Page 8 of 12 FirstFirst 123456789101112 LastLast
Results 176 to 200 of 281
Thread: Big Power Manual Transmission (S6-53) Swap
  1. #176
    Mar 2012
    Renton, Wa
    98 m3
    Bolt kits for days. 33 bolts per kit. Plus washers/nuts/etc.
    1989 535i - sold
    1999 M3 Tiag/Dove - sold
  2. #177
    Mar 2012
    Renton, Wa
    98 m3
    1989 535i - sold
  3. #178
    Mar 2012
    Renton, Wa
    98 m3
    I am very pleased to announce these have all shipped. Thank-you again everybody for being apart of this.
    Instructions will be up on the website today!
    1989 535i - sold
  4. #179
    Mar 2012
    Renton, Wa
    98 m3
    I have been asked a few times where to source the transmissions.
    The easiest source is below, id recommend calling and talking with them.
    http://car-part.com/cgi-bin/search.c...erPage=1&iKey=
    1989 535i - sold
  5. #180
    Mar 2012
    Renton, Wa
    98 m3
    I would like to do a update about the transmission kit after having driven it some more!
    First, I am extremely happy.
    I can finally use third again. A hard 2-3 shift is unreal at 30+ psi, I almost forgot since I have been babying 3rd for so long.
    I took the car up to 80 mph I was at ~2800. This makes a huge difference in the overall cars highway-ability with all my stiff mounts. PLUS Zero vibrations from my franken-shaft.
    This transmission is very smooth even compared to the Zf 320.
    I much prefer this 6th ratio to the 420 ratio. I always found the 420 ratio a bit low for a 3.15, it was setup for the e46 3.64 rear end.
    I took the car through a drive-through today, just because I could.
    Once broken in the 1k clutch is very drive-able, leaving at 1500 rpm is more than enough for it to be smooth. So far it has broken in even further with every mile driven.
    1989 535i - sold
  6. #181
    May 2015
    Methuen, MA
    1999 BMW M3 Coupe
    This is pretty dam cool. 335i tranny and clutch kit in 20 year old cars. Lol badass.
    PTE6262 .63 A/R, Stock S52, Cutring/Copper Spacer/Arp Studs Combo, Water Methanol Injected
    10.9@131mph. #AngerMotorsports
  7. #182
    Mar 2012
    Renton, Wa
    98 m3
    Hey guys I know some of you are installing these. Here is the PDF on installing these: LINK
    1989 535i - sold
  8. #183
    Mar 2012
    Renton, Wa
    98 m3
    I put down 950 wheel-torque today through the carbon graphite clutch combo that has been in my car for however long. The whole setup has performed flawlessly I am extremely happy.
    I’ll be back at the Dyno in a few months hoping to hit 1100whp w/ 46psi boost.
    The downside is I have destroyed two differentials already. The last one made it halfway through a single 3rd gear pull. I’ll be developing a 1000tq rearend solution with matching axles and driveshaft, this November. I’d like to be able to offer a bolt on drivetrain for serious power and I’m hoping this platform continues to grow in this direction because it continues to amaze me.
    1989 535i - sold
  9. #184
    Jun 2005
    New England
    F90 M5; E36 M3 Turbo
    That’s big power! With what driveshaft did you hit 950 lbs rwtq? And what diffs broke? E32 3.15 or E36 188mm?
  10. #185
    Apr 2014
    Greece
    M3 e36
    [QUOTE=vollosso;300884,
    1100Whp with a 6870?Can we see the dyno-sheet with 950 wheel torque i am curious to see it.
  11. #186
    milKt's Avatar
    milKt is offline ßMW///MµrÐêr§þðr†
    Flaccid US Appendage
    95M3t 95M3 92525iT 95525
    Quote Originally Posted by M3turboE36 View Post
    Did a moderator comment on your "focus" on this contributing member earlier this year?
    Fishy.
    https://www.bimmerforums.com/forum/s...0#post29955790
  12. #187
    Mar 2012
    Renton, Wa
    98 m3
    I was using the 328i front shaft. Really never had much traction nor do I launch it. I think the combo there has saved it.
    They are 188s. I sold my 210 a while back because I kept saying I would do this other diff swap but things keep pushing it out hah. Honestly the 188s do okay, but 3rd gear pulls on the highway with that kinda boost at 4k is a tough life. I’ll post a graph but it’s like 800wtq by 4k.
    1989 535i - sold
  13. #188
    May 2015
    Methuen, MA
    1999 BMW M3 Coupe
    Quote Originally Posted by vollosso View Post
    Holy crap. This is in an E36?
  14. #189
    Mar 2012
    Renton, Wa
    98 m3
    Quote Originally Posted by E36Mylo View Post
    Yeah theres a bunch of videos floating around too.
    1989 535i - sold
  15. #190
    May 2015
    Methuen, MA
    1999 BMW M3 Coupe
    That's nuts. Lol I can't even imagine what that feels like full throttle on the road.
  16. #191
    Mar 2012
    Renton, Wa
    98 m3
    Haha it’s pretty wild when it hooks. Full boost by like 4k on the road.
    Heck it is wild fast when it’s spinning.
    I should put a 4link and a solid axle in it, then it would really go.
    1989 535i - sold
  17. #192
    May 2015
    Methuen, MA
    1999 BMW M3 Coupe
    Yea I bet. I can't even imagine what that feels like. Ever tried the track? I wonder what something like that could trap. Easily 160+ mph
  18. #193
    Mar 2012
    Renton, Wa
    98 m3
    Driveline isn’t sorted enough yet. After I finish the new motor a driveline kit I’ll go send it
    1989 535i - sold
  19. #194
    May 2015
    Methuen, MA
    1999 BMW M3 Coupe
    I wanna see that lol that's going to get you kicked out and banned after 1 pass. Haha
  20. #195
    Mar 2012
    Renton, Wa
    98 m3
    Oh absolutely.
    1989 535i - sold
  21. #196
    Vancouver, BC Ca
    1993 325is
    Oh absolutely.
    Bring it to Mission here, about 2 hours north of Seattle. Fastest track out there. Like 10' above sea level. Lots of records here. I'll be there to watch if you come.
  22. #197
    Phoenix, AZ
    E36 M3/4/5 & E46 LSB M3
    I have an N54 tranny sitting in my garage if anyone is interested
    1997 BMW ///M3 - Estoril Sedan 5MT - M-Rain Interior (1 of 1)
    2001 BMW ///M3 - Laguna Seca Blue 6MT
    YouTube: (///Motorsport Throttle)
    https://www.youtube.com/channel/UCUM...pYSmibzy5YmUvQ
  23. #198
    Nov 2002
    Westchester, NY
    is this basically the same as the kit available at zionsville? what are the differences?
  24. #199
    Apr 2006
    Minnesota eh?
    86 325es
    Oh absolutely.
    Mabey for trap speed. We’ll see on ET.
  25. #200
    m3mods's Avatar
    m3mods is offline Boost Addict BMW CCA Member
    Sep 2011
    AC Schnitzer S3 CLS
    Quote Originally Posted by RickyN F355 View Post
    No that’s for a gs6-37bz which bolts on without an adapter plate and is rated for less torque.
  1. The Official Auto-to-Manual Transmission Swap Thread
    By TheBestCow in forum 1991 - 1999 (E36)
    Last Post: 12-20-2023, 09:07 PM
  2. Manual Transmission/Rear Differential Fluid Swap
    By Johno in forum 1992 - 1999 M3 (E36)
    Last Post: 04-28-2018, 06:54 AM
  3. Replies: 30
    Last Post: 12-15-2016, 01:15 PM
  4. WTB: e30 manual transmission crossmember for swap
    By r4esh in forum BMW Parts Wanted
    Last Post: 01-06-2010, 10:52 AM
  5. Wanted: auto to manual transmission tranny swap parts
    By molszews in forum BMW Parts Wanted
    Last Post: 07-14-2005, 08:23 PM
