I got this guy all mounted up last night. Fits perfect. No issues with the trans tunnel or anything. Just waiting on the clutch to try this guy out.
I took measurements (cmm) if the mounts and trans brace and then measurements of the shifter location.
I’ll machine little shift carriers for these setups also. Not included in the kit but available for those of you looking to keep oem shift lever selection.
Its almost exactly 53” flange to flange. So those of you looking to use a dss or similar you can check your shaft versus that. That measurement is from output flange face to driveshaft face, so if you want a guibo in there or an adapter that needs to be included.
1989 535i - sold
1999 M3 Tiag/Dove - sold
1989 535i - sold
The euro 6-speed DS is 53.82”. I measured my 420G to 210 diff to be 53.5 and had it shortened to that.. Maybe the CV could yaw up the difference in length
That would be awesome, only problem is guibo bolt patern difference, i'm sure there's a solution(time and money). I'd love to see a guibo tri-bolt adapter to standerd domestic u-joint 3" chromoly or what ever, same to 6 bolt cv and 4 bolt u-joint diffs. Not 100% sure on options for this.
I’ve got a DSS one piece so all I’d probably need is a new forward adapter.
And some shortening?
Recent developments include indirectly bringing DSS onboard. Complete driveline solutions will be available for this trans and 188/210mm rear ends. More information on this in a few days as we have some pricing and better info.
I set up the driveline to be about 0.25* high so once weight is on the mounts the driveline operating angle will be between 0.0-0.25*. Transmission brace will be out for quotes Monday.
Shift linkages are already quoted and prototypes are on the way.
Things are moving.
1989 535i - sold
I wrapped up all the parts and got them all out for quotes. Expecting to have everything here 5/14/18.
Parts quoted or in production:
-Selector Rod (DSSR)
-Adapter Ring
-Trans Brace
-Shifter carrier for oem style shift rods
-Clutch Kit
On some other good news the bmw e92 328Xi Driveshaft (26107573482). These are very common driveshafts found for 75-100$. You only need the front half, which you pair with your oem e36 rear half and everything is spot on. This reduces the entry threshold for everyone a bit I hope.
I will be using this shaft combo for the testing of this kit, DSS will be producing a 1 piece shaft for the kit also (Still waiting on pricing) for those of you who will be looking for it.
I'm hoping to have my clutch this week for testing.
1989 535i - sold
Moist
Sent from my SM-G930P using Tapatalk
97 Turbo 3.2L M3 - Cutring / ARP - RSI Top Mount - Gt4088r - ID1300 - Tial WG - 22RPD Tuned - 93 Octane - 3.5" Stainless
Cool, OEM driveshaft is great for people that just want a 6 speed (me).
For what it's worth - Just ordered up a used 6spd MT from an 08 335i w/ 85k for $350 and an 08 328xi AT rear driveshaft for $75. These are all readily available and inexpensive
I can't wait for this
I just had two people ask so I’ll clarify, the 5/14 date is the potential ship date for parts to you guys.
1989 535i - sold
Very exciting for e36 platform.
Now of only we can make this work on the V8s...
Sent from my G8141 using Tapatalk
1989 535i - sold
This is really awesome work! And we want to thank Zach for allowing us to include some additional Driveshaft options for your 355 trans swap kit.
We are on the list for one of his conversion kits to put in our project widebody e36, which we hope to have ready in the next couple months that should be putting down some big power. I myself have always been a manual trans guy at heart, and it pleases me greatly to have a BMW trans swap conversion option that can hold 1000+whp reliably to use. Can't wait to test it out!
We have been working with DSS to develop a shaft for our project widebody car with our 750 diff conversion that will handle the power, and work with the 335 trans swap Zach is making. We reached out to Zach since we thought it would be great to offer some DSS driveshaft options for those of you interested in a 1000hp driveshaft solution to work with this trans swap as well.
As Zach mentioned... options would be for either 4 or 6 bolt OEM E36 188mm diffs, or for the 750 6 bolt 210mm diff conversions in either chromoly or carbon fiber.
List pricing for the E36 335 Trans Swap Chromoly Shafts is $892.49 and Carbon Shafts is $1469.99
We can offer Group Buy Pricing under 12 shafts for 15% off. 12 shafts and over Group Buy Pricing will be 25% off.
Group Buy pricing for Chromoly Shafts at 15% off is $758.62
12 shafts and over at 25% off is $669.37
Group Buy pricing for Carbon Shafts at 15% off is $1249.50
12 shafts and over at 25% off is $1102.50
Shipping is $45.00 UPS ground
DSS 335 swap CES Shaft Options are as follows....
BMWSH2-CES3 E36 BMW with 335 Transmission to stock 6-Bolt Rear 3" Chromoly 1-Piece CV Driveshaft
BMWSH2-CES3-C E36 BMW with 335 Transmission to stock 6-Bolt Rear 2.75" Carbon 1-Piece CV Driveshaft
BMWSH2-CES4 E36 BMW with 335 Transmission and stock 4-bolt Differential 3" Chromoly 1-Piece CV Driveshaft
BMWSH2-CES4-C E36 BMW with 335 Transmission and stock 4-bolt Differential 2.75" Carbon 1-Piece CV Driveshaft
BMWSH2-CES5 E36 BMW with 335 Transmission and 7-series (6-bolt) Differential 3" Chromoly 1-Piece CV Driveshaft
BMWSH2-CES5-C E36 BMW with 335 Transmission and 7-series (6-bolt) Differential 2.75" Carbon 1-Piece CV
We would be happy to start a list and update it from our end, and have customers PM us so we do not clutter this thread, or However Zach would like to handle this part of the group buy.... These shafts are made to order and are not something that is on the shelf, so the quicker we can fulfill the group buy for these, the quicker we can place the order and get them going. Maybe a cut off date for the DSS group buy would be advisable so we do not delay placing the order for those that get on the list and are waiting.
The CES Motorsport Team
Hey John,
Appreciate, you taking up the driveshaft, and looking forward to seeing you trying to break this setup :wink
Just finished up a little dust shield to complete the kit:
Everyone, I will be releasing finalized pricing for everything tomorrow. I am considering starting a smaller group buy to kick things off.
As of now the kit will include the following:
- 6061 CNC Adapter Ring
- 20Ga Stainless Laser Cut Dust shield
- Laser cut, CNC Bent, Powder Coated Steel Transmission brace
- Clutch kit (in your selection of disks)
- Aluminum Flywheel
- TOB
- Necessary Hardware
- Adapter ring bolt kit
- Transmission bolt kit
- Dowel sleeves
- Stainless Dual Shear Selector rod (DSSR)
- Selector rod bolt kit
- Stainless Pivot Pin
- Instructions on install with torque values
Additional Items not included in the base kit that you may need:
- Shift Carrier for OEM style shifters
- You can alternately run a chassis mount shifter (CAE, IRP, RTD, AKG, Etc.)
- CES One Piece Driveshaft Options Listed above
The OEM Part numbers that will be used with these kits (Please check Linked REALOEM.COM with the interchange numbers)
Transmission: 23007571423
Driveshaft: 26107573482
Guibo: 26117610061
1989 535i - sold
Looking forward to this!
98 Fern Green M3/2 - Precision 6870/AR Designs Twin Scroll/RK/E85
2017 Toyota Tundra Crewmaxx - Family Whip
2011 Pierce 75' Quint - Fire Apparatus West Islip FD
