Page 6 of 12 FirstFirst 123456789101112 LastLast
Results 126 to 150 of 281
Thread: Big Power Manual Transmission (S6-53) Swap
  1. #126
    Mar 2012
    Renton, Wa
    98 m3
    So the powder coated was backed up a couple weeks. I pulled an audible and jumped to stainless on the brace and added a rib...
    Tell me what you guys think:
    1989 535i - sold
    1999 M3 Tiag/Dove - sold
  2. #127
    Apr 2006
    Minnesota eh?
    86 325es
    that's much better. With the rib on it you can also make it thinner. 3/16 would be plenty I think. I assume your getting that laser cut in 2 pieces then weld them together?
  3. #128
    Mar 2012
    Renton, Wa
    98 m3
    Yep exactly. Its hard to see but it’s plugged, and it’ll be stitched.
    Its out of 7 gauge so basically 3/16. I did some quick calculations and it’s way more than enough. Didn’t wanna jump into plate if I didn’t have to.
    The logo will be etched.
    All in all I’m happier with im the brace out of stainless.
    1989 535i - sold
  4. #129
    Apr 2006
    Minnesota eh?
    86 325es
    I love making stuff out of stainless. It welds like butter the cost is usually offset by not needing to paint or powdercoat. I make lots of stuff out of stainless.
    these seat brackets were like 50 bucks a piece to laser cut. The flanges are attached with a slot cut to form a hinge so I just had to bend them 90 degrees by hand and weld up the slot. Even easier if I had a brake to bend them.
    My shifter. I heated it with a torch till it turned colors.
    Sealed airbox for my 4 wheeler. My brother loves to make fun of me for this.
  5. #130
    Mar 2012
    Renton, Wa
    98 m3
    Here is the final group buy pricing including shipping to the continental 48.
    This pricing takes into account that these are somehow pre-orders. I will be testing everything before shipping these and I can assure everyone fitment and form will be perfect. The base kit will include everything you need to get the trans in the car minus a shifter, guibo, and driveshaft. The carrier option below is an option for those of you who like your various shift /short shift kits, it replicates oem style ball clip lock. This pricing will be available until first ship date.
    Estimated Early ship date: 5/14/18
    Transmission Swap Kit (as below): $2950
    • 6061 CNC Adapter Ring
    • 20Ga Stainless Laser Cut Dust shield
    • Laser cut, CNC Bent, Stainless Transmission brace
    • Twin-disk billet Clutch kit (Fiber compound 800Tq / Carbon 1000Tq setup)
    • Adapter ring bolt kit
    • Transmission bolt kit
    • Dowel sleeves
    • Stainless Dual Shear Selector rod (DSSR)
      • Selector rod bolt kit
    • Stainless Pivot Pin
    • Instructions on install with torque values
    Additional Items:
    • Billet Shift Carrier for OEM style shifters $195
    • Custom DSSR length $0
    If you are interested feel free to PM me or post here with the following:
    • Clutch disk combo (Fiber/Carbon)
    • Billet Carrier (Yes/No)
    • Special DSSR length (mm center to center)
    • CES Driveshaft? (Part Number from CES's Post: BMWSH2-CES_-_)
    1989 535i - sold
  6. #131
    bonita springs fl
    oloa 318ti
    awesome. I am not quite ready to buy this now. where will this be sold when this group buy is over?
    one lap of america s52/gt35r 318ti..500whp 533wtq 19psi via rk-tunes....
    follow me on instagram @whitecord1
  7. #132
    Mar 2012
    Renton, Wa
    98 m3
    You’ll be able to buy it through 22Rpd, rally road and maybe ces.
    1989 535i - sold
  8. #133
    Mar 2012
    Lansdale, Pa
    98 540 6, SC'ed, 16psi
    Well thought out kit! Fair price too considering clutch.
  9. #134
    Mar 2013
    Upstate NY
    M3
    Yep, I'll be buying one eventually, solid alternative to OEM trans.
  10. #135
    Jul 2011
    Dell Rapids, SD
    2-97 M3 sedan, 2015 STI
    Quote Originally Posted by vollosso View Post
    Any other clutch options for just stock setup?
    THE TIME DRAWS NEAR!
  11. #136
    Mar 2012
    Renton, Wa
    98 m3
    Quote Originally Posted by spenka View Post
    I can do a lower power setup a bit cheaper. I did a large run of flywheels to keep the cost down and went with a twin disk flywheel. To do another run would be cost prohibitive at this time.
    These will obviously work na, and since they are 8.5” and lighter they will be more fun to drive. Better lockup and better wear life versus a performance single. We went with a nice pressure and they will be very slippable.
    1989 535i - sold
  12. #137
    Jul 2011
    Dell Rapids, SD
    I'm currently doing a stock auto to manual and wanted to go with this transmission from now instead of redoing this again later. I have too much to do to this 328 before I'm seeing boost on it.
  13. #138
    Mar 2012
    Renton, Wa
    98 m3
    Yeah it’ll give you a nice segment of time to break it in :wink I did that on my first build with a twin.
    1989 535i - sold
  14. #139
    Louisville, KY
    turbo m3
    To SCapelo:
    eBay? Where?
  15. #140
    Boston, MA
    E36 M3 Turbo
    Quote Originally Posted by BadBoostedBmwM3 View Post
    To SCapelo:
    eBay? Where?
    Car-part.com is a good used parts listing that I use. EBay also has some options
    Sent from my SM-G930P using Tapatalk
    97 Turbo 3.2L M3 - Cutring / ARP - RSI Top Mount - Gt4088r - ID1300 - Tial WG - 22RPD Tuned - 93 Octane - 3.5" Stainless
  16. #141
    Mar 2012
    Renton, Wa
    98 m3
    I got mine off of car-part for 280$.
    1989 535i - sold
  17. #142
    NY
    skateboard
    I purchased 4 for 175 each locally
    ― George Orwell
  18. #143
    Mar 2012
    Renton, Wa
    98 m3
    Quote Originally Posted by GG///M3 View Post
    Smart man. How much was delivery to the outer frozen rock?
    1989 535i - sold
  19. #144
    Mar 2012
    Renton, Wa
    98 m3
    I went ahead and added these to the website to make it easier for you guys. Again these will be available at these prices until first ship date.
    Transmission Kit:
    http://www.22rpd.com/item.php?item=30
    Carrier:
    http://www.22rpd.com/item.php?item=31
    1989 535i - sold
  20. #145
    NY
    skateboard
    Korrekt
    ― George Orwell
  21. #146
    Jul 2011
    Dell Rapids, SD
    There is 1 on there for $212 here in CT.
  22. #147
    Mar 2012
    Renton, Wa
    98 m3
    Perfect
    1989 535i - sold
  23. #148
    Jul 2011
    Dell Rapids, SD
    Perfect
    Pmed you
  24. #149
    Feb 2008
    DETROIT
    E36 GOODNESSSS
    Finnally a solution to our problems !!
    Sent from my VS995 using Tapatalk
    i got these parts for sale
    front corner light for a 4 door E36 $20plus shipping
    headlight eyebrows $20 plud shpping
    M3 OEM radiator $100 plus shipping
    M52 cams with trays high miles $150 shipped
    M3 front calipers $150 plus shipping
    18x8 offsed 35, front 18x10 offset 40 rear bsa motorsports wheels $400 plus shipping
    obd2 valve covers $50 plus shipping
    intake manifolds $50 plus shipping
    estoril blue doors of a 96 M3 2door $200 plus shipping each
    rear glass $50 plus shipping
    rear trunk lid $150 plus shipping
    new 1/4 is 800 ft away ))
  25. #150
    Tampa, FL
    03' M5 & 98' M3
    We are looking at about a $4k transmission swap between one thing and the next, excluding labor of course. If it can support 1000wtq
  1. The Official Auto-to-Manual Transmission Swap Thread
    By TheBestCow in forum 1991 - 1999 (E36)
    Last Post: 12-20-2023, 09:07 PM
  2. Manual Transmission/Rear Differential Fluid Swap
    By Johno in forum 1992 - 1999 M3 (E36)
    Last Post: 04-28-2018, 06:54 AM
  3. Replies: 30
    Last Post: 12-15-2016, 01:15 PM
  4. WTB: e30 manual transmission crossmember for swap
    By r4esh in forum BMW Parts Wanted
    Last Post: 01-06-2010, 10:52 AM
  5. Wanted: auto to manual transmission tranny swap parts
    By molszews in forum BMW Parts Wanted
    Last Post: 07-14-2005, 08:23 PM
