Results 1 to 21 of 21
Thread: Who has an LSx Swapped E38! Prospective Swapper Here!
    Oct 2017
    Camarillo, California
    2001 BMW 740iL
    Hi Everyone,
    Due to my run-in tonight with a LS3 Swapped E30, I have the itch to junk my '95 7er's dying M62 V8 for an LSx + T56 combo.
    It's super hard to find any information on a swap like this and want to know if any user on here has experience with doing such a swap, and if I could get recommendations for a shop to do the work, and or tips on how to do the swap myself.
    Any help would be greatly appreciated. Let me know!!!
    btw: sorry for my sloppy grammer, it's 1 AM and I'm tired.
    Feb 2015
    Grant, AL. United States
    98 740i, 01 540i
    I found a website that had a conversion for the e38 but my old phone died where I had it saved. Its not cheap and not complete but it had the mounts and maybe headers for it. Youd need to do a lot of wiring and programming though, along with custom driveshaft and many other similar stuff. A big pain is getting the dash gauges to work.
    Rutland, Vermont
    E30 E38 E46 E85 F150 GTI
    Mar 2013
    Sonora, ca
    2001 740il
    I found that 95 is the best for swap electrically, because it’s analog inputs for gauges and such, there are some that have figured out some of the can protocol but that is the hardest part of swap, communication. Check the e39 forum for swap been done a ton of times there.
    Rutland, Vermont
    Hopefully rvae34 will check in. He did this in an E39 which has to be a fairly similar swap.
    2000 740i Sport | 2004 330xi | 1988 325i Vert | 2003 Z4 2.5 | 1995 Ford F150 | 2018 GTI
    Oct 2018
    Vancouver, BC
    2001 BMW 740i
    I'm planning an LS swap now too. It's time to replace the timing chain guides and upper oil pan gasket on my 2001 M62TU... so might as well yank the engine and replace it with something smaller that I'm more familiar with.
    I'm planning an aluminum 5.3L and 4L80E trans. I aim to figure out how to get the GM ECU to export CANbus signals to the gauge cluster, but I'm still driving my E38 at the moment so that progress is way off haha.
    I also want to make super-low-profile block hugging mid-length headers to clear the steering box/shaft. It seems any E38 LS swap I can find a thread for is single-turbo'd, which doesn't help with ideas on driver side header fabrication/clearance.
    Subscribed to this thread tho.
    May 2019
    Kansas City
    2001 bmw 740il
    I have an e38 lq9 4l80e with BW s475. Has a new e39 custom wavetrack helical diff on the way right now. I’d post pics but it’s don’t have any links and it looks you you have to be a damn computer programmer to post them here.
    Mar 2013
    Sonora, ca
    2001 740il
    Quote Originally Posted by handofmercy View Post
    Get Tapatalk app downloading photos is a snap.
    May 2019
    Kansas City
    2001 bmw 740il
    May 2019
    Kansas City
    2001 bmw 740il
    Maybe this will work.
    Houston
    2001 740il
    No step by step write up for the uninitiated Batman?
    May 2019
    Kansas City
    2001 bmw 740il
    Quote Originally Posted by Zedbimmer View Post
    I’m new here. There is a bit of it on FB group e38 empire. I can do a little bit of a write up on it when I get some free time in next day or two. Not too much history on the e38 last swaps. I feel like mine will never really be done though. I guess that’s the nature of hotrodding cars. Supposed to be getting my new custom e39 m5 wavetrack helical differential next week. I’m pretty stoked about that. Need to get it back on the dyno too so I can get it all turned up to 11.
    Oct 2014
    Mesa AZ
    2000 740iL
    Quote Originally Posted by frojoe View Post
    An LS is more narrow than the M62, I would bet that you have an extra inch of clearance from the steering box. You could also bolt in an e39 6 cyl subframe and have rack an pinion. That would also allow you the use of a rear sump oil pan. Either way, I guess my point is that you probably don't have to compromise as much on header design as you think you will.
    May 2019
    Kansas City
    2001 bmw 740il
    I used truck headers that I modified. You would be fine using them. The steering rack isn’t a problem.
    Houston
    2001 740il
    been two days and more
    IL
    2000 740i sport
    Subscribed
    Jun 2018
    Castle Rock CO
    1990 325is, 1998 740i
    He finally comes to the forums...
    I have followed your 7 on youtube/insta/facebook wherever it pops up
    nice swap I haven't been able to figure out what transmission you used though
    I like to pretend I know stuff
    Sep 2001
    Coral Springs, FL
    E21,E38,E39,F10 M5
    I know of a turbo LS swapped E65 here in South Florida.. never seen an E38 until now with that silver one posted here... that thing must drive like a bat out of hell.
    Stancing is for drivers trapped in an abusive relationship of their own lives.
    Jul 2004
    FL / 6ix
    RWD
    Quote Originally Posted by KinkedChrome View Post
    E39 front subframe will not bolt up without modification, just wanted to point that out.
    Oct 2014
    Mesa AZ
    2000 740iL
    Quote Originally Posted by T.Dot E30 View Post
    Yeah, i should have been more clear. Its really close to bolting in though.
    The bolt patterns are the same and the front most bolt hole needs to be modified.
    VA
    E63AMG/Z31/Tacoma/F31
    I used an autokraft oil pan on my e39 but no clue if necessary on the e38.
  1. Who has an M-Tech 2 wheel in their E34?
    By LJSE34 in forum 1988 - 1996 (E34)
    Last Post: 02-20-2005, 05:53 PM
  2. who has an ETK with the new CSL in it?
    By odortiz in forum 1992 - 1999 M3 (E36)
    Last Post: 11-26-2003, 10:01 PM
  3. Who has an Infinity Basslink Installed?
    By achilles99 in forum Car Audio & Electronics sponsored by Bavsound
    Last Post: 07-02-2003, 08:29 AM
  4. Who has an etk?
    By GMat in forum 1992 - 1999 M3 (E36)
    Last Post: 01-06-2003, 11:58 AM
  5. Who has an (M)6 series?
    By ///Milk in forum 1976 - 1989 (E24)
    Last Post: 12-31-2002, 01:03 AM
