Page 3 of 12 FirstFirst 123456789101112 LastLast
Results 51 to 75 of 281
Thread: Big Power Manual Transmission (S6-53) Swap
  1. #51
    Jul 2010
    Stafford, VA, US
    1997 BMW 328i
    Man those bolt holes look remarkably close to the OE ones
    Sent from my SM-N950U using Tapatalk
    Follow my builds on youtube and IG.
    www.youtube.com/thenameskam
    @thenameskam on IG
  2. #52
    Vancouver, BC Ca
    1993 325is
    That's purty!
  3. #53
    Apr 2002
    Shelby Twp, MI
    TurboVert, MCoupe, 335xi
    Quote Originally Posted by Kame36sedan View Post
    Close, but it's not going to happen without some kind of adapter ring. The top bolts by the head are like 10mm further apart and the others are shifted a few millimeters here and there.
    I tried bolting up an N54 6-speed transmission to an S52 and it wasn't going to happen. I think 2 bolts was all that would line up and I just wouldn't feel comfortable with that.
    I also bought a ZHP 6-speed and it bolts right up but they are not as plentiful and are rated lower than the N54 transmissions (but still stronger than the E46 M3 6-speeds).
  4. #54
    Jun 2005
    New England
    F90 M5; E36 M3 Turbo
    GS6-37 from E46 330i (or maybe Z4 3.0) is rated at 370NM, less than Getrag 420G from E46 M3 that is rated at 420NM.
  5. #55
    Apr 2006
    Minnesota eh?
    86 325es
    M52's are rated at 190 hp.
  6. #56
    Apr 2002
    Shelby Twp, MI
    Regardless of what the rating is, Jim Blanton and others have said it's a stronger and more reliable transmission. Endurance race teams have pulled the 420G from their cars and installed the ZF GS6-37 because it's that much better of a transmission. ZF licensed Getrag to make the GS6-37 trans as well. The only downside is clutch availability and rarity compared to other 6-speeds.
    N54 trans whoops them all, so that's where I'll be headed one of these days.
  7. #57
    Mar 2013
    Upstate NY
    M3
    Likewise, go find a 420g for under 1000$. They are insane right now and for good reason... it only came in the M3 pretty much. Now as long as that nice shiney chunk of billet machined on the local VMC does not cost us 1k$ or more like every other BMW taxxed part
  8. #58
    Mar 2012
    Renton, Wa
    98 m3
    Quote Originally Posted by Mklock View Post
    This whole swap kit will cost less than a 420g and a 1000tq clutch. I really should post some pricing.. just want to make sure everything is 100% before I get anyone too excited.
    1989 535i - sold
    1999 M3 Tiag/Dove - sold
  9. #59
    Mar 2013
    Upstate NY
    M3
    To late, I'm over here wagging my tail...
  10. #60
    poconos pa
    e36 m3, turbo e36
    So where do I send my money!
    -sold...replaced by turbo e36
  11. #61
    Jul 2002
    Long Island, NY
    98 Turbo M3, 04 E53 X5
    Whats the length difference between the 420g and the ZF GS6-37?
    Looking to see if I can still use my DSS 420g DS
    98 Fern Green M3/2 - Precision 6870/AR Designs Twin Scroll/RK/E85
    2017 Toyota Tundra Crewmaxx - Family Whip
    2011 Pierce 75' Quint - Fire Apparatus West Islip FD
  12. #62
    Jun 2005
    New England
    Length difference with adapter ring.
  13. #63
    Mar 2012
    Renton, Wa
    98 m3
    Quote Originally Posted by beeasy View Post
    Soon so soon.
    Quote Originally Posted by NY98M3 View Post
    I think it’s going to be really close, without measuring the 420 personally I cannot tell you exactly. I’ll get under the e46 later and take a measurement.
    1989 535i - sold
  14. #64
    Jan 2003
    Charlotte
    im sure ill be needing one!
    1998 Turbo M3 Nick G tuned setting 5 934Whp 849Wtq @27.88 Psi. ignite E90 setting 6=
  15. #65
    Royalest of Oaks
    Mazda 3
    This is going to sound lame for the FI section, but what about someone that wants a 6sp for stock power levels, with room to maybe going turbo in the future? Since you mentioned the ZHP trans isn't that easy to find, could different clutches be applied?
  16. #66
    Mar 2012
    Renton, Wa
    98 m3
    Quote Originally Posted by LSxDreamer View Post
    Yeah I can do an organic clutch pack for you.
    1989 535i - sold
  17. #67
    Bellingham, WA
    e30
    Just out of curiousity you mentioned the autos in the E90 dont totally suck. I have never considered an auto before so I dont follow them normally. Are all the autos in the platform not that bad or is it only true of the ones that are the “sport” or behind the 335s. Not sure if there is any difference between them even.
    I figure others may be interested too so thought I would ask!
    -Nick
    91 E30 M42 on VEMS
    Turbo Camshaft Thread
  18. #68
    Mar 2012
    Renton, Wa
    98 m3
    Quote Originally Posted by wazzu70 View Post
    Yeah the 6hp is pretty stout. There’s a few capacities 19/21/26.
    I have a buddy that’s a transmission calibration engineer and we have discussed how to implement this transmission from an electronics perspective.
    It’s the next stage of this project. A cheap automatic trans swap that will cover 700whp. I think I have EMC convinced to buy one and be my guinea pig.
    On some other fun news the aluminum guibo from the F series and other 2011+ cars will work with this swap.
    1989 535i - sold
  19. #69
    Vancouver, B.C., Canada
    '97 M3
    How does the aluminum guibo deal with flex?
  20. #70
    Mar 2012
    Renton, Wa
    98 m3
    Quote Originally Posted by chikinhed View Post
    Yeah these guys have rubber inserts, oem part.
    1989 535i - sold
  21. #71
    '97 M3
    It’s probably lighter as well. Is it the same bolt pattern as ours?
  22. #72
    Mar 2012
    Renton, Wa
    98 m3
    Its 105mm, our factory is 96mm. It will work with this 6s swap!
    Other fun news is the 335i driveshaft is the same diameter on the thick part.
    1989 535i - sold
  23. #73
    Under a roof
    507whp 318i
    Sorry if I missed it, but is there a certain DSS driveshaft that'll work perfectly with this?
  24. #74
    Jun 2005
    New England
    I have had 3 DSS. Hated them all. But never broken one.
  25. #75
    Under a roof
    507whp 318i
    Vibrations?
  1. The Official Auto-to-Manual Transmission Swap Thread
    By TheBestCow in forum 1991 - 1999 (E36)
    Last Post: 12-20-2023, 09:07 PM
  2. Manual Transmission/Rear Differential Fluid Swap
    By Johno in forum 1992 - 1999 M3 (E36)
    Last Post: 04-28-2018, 06:54 AM
  3. Replies: 30
    Last Post: 12-15-2016, 01:15 PM
  4. WTB: e30 manual transmission crossmember for swap
    By r4esh in forum BMW Parts Wanted
    Last Post: 01-06-2010, 10:52 AM
  5. Wanted: auto to manual transmission tranny swap parts
    By molszews in forum BMW Parts Wanted
    Last Post: 07-14-2005, 08:23 PM
