New - Turner Motorsport Monoball Lower Rear Shock Mount for the E82 and E88 1 Series
The performance side of these mounts is primarily found in the articulation allowed by the bearing, by eliminating the deflection found in the rubber mounts.
This solid monoball design reduces play and increases feel so the performance is felt either on the street or the track with almost zero added NVH.
Rubber mounts in any position of a vehicle are usually designed with comfort and longevity in mind leaving performance as a sacrifice.
The solution from Turner is to offer a rebuildable mount with a Teflon lined bearing for increased durability combined with a blue anodized body and melonite coated bushing sleeves to resist corrosion and maximize ball articulation.
Click HERE for your BMW E8X 135i Turner Motorsport Monoball Lower Rear Shock Mount
Click HERE for your BMW E8X 128i Performance Ultimate LSM Replacement upgrade
