Results 1 to 10 of 10
Thread: Sunbelt Stage 3 cams setup question
    Dec 2005
    utopia
    17 F250 12 Merc C250
    Hey guys and gals, got a set of Sunbelts Stage 3 cams for my 325is, 2.5l, 11.5:1 CP pistons, moneyshift valve cutouts from VAC, Pauter rods, crank worked, ATI damper, S54 oil system, megasquirt, M50 manifold, etc. Looking for some setup info. I have heard 3 degrees retarded on the intake cam, small vanos shim from Bimmerworld etc. Haven't found adjustable timing gears. Anybody run this setup? Have any knowledge? ZF trans. Running in SCCA STU, currently have a built 3.91, probably switching to the 3.64.
    Chris Leone
    chrisleonemotorsports.com
    roll cages, repairs and racecar fabrication
    1984 318i now 325is
    1994 325is STU racecar
    1988 325is donor
    Jul 2001
    F150, Suburban, M3
    Search, there are a couple good threads on Sunbelt setup. Helped me, but itís been so long I donít recall the details. One of the cams straight up, one retarded, vanos limiter, degree wheel and dial indicator, something... you donít need adjustable gears, all can be done in vanos setup.
    Social media weaponizes blandness - Sebastian Junger
    Jun 2012
    PR
    '93 e36 race car
    Quote Originally Posted by XXLBIMMER View Post
    Very interested is following your progress and hearing how this engine works for you. I plan on building a 2.5L for STU.
    Vancouver, BC Ca
    1993 325is
    If you have moneyshift valve pockets in your pistons, why do you need a Vanos shim?
    Dec 2005
    utopia
    Quote Originally Posted by jakermac View Post
    Pistons came first.
    I've searched for quite a while. Found some info on stage 2s, but not on the 3s.
    Chris Leone
    1984 318i now 325is
    1988 325is donor
    Nov 2007
    Orlando
    99 M3, 11 GT3RS
    Are those sunbelts legal? "cams must have stock lift"???
    99 M3 STU/ GTS3 Project
    Dec 2005
    utopia
    Quote Originally Posted by NotoriousJJE View Post
    If you are using an S52 , no they are not legal. I'm using an M52 2.5l.
    9.1.4.1.6. Valve lift is limited to .600 inches
    Per spec line of M3 "Engines must use the OEM camshaft lift."
    Chris Leone
    1984 318i now 325is
    1988 325is donor
    Nov 2007
    Orlando
    99 M3, 11 GT3RS
    Nice! I'm jealous! Are you going to have it ready for the May race at daytona? I hope to be there and shake it down with amasa a couple of weeks before.
    Dec 2005
    utopia
    Not the way things are going at the shop. I barely get anytime to work on it. It's always everybody else's crap first. Should have my last project done in about 2 weeks. Then I can work on my stuff. Until something else pops up.
    Chris Leone
    1984 318i now 325is
    1988 325is donor
    Vancouver, B.C., Canada
    '97 M3
    It would be nice if someone would degree these cams and post up the numbers at 0.005Ē and 0.050Ē for the rest of us. Iíve done so for the S52, Elgin regrinds and the Schrick 264/256 cams already.
  1. Sunbelt Stage II Cam Timing - S52
    By foscoe944 in forum Track, Auto-X & Drag Racing sponsored by Bimmerparts.com
    Last Post: 07-08-2012, 08:28 PM
  2. WTB: S52 Schrick or Sunbelt Stage 2 cams.
    By aikimo in forum BMW Parts Wanted sponsored by Bavarian Auto Recycling
    Last Post: 08-03-2009, 02:01 PM
  3. Sunbelt cams install question
    By Toby Larsson in forum Track, Auto-X & Drag Racing sponsored by Bimmerparts.com
    Last Post: 01-19-2009, 11:04 PM
  4. New UUC Stage II Clutch/Fly Setup Questions
    By SKooT1027 in forum 1992 - 1999 M3 (E36)
    Last Post: 09-07-2007, 06:30 PM
  5. Questions on 2nd Stage Cam '84 318i
    By B5Beauty in forum 1983 - 1991 (E30)
    Last Post: 12-10-2003, 01:45 PM
