Results 1 to 2 of 2
Thread: P0014 diagnosis
    Mar 2013
    Alpharetta
    1998 z3
    P0014 diagnosis
    Read lots of posts trying to clear a p0014 that popped up Friday but not ready to start trying to resolve yet. Most posts settle on two culprits- bad exhaust position sensor or bad or stuck vanous piston.
    120 days ago I replaced the sensor for a different code and it took care of the problem. 90 days ago I replaced the venous seals and oil filter housing gasket and until 2 days ago all was well.
    I have a c-110 scanner (son has it at school actually) but I hope it will be able to diagnose vanous operation without having to tear into it again.
    Any reality advice on other culprits would be appreciated.
    John
    Sent from my iPad using Tapatalk
    Dec 2013
    Chicagoland area
    EXOTICS
    Remove and clean both Vanos solenoids, intake and exhaust.
    If recommended oil change intervals, with quality oils,
    have not been regularly performed, then that may be the cause.
    For a good BMW scan tool,I feel you have 3 options:
    Don't forget to purchase the recommended cables for your model BMW.
    Any of these options is a major improvement over the generic P-code scan tool.
  1. ASC&ABS lights coming on - Diagnosis??
    By Keda in forum 1992 - 1999 M3 (E36)
    Last Post: 05-01-2002, 05:21 PM
  2. Help!! Thermostat Diagnosis
    By Jeff in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 08-28-2001, 12:12 PM
  3. Help!! Thermostat Diagnosis
    By Jeff in forum 1992 - 1999 M3 (E36)
  4. Help!! Thermostat Diagnosis
    By Jeff in forum 1991 - 1999 (E36)
    Last Post: 08-28-2001, 10:06 AM
  5. Problems with Oil Pressure, need some diagnosis help
    By Lopaka in forum 1992 - 1999 M3 (E36)
    Last Post: 07-01-2001, 11:24 PM
