For the e46 platform I imagine the shift carrier we developed for the e36 will work, the shift selector rod is adaptable so no problems there, but the brace would need to be tested. I use the rear set of holes on the e36 and i am not sure if these translate to the e46.
Regardless, the brace I designed for the e36 has large pads on either side so it a matter of drilling a hole or two.
I think you would be working at a defect coming from the diesel because they run a different engine angle I believe. I have these guys rotated CCW 7* iirc.
I'd actually like to pick your brain on some e46 stuff if you are up for it sometime.
1989 535i - sold
1999 M3 Tiag/Dove - sold
Finally doing the trans swap. Did CES ever do a GS6-53 plus adapter plate to E32 210mm diff DSS driveshaft? I don’t think I can adapt my ZF320 to E32 diff DSS driveshaft because the GS6-53 output flange is 105mm versus the 96mm of the ZF320. My understanding is that DSS uses a CV joint rather than a u-joint and adapter plate for the larger output flange.
No one ever expressed that much interest in them... Until now that is 😁 Our shop car getting the 335 swap is still at the bodyshop so we do not have the car to do the measurements. Thank you pbonsalb for working with us to get these and have shafts made!
97 Turbo 3.2L M3 - Cutring / ARP - RSI Top Mount - Gt4088r - ID1300 - Tial WG - 22RPD Tuned - 93 Octane - 3.5" Stainless
Silly question, would this bolt up to an m62tub44 with the same adapter plate?
2002 BMW Titanium Silver 540i/6-speed Sport - ZHP Shift Knob - M5 Clutch/TTV Racing 15.6lb Flywheel - M60 Intake Manifold - N62 84mm TB - Dinan Intake Tube - 4" MAF Tube - DUDMD Tune - Magnaflow Resonator - Eibach 18mm Rear Sway Bar - Powerflex Front Sway Bar Bushings - CDV Delete - UUC SS Brake Lines - Koni Yellow Shocks/Struts - Eibach Springs - Zionsville Radiator & FDM
V8 and I6 bellhousings have different bolt spacing to orient the trans to the motor. You might find a plate at PMCbut the plate spaces the trans back so you have to compensate for that with a special flywheel. Maybe PMC makes one. Google PMC BMW M62 transmission adapter or something like that.
The other thing to look into is whether the V8 version of the GS6-53 fits an M62. It was used on the E9xM3, the F10M5 and maybe some others (M6). Might bolt right up but I have no idea about trans compatibility among the V8s.
When the kit will be available?
Yeah, but he's in Tampa. Time moves differently down there.
95 turbo 330ti. 01 maxpsi m3 e85. 01 m5. 01 m coupe. 03 AIM 996t e85. 06 x3 w/Meyers plow and winter daily. Prussian Motors is hiring!! prussianmotors.com/jobs
Current e39t LS Turbo swap: https://www.bimmerforums.com/forum/s...LS-e39-Touring
And for a second Bfc was revived hah.
1989 535i - sold
How many kits are in service at this point?
1989 535i - sold
I haven't forgot about you vollosso. I'm still working on the new blue turbo e46 m3. This one's making 870hp/630tq. So far, the trans is holding, but I just replaced the differential. If I break the transmission in the fall, I'll take it out of service for the winter and get your kit in this car. I already bought a wrecked 335 with the trans so it's on the shelf/ready to go!
1989 535i - sold
Also thinking about this kit and however want to see how long my stock trans last with the 210 swap. Time does move slow down here lol 3 or 4 years later and still putting my build together...lol
Mod list - M50 manifold; TechniqueTuning Stg2, Apex Arc-8, ZKW euro, clear corners Mike R diffbrace, Koni Yell with HR race
X-brace UCC tranny mounts -BLK/with enforcers, powerflex rtabs,lcabs, AAfanclutch, mishimoto rad, UCC Ultra-cerametallic Clutch.
You will go through days of joy and days of sadness as the pursuit for power leads to madness...
Is it possible to buy just the adapter plate, for those of us looking to adapt a DCT to their s54 for example?
- Brad
Just let me know we will have them available!
We could work something out, shoot me an email to info@22rpd.com and we will get it out together.
1989 535i - sold
What search engines are people using to source the transmissions? Ebay prices on these things are pretty high ($800-1000) and that is before shipping. I'm sure I am also not getting all the proper hits with searching for the exact PN either which stinks.
1989 535i - sold
I located a bunch on car parts dot com or something like that at LKQ yards within 100 miles for less than eBay. A local yard was affiliated with one of those yards and I was able to get it to transfer the trans and they sold it to
me at near cost due to a connection. 73k mile GS6-53 listed at $615 that I got for $450. It was an 07 or 08.
