Results 1 to 5 of 5
Thread: suggetions on sub woofer amp placment
    Jun 2012
    Mundelein, IL
    840Ci/6 528iT Europa TCS
    Hi all. I recently found and purchased a Bavsound sub woofer speaker box to replace the OEM sub with no DSP. The sub is loaded with a Memphis 10" dual voice coil woofer at 4 ohms. Now, I bought an Alpine 300 watt (@4ohms) mono block amp measuring 7.5x7.5x2.5. For you guys who have been down this road before, where is a good place to install the amp?
    I have the factory CD player and the factory nav installed on the drivers side.
    Feb 2014
    Seattle wa usa
    2003 546it m-sport
    Jun 2014
    Acton, IN
    330i ZHP, 03 525iT Sport
    Not sure what is supposed to go under here, but my 03 didn’t have anything in this space.
    I installed my old school PPI PC4800 in this spot under the carpet and have had zero issues.
    Granted, I’m running two 8 inch subs and my front components off of it.
    Sep 2008
    West London/Heathrow - UK
    03 530dT - Ex Police Car
    Hi,
    Here's my build!
    https://www.bimmerforums.com/forum/s...-Audio-Upgrade
    Same location as simmsled
    Cheers, Dennis!
    Jun 2012
    Mundelein, IL
    Thank you very much for sharing your fine, fine, superfine, sound system. Did you fabricate the pods on the C pillars and the extensions/cabinets on the doors? They are very nicely executed. So I now have an answer to that question. I will located the amp forward of the spare tire well.
    Do you or anyone here know the speaker diameters in the doors and roof? I have used Faital Pro drivers in the past and I am considering them again here. They make three, four, and five inch Ferrite and Neodymium drivers. I would love not to have to pull the door panels off to measure. Another maybe easier option, is to do the stage 1 Bavsound kit once the subwoofer is in place. Any comments on the Bavsound kit?
    Thanks again for the help.
  1. How Do I take off the AMP and Sub-woofer cover on a coupe?
    By Basha3 in forum 1996 - 2002 Z3 (E36/7, E36/8)
    Last Post: 01-07-2018, 02:21 PM
  2. How Do I take off the AMP and Sub-woofer cover on a coupe?
    Last Post: 01-05-2018, 06:14 AM
  3. How do i connect a sub woofer/amp to my car
    By EssCee in forum Car Audio & Electronics sponsored by Bavsound
    Last Post: 03-30-2006, 03:55 AM
  4. help on sub and amp install in E39 540i with DSP?
    By supark in forum 1988 - 1996 (E34)
    Last Post: 01-03-2006, 02:26 PM
  5. Need help on sub+amp hook up to stock stereo system
    By xctasy in forum Car Audio & Electronics sponsored by Bavsound
    Last Post: 07-01-2001, 11:29 PM
