1989 535i - sold
1999 M3 Tiag/Dove - sold
Diameter and thickness. Anything more than 3" tho and you touch the gas tank. I just got a 3" chromoly one made, I hope I don't have issues myself.
Sent from my SM-N950U using Tapatalk
Follow my builds on youtube and IG.
www.youtube.com/thenameskam
@thenameskam on IG
Supposedly dss doesn't have vibrantion issues anymore but I've never run one so idk.
@thenameskam on IG
Well the good news is when the transmission is almost 6” longer you end up with quite a bit higher critical speed and therefore less vibration.
Also once I have this trans mounted in a couple days I’ll look and see if we can fit a 3.5” driveshaft. A 3.5” aluminum shaft would be the perfect solution.
1989 535i - sold
1989 535i - sold
3.5 won’t fit due to the size of the opening between the gas tank saddles. CES uses a 2.75 CF DSS shaft. With CF you definitely don’t want any rubbing.
The vibration comes in part from the length and in part from the lack of guibo. I have a one piece CF shaft on my E90M3 with guibo and zero vibration. BMW factory fitted one piece CF shafts on the F80M3, with guibo.
My DSS one piece chromoly no guibo shaft I bought in 2017 vibrates just like the one I bought in 2013 or 2014 and the one I bought in 2015 or 2016.
You CAN fit it. It just rubs the gas tank lol
@thenameskam on IG
I bought the 3.5" DS that Dburt had in his TT LS E36 for my car....
Sent from my SAMSUNG-SM-G930A using Tapatalk
What about shimming the sub frame down to add clearance for a larger diameter drive shaft
-sold...replaced by turbo e36
My SF is shimmed down about 1/2 inch with double MC washers front and single in rear. Pinion angle is an issue with one piece. Domestic motor conversions may be mounted higher or lower. You can lower an S52 about 1/4 to 3/8 inch no problem.
Might want the Chickinhed anti movement kit for the subframe. Then tolerance could be tighter on tank clearance and less risk for CF shaft. Been checking Walmart every day but have not seen the kit on the shelves yet.
DSS never bothered trying to make a shaft that would allow a guibo. A shaft shop probably could. The 2004 GTO might have a 3 bolt front piece that could be used on a custom shaft for an E36 guibo. Revshift makes an aluminum guibo with poly inserts (that supposedly causes vibration).
I've used the revshift poly guibo and it is a horrible vibration source. I think the factory 335 guibo would be perfect
Sent from my SM-G930P using Tapatalk
97 Turbo 3.2L M3 - Cutring / ARP - RSI Top Mount - Gt4088r - ID1300 - Tial WG - 22RPD Tuned - 93 Octane - 3.5" Stainless
LOL! It’s in the large woman bra and girdle section. Dig deep in the discount bin, it’s at the bottom.
I have to install it and test it before I start producing them. It would be all done if I didn’t keep coming up with new mods to do. I’ve made a bolt on plate for the bottom of the subframe to get the diff out easier and I’ve just ordered an e46 M3 rear cover for the 210. The bolt pattern is the same but mount points are in a different spot than the ‘boomerang’ mount so there is going to be more cutting and welding in my future.
Ring fits. I have to shift two holes for the final design to be perfect, but I’ll be using this one in my car.
Tested the starter with an old auto starter ring.
Excuse the phone photos, it’s been a long day.
1989 535i - sold
Nice
@thenameskam on IG
The S6-53 is about the same weight as a T56.at 123 lbs, depending on the model.
Just for the record I hate you. I should have waited another year to go 6 speed I guess..
If I hurt the 420g I'm in deep enough to just put another one in most likely though.
Does this change the location of the shifter when comparing to a zf shifter location?
1989 535i - sold
So what's the group buy pricing starting at?
