Results 1 to 6 of 6
Thread: 50psi hose
    Jan 2012
    Vancouver, BC Canada
    1985 Mercedes 300SD
    50psi hose
    I have a coil of non fuel injection hose here, but it's rated at 50psi. Just wondering what are cars run at and if it's s bad idea to use it.
    1983 BMW 733i My current project (or at least one of them)
    2003 Volvo V70 5 Speed Current Daily Driver
    1993 300TE 4Matic Project wagon -sold
    1997 E290 Turbo Diesel Wagon -traded for above, an amazingly comfortable car to drive, great drivetrain, but the rust, oh my god the rust
    1992 BMW 525i -traded in
    1990 Silver 300TE -Sold Loved the wagon, hated the M103
    1985 Grey 380SE Diesel Conversion, 2.47 rear end, ABS -Sold, really should have kept this one
    1979 Silver 300D "The Silver Slug" -Sold
    Quadratechtown, PA
    5, 7, 4x4
    Cars run at 3 bar, you need higher rated hose.
    But there are some low pressure situations that you can use the hose, maybe the vent tank in the back and the charcoal filter in the front.
    Jan 2012
    1985 Mercedes 300SD
    Isn't 3 Bar only 43PSI?
    Mar 2013
    USA
    E21/early e23/e34
    3 bar is more like 44psi, but it's not rated for fuel and I'd be leary of using it for that purpose... last thing you need to have happen is a fuel line rupture, I use rated fuel lines and clamps for that purpose, wouldn't matter anywhere else I suppose.
    Jan 2012
    1985 Mercedes 300SD
    It is fuel line, it just says on it " not for fuel injection, 50psi".
    Either way I'll probably just go buy a couple feet of the correct hose. I was just curious.
    Quadratechtown, PA
    5, 7, 4x4
    Good,
    FI hose, SAE J30R9, is rated for 100 psi and 900 burst pressure. That 50 psi stuff you have isn't for any FI pressurized use.
  1. can someone help me with removing power steering hose clamps?
    By pikachu in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 04-29-2002, 01:32 PM
  2. Breather hose broken help!!
    By CJ in forum 1991 - 1999 (E36)
    Last Post: 02-19-2002, 03:02 PM
  3. Crankcase Vent Hose
    By pescadito in forum 1991 - 1999 (E36)
    Last Post: 09-28-2001, 10:02 PM
  4. check the hose connectors on your fuel filter!!!
    By M3Jokster in forum 1992 - 1999 M3 (E36)
    Last Post: 07-31-2001, 02:29 AM
  5. 318i (M42 engine) hose question...
    By DDD in forum 1991 - 1999 (E36)
    Last Post: 05-22-2001, 12:13 AM
