Page 4 of 12 FirstFirst 123456789101112 LastLast
Results 76 to 100 of 281
Thread: Big Power Manual Transmission (S6-53) Swap
  1. #76
    Mar 2012
    Renton, Wa
    98 m3
    Quote Originally Posted by bavdrftr318 View Post
    Vibrations?
    Yeah they are just so long and only 3” dia.
    1989 535i - sold
    1999 M3 Tiag/Dove - sold
  2. #77
    Jul 2010
    Stafford, VA, US
    1997 BMW 328i
    Diameter and thickness. Anything more than 3" tho and you touch the gas tank. I just got a 3" chromoly one made, I hope I don't have issues myself.
    Sent from my SM-N950U using Tapatalk
    Follow my builds on youtube and IG.
    www.youtube.com/thenameskam
    @thenameskam on IG
  3. #78
    Under a roof
    507whp 318i
    Quote Originally Posted by Kame36sedan View Post
    Huh... so I guess it’s just a necessary evil going big power and you learn to live with it?
    Not so much vibration it’s a safety thing?
  4. #79
    Jul 2010
    Stafford, VA, US
    1997 BMW 328i
    Supposedly dss doesn't have vibrantion issues anymore but I've never run one so idk.
    @thenameskam on IG
  5. #80
    Mar 2012
    Renton, Wa
    98 m3
    Well the good news is when the transmission is almost 6” longer you end up with quite a bit higher critical speed and therefore less vibration.
    Also once I have this trans mounted in a couple days I’ll look and see if we can fit a 3.5” driveshaft. A 3.5” aluminum shaft would be the perfect solution.
    1989 535i - sold
  6. #81
    Under a roof
    507whp 318i
    Quote Originally Posted by vollosso View Post
    That you’d have to remove gas tank though no?
  7. #82
    Mar 2012
    Renton, Wa
    98 m3
    No im hoping we can keep it. I’ll know more in the coming days.
    1989 535i - sold
  8. #83
    Jun 2005
    New England
    F90 M5; E36 M3 Turbo
    3.5 won’t fit due to the size of the opening between the gas tank saddles. CES uses a 2.75 CF DSS shaft. With CF you definitely don’t want any rubbing.
    The vibration comes in part from the length and in part from the lack of guibo. I have a one piece CF shaft on my E90M3 with guibo and zero vibration. BMW factory fitted one piece CF shafts on the F80M3, with guibo.
    My DSS one piece chromoly no guibo shaft I bought in 2017 vibrates just like the one I bought in 2013 or 2014 and the one I bought in 2015 or 2016.
  9. #84
    Jul 2010
    Stafford, VA, US
    1997 BMW 328i
    You CAN fit it. It just rubs the gas tank lol
    @thenameskam on IG
  10. #85
    Under a roof
    507whp 318i
    So why not just use a guibo on all DSS? At certain power levels does that become a point of failure?
  11. #86
    NY
    325i, 530i, F250
    I bought the 3.5" DS that Dburt had in his TT LS E36 for my car....
    Sent from my SAMSUNG-SM-G930A using Tapatalk
  12. #87
    poconos pa
    e36 m3, turbo e36
    What about shimming the sub frame down to add clearance for a larger diameter drive shaft
    -sold...replaced by turbo e36
  13. #88
    NY
    325i, 530i, F250
    Quote Originally Posted by beeasy View Post
    Would about shimming the sub frame down to add clearance for a larger diameter drive shaft
    Thats exactly what Dburt did....im planning on doing it to my car as well....Just use the same McMaster washers that are used when installing the Powerflex rear subframe bushings...
  14. #89
    Jun 2005
    New England
    My SF is shimmed down about 1/2 inch with double MC washers front and single in rear. Pinion angle is an issue with one piece. Domestic motor conversions may be mounted higher or lower. You can lower an S52 about 1/4 to 3/8 inch no problem.
    Might want the Chickinhed anti movement kit for the subframe. Then tolerance could be tighter on tank clearance and less risk for CF shaft. Been checking Walmart every day but have not seen the kit on the shelves yet.
    DSS never bothered trying to make a shaft that would allow a guibo. A shaft shop probably could. The 2004 GTO might have a 3 bolt front piece that could be used on a custom shaft for an E36 guibo. Revshift makes an aluminum guibo with poly inserts (that supposedly causes vibration).
  15. #90
    Boston, MA
    E36 M3 Turbo
    I've used the revshift poly guibo and it is a horrible vibration source. I think the factory 335 guibo would be perfect
    Sent from my SM-G930P using Tapatalk
    97 Turbo 3.2L M3 - Cutring / ARP - RSI Top Mount - Gt4088r - ID1300 - Tial WG - 22RPD Tuned - 93 Octane - 3.5" Stainless
  16. #91
    Louisville, KY
    turbo m3
    Hey guys finally some good news, clutch is ironed out. I am so excited to test this setup.
    The prototype clutch (for my car) is a carbon-compound full-face twin-disk. Rated for 1000ftlbs tq. Added bonus, this compound should exhibit exceptional wear life.
    Im also looking at cae style shifters for this setup, I really am looking forward to WOT 2-3 shifts.. something I refrain from currently hah.
    With the full face, it should be very streetable.
    My old HPF feramic clutch is nice, which I believe SBC made for them.
  17. #92
    Vancouver, B.C., Canada
    '97 M3
    LOL! It’s in the large woman bra and girdle section. Dig deep in the discount bin, it’s at the bottom.
    I have to install it and test it before I start producing them. It would be all done if I didn’t keep coming up with new mods to do. I’ve made a bolt on plate for the bottom of the subframe to get the diff out easier and I’ve just ordered an e46 M3 rear cover for the 210. The bolt pattern is the same but mount points are in a different spot than the ‘boomerang’ mount so there is going to be more cutting and welding in my future.
  18. #93
    Mar 2012
    Renton, Wa
    98 m3
    Ring fits. I have to shift two holes for the final design to be perfect, but I’ll be using this one in my car.
    Tested the starter with an old auto starter ring.
    Excuse the phone photos, it’s been a long day.
    1989 535i - sold
  19. #94
    Vancouver, BC Ca
    1993 325is
    Looks awesome. That trans is a monster!!
  20. #95
    Jul 2010
    Stafford, VA, US
    1997 BMW 328i
    Nice
    @thenameskam on IG
  21. #96
    '97 M3
    The S6-53 is about the same weight as a T56.at 123 lbs, depending on the model.
  22. #97
    Jun 2004
    The D, MI
    97 M3, 98 328i, 13 Cruze
    Just for the record I hate you. I should have waited another year to go 6 speed I guess..
    If I hurt the 420g I'm in deep enough to just put another one in most likely though.
  23. #98
    Under a roof
    507whp 318i
    Does this change the location of the shifter when comparing to a zf shifter location?
  24. #99
    Mar 2012
    Renton, Wa
    98 m3
    You’ll need a shortened linkage. Which will be included
    1989 535i - sold
  25. #100
    Mar 2013
    Upstate NY
    M3
    So what's the group buy pricing starting at?
  1. The Official Auto-to-Manual Transmission Swap Thread
    By TheBestCow in forum 1991 - 1999 (E36)
    Last Post: 12-20-2023, 09:07 PM
  2. Manual Transmission/Rear Differential Fluid Swap
    By Johno in forum 1992 - 1999 M3 (E36)
    Last Post: 04-28-2018, 06:54 AM
  3. Replies: 30
    Last Post: 12-15-2016, 01:15 PM
  4. WTB: e30 manual transmission crossmember for swap
    By r4esh in forum BMW Parts Wanted
    Last Post: 01-06-2010, 10:52 AM
  5. Wanted: auto to manual transmission tranny swap parts
    By molszews in forum BMW Parts Wanted
    Last Post: 07-14-2005, 08:23 PM
