Results 1 to 3 of 3
Thread: Vanos solenoids bolt replacement
    Cornelius, NC
    09 535ix
    So I took solenoids out to clean them and not one, but BOTH bolts fell and disappeared. Anybody know the thread size and length so I can make a home Depot run?
    RIP Jess or the idea of Jess or... what OT was.. or whatever...
    Feb 2010
    Atlantic Beach, Fl
    81,e21 orig ownr&05,e60
    Check REALOEM.com for bolt info and you are probably better off at a Ace Hardware for metric bolt selection.
    They are 10 mm head bolts, which means 8 mm thread size (that's how bolts are measured) I believe it's 1.0 thread pitch. About 10 mm long maybe?
  1. Vanos Solenoid Gaskets Replaced: Still weeping oil
    By machinemanjr in forum 1995 - 2001 (E38)
    Last Post: 11-23-2014, 10:23 AM
  2. Stripped Vanos Solenoid Bolt Hole in UTC
    By peter540 in forum 1996 - 2003 (E39)
    Last Post: 12-11-2013, 11:04 AM
  3. vanos solenoid gasket replacement - how to torque?
    By mng in forum 1996 - 2003 (E39)
    Last Post: 05-04-2013, 10:27 PM
  4. Vanos solenoid bolt/nut size
    By woodzusa in forum 1996 - 2002 Z3 (E36/7, E36/8)
    Last Post: 06-20-2010, 11:55 AM
  5. 2000 M5 Vanos solenoids need replacing?
    By coxthorne in forum 1996 - 2003 (E39)
    Last Post: 08-29-2007, 06:31 PM
