smoke tester but will tow the car to a shop to do it if I cannot find anything on my own.
    Agreed! My friend has proper software and will scan the car later today. Will update thank you!
    Jul 2004
    Houston, TX
    36 Cylinders
    SMG does have a failsafe preventing starting. It's because it needs to release the clutch and keep it in neutral in order to start.
    Use the scanner to see the engine codes, SMG codes (if any), and ews module codes.
    -Abel
    Aug 2017
    Berlin CT
    I definitely will thank you!
    Jun 2002
    E39M5, E500 4WD
    As I understand it, the starter cranks the engine for just a second, then quits. Is this correct? I think this would rule out the SMG, wouldn't it, Abel?
    Bad engine main ground connection at the passenger engine mount? Bad starter? Bad ignition switch?
    Chris Powell
    BMWCCA 274412
    Jul 2004
    Houston, TX
    36 Cylinders
    Correct, I had to read a few times, so then I edited my first comment to end in a question. If it cranks even a little bit, then it shouldn't be SMG related.
    -Abel
    Aug 2017
    Berlin CT
    It does crank and it did start. It struggled to keep idle almost choking out. I haven't got to cleaning the throttle body or the ICV valve yet but hope that will solve it.
    Dec 2013
    Chicagoland area
    EXOTICS
    We are still waiting on those BMW codes.
    Jun 2002
    E39M5, E500 4WD
    We are down to a basic fuel/air issue. You need to have the system smoke tested. If this doesn't show a large leak, after 7 minutes, you need to do a crankcase vacuum test, because you likely have an internal (CCV) issue.
    Try this, for me: unplug the MAF, then start the car. Did it start and continue running? (You might have to try twice).
    You need a bit of diagnostics, of the fuel/air mix. Smoke test, fuel pressure, crankcase vacuum.
    Chris Powell
    BMWCCA 274412
    Aug 2017
    Berlin CT
    Quote Originally Posted by MIKYZZ4 View Post
    My friend was never able to scan the car. I plan on ordering my own tool to get proper codes if I cannot find anything.
    I did unplug the MAF and it did start and ran however, the random shut offs and no starts still happened after a while. I since then replaced the MAF.
    Jun 2002
    E39M5, E500 4WD
    If disconnecting the MAF didn't change anything, I have to put a new test at the top of the list, before a smoke test. You need to connect a fuel pressure gauge to the schrader valve on the fuel rail, run the hose under the back of the hood, and clip the gauge under a wiper, or tape it to the windshield. Then drive the car until the symptoms manifest, and look at the gauge. It should say 51 psi; if it's half that or less, replace the fuel pump.
    Chris Powell
    BMWCCA 274412
    Aug 2017
    Berlin CT
    I did replace the fuel pump about 150 miles due to similar symptoms in the past. I also replaced the fuel filter. Perhaps the fuel sender is bad? I will try the pressure test when possible thank you Bmwdirtracer.
    Jun 2002
    E39M5, E500 4WD
    Ignore the fuel sender code for now, if you have over 1/2 tank. If you had a good scan tool, you could read fuel levels in each half of the tank....
    Now, looking back over this thread, I see that you have a code for "Intake Air Temp". You need to use a good scan tool to read what the computer is seeing as intake air temperature. If the sensor or wiring is open-circuited (unplugged,for instance), the computer will see IAT readings of ~negative 40 degrees F, which will absolutely cause pretty much all your issues.
    A quick look at the wiring diagrams shows that, on your car, IAT is measured by the MAF., rather than a separate sensor. Do not buy a MAF : get access to the live data with a good scan tool.
    Chris Powell
    BMWCCA 274412
    dworthy's Avatar
    Nov 2010
    I don't remember reading it, but was the MAF cleaned once already? If the IAT is fouled too, it was cause problems too.
    Darin
    Current:
    Past:
    M-Flight Member
    Aug 2017
    Berlin CT
    MAF is new.
    I will try to do a fuel pressure test this weekend. In the mean time can you point me to the Intake Air Temp sensor so I can verify?
    Mar 2003
    St. Joseph, Mo.
    a quick google search will reveal plenty of hits for the IAT sensor location on an e46 m3....
    Aug 2017
    Berlin CT
    Hate to sound like an idiot but every search is a dead end. Leads to a different BMW model. If anyone can post a link Ill be happy to take from there.
    Jun 2002
    E39M5, E500 4WD
    Please see my post #20. MAF delivers IAT info, no separate sensor.
    I have to ask, where did you buy your MAF? And who's the manufacturer?
    Chris Powell
    BMWCCA 274412
  1. E46 Will not start...please help!!!
    By ToedRaindrop in forum 1999 - 2006 (E46)
    Last Post: 06-27-2012, 11:43 AM
  2. 528i Will not start, please HELP!
    By gradyjoseph in forum 1996 - 2003 (E39)
    Last Post: 06-15-2009, 05:18 PM
  3. 95 E36 Will not start Please help!
    By clicked82 in forum 1991 - 1999 (E36)
    Last Post: 09-23-2008, 02:42 PM
  4. 1999 Z3 will not start, please help
    By jjessie1 in forum 1996 - 2002 Z3 (E36/7, E36/8)
    Last Post: 07-17-2007, 05:29 PM
  5. Car will not start, please help!!!
    By Jordanst2 in forum Car Audio & Electronics sponsored by Bavsound
    Last Post: 03-05-2006, 10:50 PM
