Hello
My car is jerking sometimes. I notice it at low speed in low gears... I am getting error codes as per below.. can anyone help?
Fault Code: 004837
Fault Explanation:Boost pressure plates, status line
Fault Code: 004AFB
Fault Explanation:Brake vacuum sensor, signal
Fault Code: 004AD5
Fault Explanation:Zero quantity adaptation injector
cylinder 1
Fault Code: 004AF5
cylinder 3
Fault Code: 004B05
cylinder 4
Fault Code: 004AE5
cylinder 2
They come back after a error memory clear
glowplug symbol sometimes comes up for a split second when pressing start button
Any help would be much appreciated
Bill
Hi did you ever find out what was wrong because I’m getting exactly the same codes
