Results 1 to 2 of 2
Thread: 1988 735il SLS Leak
    Mar 2018
    Austin, Tx
    1988 BMW 735IL
    1988 735il SLS Leak
    Howdy! I recently purchased a 1988 735il that has a leak on the rear passenger side LAD hydraulic line, it looks like it's mostly leaking from the reservoir, however there is power steering residue coating on the entire line. I'm including a picture in this post so it can be seen, I'm not too educated on this matter however I've done a little research and would love an opinion on how to fix this issue. I don't believe the shocks are leaking, it seems like this specific line as well as the valve underneath (which appears to have experienced O-ring failure) are the problem areas. Would this be as simple as O-ring replacement? The power steering reservoir appears to be slightly low, i've also noticed a lot of residue from the bottom of the reservoir as well as a small leak. Driving the car is obviously extremely bumpy and bouncy, but from further examination it looks like the rear passenger side is the only source of the leak happening from the SLS. I'm not noticing too much discomfort while driving from the rear driver shock, and when looking a the same area it appears to not be leaking. Other than this issue the car is in very good condition, with only 136k miles.
    http://photobucket.com/gallery/http:...rt=3&o=2&ref=1
    Jan 2005
    Japan
    11/88 E32 750iL+98 E36M3
    Post question for the E32 in the E32 forum.
    These hoses can be recrimped or are still available from the dealer. See realoem.
    I will move it to the E32 forum.
  1. 1988 735il - Nice Running Project
    By R2dmax in forum 7 series
    Last Post: 08-04-2009, 06:14 AM
  2. '88 735iL Antifreeze leaks & Overheating
    By allthingscnsdrd in forum 1995 - 2001 (E38)
    Last Post: 01-17-2009, 09:39 PM
  3. 1988 735il
    By dhawthorne15 in forum 1988 - 1994 (E32)
    Last Post: 12-12-2008, 10:56 PM
  4. 1988 735il parting out
    By rbowenoc in forum Whole Parts Cars
    Last Post: 05-29-2007, 01:03 AM
  5. Problems with my 1988 735iL
    By DRickerson in forum 1988 - 1994 (E32)
    Last Post: 01-24-2007, 01:09 AM
