So I clumsily manage to knock the cap off and it fell into the engine bay crevice one night while working on the car. I couldn't find the part no matter how hard I tried.
Anyone knows which of our favorite online retailer carries replacements or what its part number is?
small- 6113 1383901
medium- ...1383903
large- ....1383905
jumbo- ...1383897
try these......
You better look harder because they no longer sell those little ones.
I used a bit of silicone sealant (you can use RTV also), to safely secure the cap to the connector. Put a small amount on the underside of the cap and set in place.
I did the same thing with the jack pads under the car. Still there after many years.
'93 850Ci - Mineralweiß Metallic
2001 740iL - Titansilber
ALPINA B7 -Alpinweiß III
I second TX's advice. Both have a tendency to pop out or go missing.
What "thumbs up" really means
if you don't want to deal with it again...
http://www.te.com/usa-en/products/ha...&tab=pgp-story
Can't seem to get a proper online search hit using those numbers you provided, ATA197.
Also, I would like to use original part if necessary especially those caps if still available; even used ones will be fine.
I will certainly tack the existing ones down as TX suggested. That's a great idea.
As last resort, I may try the aftermarket stuff. I think I will try Wuffer as he has a couple parts cars coming in soon.
Got the numbers directly off the part. Apparently they are nla. Sorry
