Page 9 of 12 FirstFirst 123456789101112 LastLast
Results 201 to 225 of 281
Thread: Big Power Manual Transmission (S6-53) Swap
  1. #201
    Nov 2002
    Westchester, NY
    Quote Originally Posted by m3mods View Post
    No that’s for a gs6-37bz which bolts on without an adapter plate and is rated for less torque.
    Thnx ill never have more than 320 hp
  2. #202
    Mar 2012
    Renton, Wa
    98 m3
    Quote Originally Posted by RickyN F355 View Post
    Both kits accomplish the same thing.
    One just has a more robust clutch and trans and probably costs less :p
    1989 535i - sold
    1999 M3 Tiag/Dove - sold
  3. #203
    Nov 2002
    Westchester, NY
    Quote Originally Posted by vollosso View Post
    But doesnt bolt up as easily?
  4. #204
    Mar 2012
    Renton, Wa
    98 m3
    Both kits will bolt up very easily I assume.
    1989 535i - sold
  5. #205
    Nov 2002
    Westchester, NY
    Well the cheaper price is certainly attractive
  6. #206
    Boston, MA
    E36 M3 Turbo
    I think I may be the only one running this kit so far, and its been great. I've got just about 900 miles on the clutch break-in and it being my first twin disc it took some getting used to but it's gotten smoother with mileage. I was able to swap in an e90 Xi rear driveshaft (front half) like Zack listed and it has been smooth up to 140+ a handful of times. Holding 18psi on my GT40r s52 somewhere in the 570-600whp range I would estimate.
    I did need to slightly modify the shift carrier a little bit to accept my UUC e36 short shift kit (I believe the updated shift carrier takes care of this), but other than that every nut & bolt was supplied and the fitment of the adapter plate was pretty spot on. There was a very slight whine of the starter on first start due to misalignment when I bolted it on. I loosened it and retightend and its been silent ever since.
    Overall this trans is buttery smooth. There has never been a harsh engagement or a sloppy shift so I'm not really sure why people have complained about this trans. I have yet to launch with it due to my fear of losing some rear end part so I will comment on that when I make it to the track. I do want to change my shifter setup though in the near future. Maybe a body mounted RTD or CAE.
    6th gear now cruises at a healthy 2900rpms @ 75mph - this is on a 245/40r18 and 3.23LSD. I can finally take the car on longer trips without going deaf, AND I can make passes without needing to downshift thanks to the s52 low end grunt.
    Last weekend I got to run a 2017 Hellcat Challenger bone stock 50-120 and took the W!!! It's awesome because 50mph is at about 3500-3600rpm in 3rd which puts me just before full boost (brake boosting) and lets me run thru the entire gear before shifting. Easier to fight off these stupid 2 pedal cars with big power lol
    97 Turbo 3.2L M3 - Cutring / ARP - RSI Top Mount - Gt4088r - ID1300 - Tial WG - 22RPD Tuned - 93 Octane - 3.5" Stainless
  7. #207
    Apr 2006
    Minnesota eh?
    86 325es
    Quote Originally Posted by SCapelo View Post
    Last weekend I got to run a 2017 Hellcat Charger bone stock 50-120 and took the W!!! It's awesome because 50mph puts me at about 3500-3600rpm which puts me just before full boost (brake boosting) and lets me run thru the entire gear before shifting. Easier to fight off these stupid 2 pedal cars with big power lol
    Thats sweet
  8. #208
    Apr 2015
    United States
    1995 BMW M3 Coupe
    I'm getting ready to do this swap to my car. When I search for the Guibo: 26117610061 it comes up as a rubber one. I thought that it was an aluminum Guibo?
  9. #209
    Mar 2012
    Renton, Wa
    98 m3
    Quote Originally Posted by CvilleBill View Post
    The aluminum one was superseded by the rubber one, So both part numbers now go rubber.
    Some people destroyed the aluminum one. Maybe a manufacturer error.. my car at 1000wtq doesn’t seem to be able to destroy it.
    1989 535i - sold
  10. #210
    NY
    skateboard
    Then it’s not making enough torque.
    ― George Orwell
  11. #211
    Apr 2015
    United States
    1995 BMW M3 Coupe
    Thanks for the fast response.
  12. #212
    Norristown PA
    mostly bmw
    How about fitment for an e46 m3? =)
    95 turbo 330ti. 01 maxpsi m3 e85. 01 m5. 01 m coupe. 03 AIM 996t e85. 06 x3 w/Meyers plow and winter daily. Prussian Motors is hiring!! prussianmotors.com/jobs
    Current e39t LS Turbo swap: https://www.bimmerforums.com/forum/s...LS-e39-Touring
  13. #213
    Mar 2012
    Renton, Wa
    98 m3
    Quote Originally Posted by bubela View Post
    It should all work. The trans brace may need to be tweaked and the shift carrier may not be perfect.
    If you’d like to be a tester we can work something out
    1989 535i - sold
  14. #214
    Norristown PA
    mostly bmw
    Hmm.. Currently sold out of the ZF GS6-53DZ trans, but might have to buy one to get this trans in one of my cars. Loving what I see here. I assume my current UUC twin disk (in front of my 420G) will not work with your ZF GS6-53DZ swap kit?
    I wasn't even thinking about this until yesterday when I ran into someone with an e36 drift car. He was telling me about it. To be honest.. I'm not in a huge hurry, but this could be a winter project.
  15. #215
    Mar 2012
    Renton, Wa
    98 m3
    Correct, it needs a custom clutch/flywheel package to make it work, it is included. 8.5” all billet twin-disk. ~30lbs total weight.
    Your choice of disks.
    1989 535i - sold
  16. #216
    Jun 2005
    New England
    F90 M5; E36 M3 Turbo
    The twin disk clutch and flywheel seem to me to weigh about 44 lbs, which is about what a stock 5 speed clutch and dual mass weigh. Edit— The weight is about 32.5 lbs on my scale versus about 38 lbs for my dual mass plus south bend ceramic clutch. So the twin disk is about 15% lighter.
  17. #217
    Mar 2012
    Renton, Wa
    98 m3
    Theres some variance depending on the disks. For example sprung would be heavier.
    I never weighed mine, I don’t own a scale with that capacity. In development the estimated weight was 32#. I think the shipping weight was 35# for mine boxed?
    Did you weigh yours? I’m curious now
    In the end, even if the weight was the same as oem the inertia will drop due to the smaller disks and pressure plate which results in the sportier feel.
    1989 535i - sold
  18. #218
    Apr 2015
    United States
    1995 BMW M3 Coupe
    I just weighed my unopened clutch package. I got the sprung 800lb clutch. It was exactly 35 lbs.
  19. #219
    Mar 2012
    Renton, Wa
    98 m3
    Thoughts on the hardware at this point?
    1989 535i - sold
  20. #220
    Apr 2015
    United States
    1995 BMW M3 Coupe
    It all looks great! I'm taking it to BPC in Raleigh tomorrow to get it installed. I'm excited because I really hate the clutch that is currently in my car. It currently has a grip force that has issues disengaging. I'm a little concerned about the ratios because i have a 2.73 rear end...but I think I'll be really happy with it. I'm used to a 5 speed. 1rst should be really awesome for a change. I need a different turbo.
    The front portion of the 328 shaft is really beefy.
  21. #221
    Apr 2015
    United States
    1995 BMW M3 Coupe
    I think getting rid of the DSS shaft will make the conversion worth while.
  22. #222
    Apr 2015
    United States
    1995 BMW M3 Coupe
    If any body needs one...?
  23. #223
    Philadelphia, PA
    2005 M3 & 2004 330i
    How much length does your bellhousing adapter add? The E46 330d did have a S6-53 variant and I imagine its shift linkage and mounting hardware could work
  24. #224
    Mar 2012
    Renton, Wa
    98 m3
    Quote Originally Posted by TerraPhantm View Post
    ~0.625”
    Terra, Here are the components: LINK
    The carrier for these ends up being pretty small and you have to lift the shifter up quite a bit to clear the guibo. The rear of the trans is pushed back almost to the shifter area.
    The selector rod we end up with is only 2.5-3" so I think it would not work. I would like to see the selector rod they are showing. Looks interesting.
    1989 535i - sold
  25. #225
    Philadelphia, PA
    2005 M3 & 2004 330i
    ~0.625”
    Hmm, well I don't know the tolerances on these things, but I imagine for E46 applications it'd still be easier to modify the 330d components than to design and manufacture all new stuff. Probably could notch the transmission brace a bit and shorten the shift carrier a little (and I guess go for a custom DSSR).
  1. The Official Auto-to-Manual Transmission Swap Thread
    By TheBestCow in forum 1991 - 1999 (E36)
    Last Post: 12-20-2023, 09:07 PM
  2. Manual Transmission/Rear Differential Fluid Swap
    By Johno in forum 1992 - 1999 M3 (E36)
    Last Post: 04-28-2018, 06:54 AM
  3. Replies: 30
    Last Post: 12-15-2016, 01:15 PM
  4. WTB: e30 manual transmission crossmember for swap
    By r4esh in forum BMW Parts Wanted
    Last Post: 01-06-2010, 10:52 AM
  5. Wanted: auto to manual transmission tranny swap parts
    By molszews in forum BMW Parts Wanted
    Last Post: 07-14-2005, 08:23 PM
