Results 1 to 17 of 17
Thread: 95 m3 full bolt ons dyno question
    Feb 2013
    Denver, CO
    95 Daytona Violet m3
    So my car has a Riot racing BBTB, RR cams, injectors, shorty headers, CAI with the 3.5inch upgrade, and a chip. I recently got it dynoed and on the last run it got to 235rwhp. My question though is it has this weird dip at around 5k rpm, anyone have any idea as to what that could be? Friend thinks it could be coils since my motor has about 199k miles or the dyno wasnt reading right since we couldnt get a solid torque reading.
    2002 E46 m3 Topaz Blue
    Jun 2012
    PR
    '93 e36 race car
    Quote Originally Posted by Mastershake01 View Post
    Vanos activation?
    Jun 2005
    New England
    F90 M5; E36 M3 Turbo
    It’s too bad the dyno operator did not know how to hook up the tach to give the power curve in rpm and thus also a torque curve. Dyno seems slightly low but is is a 23 year old motor.
    Feb 2013
    Denver, CO
    thats what I was thinking, Ive been thinking about taking it to another shop to have it ran again because this is the fastest e36 m3 ive ever driven, feels alot stronger than my 97 I use to have but I dont know.
    Jun 2005
    New England
    With rpm you would be able to compare better. Vanos does change from advance to retard around 5000 rpm for top end power and a little blip there is not uncommon. If vanos was not working there would be no low to midrange advance and the power curve would feel flat and then take off up top.
    Many 20+ year old cars need some work so it’s possible your car needs some sorting. Cam sensor and knock sensor harnesses can deteriorate with age and a lot of other little things can go wrong.
    Mar 2012
    Renton, Wa
    98 m3
    That dip at 95mph isn’t 5k.
    Your tune doesn’t have vanos setup properly.
    1989 535i - sold
    1999 M3 Tiag/Dove - sold
    Jun 2005
    New England
    A 95 M3 has 3.15 diff and 235/40/17 tires and does 93 mph at 5000 rpm in 4th, but maybe the car does not have stock size tires or diff ratio.
    NY
    skateboard
    Looks like you need an RK tunes tune.
    ― George Orwell
    Mar 2012
    Renton, Wa
    98 m3
    Just looking at the graph im going to say its what happens when vanos switch point is wrong. Usually happens at 4.5k. Maybe the tune bumped the switch up a bit but not enough and thats why its closer to 5k.
    1989 535i - sold
    Apr 2008
    Riverside, CA
    98' M3/4/5, 85' 944
    op like teh screen name
    Apr 2016
    Irvine, CA
    99 328is, 03 X5
    I suspect elevation playing a huge hand in that.
    Mar 2012
    Renton, Wa
    98 m3
    Quote Originally Posted by Team Neverlift View Post
    Its sae, so nope.
    1989 535i - sold
    Feb 2013
    Denver, CO
    Quote Originally Posted by tvcasualty View Post
    Thanks. Im possibly thinking the tune since Im sure the RR Cams run more aggressive than the most of the other off the shelf cams and there is no dedicated tune for them. Does anyone know a good BMW OBD1 tuner in Denver or the surrounding area? Thanks everyone for the replies.
    Vancouver, BC Ca
    1993 325is
    Remote tune from Vollosso!!! He did my built OBD1 3.0 to the tune of 270whp and 240 ft/lbs.
    Jun 2005
    New England
    Probably a Schrick 264/256 tune would work for the RR regrinds. Remote tuning is fine as long as the tuner is responsive and willing to work with you on revisions if you need one. Most 20+ year old cars need some maintenance. Owners often mod them without sorting them out first. Sometimes the mods are not installed right. Then the tuner gets blamed for everything and has to spend hours trying to help the owner figure out and fix the non tuning problems with the car. Can the OP help by data logging or at least getting proper dyno run with rpm hook up and run files?
    Feb 2013
    Denver, CO
    I have an appointment set up at a reputable tuner here that is going to custom tune a Miller War Chip, I will update in a few weeks when that is done.
    Jun 2005
    New England
    Hopefully the shop is familiar with the Miller system. If not, you can pay for its education. Let us know the results.
  1. 95 m3 control arms on 328 questions
    By dwvcfii in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 04-19-2011, 09:35 PM
  2. 98 E36 M3 Full Bolt on + Cams VS. Evo 7 or 8
    By omak81 in forum Kill Stories
    Last Post: 10-09-2010, 05:37 AM
  3. '95 M3 vs. full bolt on Mk4 GTI
    By malter in forum Kill Stories
    Last Post: 07-26-2006, 12:46 PM
  4. FS:1997 M3 Sedan(full bolt on)
    By mr_green in forum BMW Cars For Sale / Wanted
    Last Post: 10-13-2004, 06:50 PM
  5. Are SS resonators for US 95 M3 direct bolt on?
    By vehdyn in forum 1992 - 1999 M3 (E36)
    Last Post: 12-11-2002, 08:30 PM
