Results 1 to 12 of 12
Thread: Need HELP - very frustrated
    Sep 2016
    Stroudsburg, PA
    2002 325Ci Convertible
    Angry Need HELP - very frustrated
    I have a 2002 325ci with 233,000 miles. I have been fitting misfires for quite some time. I have replace the oil separator, all of the coil packs, MAF and crank sensor. The gas filter was clogged and I was only getting 37 psi on the fuel pump. I cleaned the filter and the pressure went up to 49 psi. I picked up the car from the mechanic last year and the car was running great. When I started the car this morning the check engine light came on immediately and I could feel the misfire. I drove the car about 3 miles and the check engine light went off and the misfire went away and purred like a kitten.
    I don't know what else to check to stop the misfires. Any ideas would be greatly appreciated. My mechanic is good at what he does but he is GM certified not a foreign car guy.
    BTW - I have spent almost $2000 in the last 6 months trying to get this fixed.
    Jan 2018
    Sachse, TX
    several
    I am not an expert when it comes to these cars by any means. I have only replaced the radiator and a coil so far. Would it be worth it to you to get the car evaluated by a shop who specializes in BMW or possibly a local BMW service department? Are there specific codes that the engine light is throwing? AutoZone and O'Reilly will run a check on their scanner for free. I know many shops charge for most things. Some will help you out if they see a possibility of winning your business.
    Jeremy
    2000 323Ci Titansilber Metallic cabriolet
    Sep 2016
    Stroudsburg, PA
    Thanks Jeremy, Unfortunately there are no BMW mechanics local to me.
    Jan 2018
    Sachse, TX
    several
    Quote Originally Posted by slabadie View Post
    Does your mechanic friend know anyone who may know more than he does? Post the codes that are coming back.
    Jeremy
    Jan 2016
    Ca
    2001 525it
    Normally I would say smoke test the intake manifold for vacuum leaks but in your case you will have to use carb clean on cold start spray around the intake manifold gasket area ect and if the engine idle goes up after spraying a certain area,there is your leak. But the engine should be cold, because as the engine warms up things expand and seal. Also what ever cylinder is misfiring mark and move the coil pack to a different cylinder, clear faults recheck, if it comes back and didn't follow the coil pack move then you would know if is a coil pack. Also look for water in the master cylinder compartment, clogged drain. Just had a e39 hydro lock the engine because of the that and he had an intermittent misfire
    Dec 2013
    Chicagoland area
    EXOTICS
    Had your mechanic thought of replacing the old sparkplugs,
    wth a new set of NGK plugs, to go along with the coil pack replacement?
    Btw,a scan for codes may turn up clues, if only slightly helpful with a genetic scan tool.
    Scan for codes,take note of them,then clear all codes.
    Complete a short drive cycle, then scan for new codes that reappear.
    Sep 2016
    Stroudsburg, PA
    I had just replaced the plugs when he did the coil packs.
    Dec 2013
    Chicagoland area
    EXOTICS
    Ok,
    If possible, perform a scan.
    BMW scan tool/software would be ideal,
    But work with what you have on hand.
    Jan 2015
    Timaru, New Zealand
    Two Z3 Roadsters
    Sounds likes a vacuum leak. Problem is there when the engine is cold and the mixture is running on tables in the ECU (open loop control). Its running lean due to the unmetered air. Once the engine heats up, the ECU switches to closed loop control and uses the O2 sensors to trim the mixture rich to balance the unmetered air of the vacuum leak and the problem goes away.
    Look at the large rubber tubes from the air box to the throttle body. By the throttle body there is a branch off the main tube to the idle control valve (ICV), this branch is a common spot for a hole.
    Alternatively, get your mechanic to smoke test the inlet system to see where the problem is.
    1999 2.8L Z3 Roadster,
    2000 3.0L Z3 Roadster,
    Jul 2011
    Arlington, VA
    2018 BMW M240i
    Try www.bimrs.org to see if there’s a shop that specializes in bimmers in your area.
    Sep 2016
    Stroudsburg, PA
    Thanks for the link Marco. Unfortunately there is nobody close.
    Thanks Muzz258 for the suggestion on vacuum leak. I check that out over the weekend.
    Dec 2013
    Chicagoland area
    EXOTICS
    For future reference try BMWCCA.
    Join a local chapter,that way you'll have conact with BMW enthusiasts,
    who would have knowledge of any local BMW specialist mechanics.
  1. Need Help VERY Erratic Idle
    By e30AlaskanOwned in forum 1983 - 1991 (E30)
    Last Post: 07-19-2017, 11:29 PM
  2. Anyone close by? I need help (VERY unfortunate incident)
    By Jerrysull2 in forum Car Detailing and Show & Shine Prep sponsored by Autogeek.net
    Last Post: 06-08-2007, 05:15 PM
  3. I need help very fast on tire size!!!!!
    By Vin328IX in forum 1992 - 1999 M3 (E36)
    Last Post: 04-14-2005, 05:44 PM
  4. e36 problems ... please help.. very frustrated
    By defex in forum 1991 - 1999 (E36)
    Last Post: 12-17-2004, 01:33 PM
  5. Need HELP...very strange...
    By ACS ///M in forum 1996 - 2002 Z3 (E36/7, E36/8)
    Last Post: 02-07-2004, 08:26 PM
