Page 8 of 14 FirstFirst 1234567891011121314 LastLast
Results 176 to 200 of 341
Thread: 2018 LSX into E36 build - 1998 328I
  1. #176
    Mar 2004
    USA
    96 328is 6.0L
    Quote Originally Posted by RulyLSX View Post
    Why does it just creep forward? I would think that with one still turning that it would just spin the single one? Is it a speed sensor thing or a differential thing?
    Eventhough you have LSD diff, it still doesn't have nearly enough locking power to move 3000+lb car when the other side has zero resistance. So all it can do is slip the clutches while giving tiny bit of motion.
    When looking at your video it reminded exactly what I had and filmed, but on passanger side. I wanted to say I had this happen to me few months ago, but looking at the date of my post it was almost a year ago https://www.bimmerforums.com/forum/s...7#post29845457
  2. #177
    Mar 2018
    Arizona
    1998 328I
    Quote Originally Posted by octanematty View Post
    Hey rusty, long time lurker here, definitely an inspirational build given how quickly you sorted the swap out.
    Are you going for a 210mm diff? Considered a ford8.8 swap instead? Custom Axles aren’t cheap but long term it will probably be cheaper and lighter
    Thank you man, comments and feedback like that make the build all that much better! Especially considering I too was a lurker for a while before my build!
    I am going 210mm, i sourced and have a EVO e36 210mm diff and subframe on the way, will be running that along with all poly bushings, hoping to get that next week and hope to have her back up and running before the end of oct.
    The plan will be
    Drop rear end
    remove bushings from doner m3 evo rear end
    have parts sent off to be sand blasted/powdercoated
    install new bushings
    install new rear end
    SEND IT
    Quote Originally Posted by bimerok View Post
    LOL i do remember that video, what did you end up doing after that? 210mm or replace the axles?
    Quote Originally Posted by Tim Mc View Post
    I would expect you are relying on the limited slip to provide forward movement...depending on its 'break away' may not be enough to drive the car. On Subaru's if you break an axle, you lock the center diff and let the car act as front wheel drive.
    ya that makes sense, i knew the sticky tires would cause problems, Honestly I was expecting at LEAST a few pases before that happened, not on the first launch lol . oh well
  3. #178
    Mar 2004
    USA
    96 328is 6.0L
    I just replaced axel and that's all.
  4. #179
    Mar 2018
    Arizona
    1998 328I
    Well in order to not go through this again I'm going 210mm, just sent out my axles to get done by DSS as well, i don't want to worry about it.
    On a more positive note I just got a nice box in the mail today
  5. #180
    Dec 2007
    SF bay area
    1998 M3 / 2000 S2000
    Not if you break an axel with wanganstyle diff.
    Minus one axel you can still drive home
    Wanganstyle Powertrain
    http://www.wanganstyle.com/
    S54B32 E36 M3 DTA S100 Sedan Street car full swap:
    http://forums.bimmerforums.com/forum....php?t=1437471
  6. #181
    Houston, TX
    1997 M3 Sedan
    PT4788?
    Sent from my iPhone using Tapatalk Pro
  7. #182
    Mar 2004
    USA
    96 328is 6.0L
    Quote Originally Posted by wanganstyle View Post
    with that kind of lock up you'll be breaking axels just by making u-turns
  8. #183
    Dec 2007
    SF bay area
    What about no?
    idiots on the interweb spouting free data gets free shitty results; if one keeps driving diffs made from garbage skills it might as well be a welded.
    A proper diff does not need any preload to drive home on one axel; it just needs enough LOCK.
    I drove home after breaking an axel on my 0 preload circuit unit; 6 miles up and down hwy 9 to cupertino to a friends garage to swap in a new axel.
    0 preload means = diff turns like open diff; so if you break axels with an open diff making u turns you got some serious problems.
    For any who actually have the balls to drive a welded; axels dont break often with a welded either unless power level is idiot for application parts;
  9. #184
    Dec 2007
    SF bay area
    Duplicate thread
  10. #185
    Mar 2018
    Arizona
    1998 328I
    Quote Originally Posted by BigL350 View Post
    PT4788?
    it's a PT 7675
  11. #186
    Houston, TX
    1997 M3 Sedan
    Ah, the compressor cover threw me off. In my pondering about one day doing a single turbo setup I guessed that the PT7675 was the best bang for the size that might fit in our already tight engine compartment. Looking forward to the rest of your project.
  12. #187
    Mar 2018
    Arizona
    1998 328I
    Yeah I have the billet model which was a little pricier but supposedly makes more power.... Either way it's rated up to 1200hp so i have plenty of room to grow!
    Plan is to have it done before the year is over so stay tuned!
  13. #188
    Mar 2018
    Arizona
    1998 328I
    Pulled the axles off the hub today... boy that was fun, had to call around to hunt down a 36mm 12point socket in order to remove the axle nut, used an impact wrench to take it off then hammered out the axle from the hub.
    M3 axles are on route to DSS to get the 1000hp treatment they do... these things better hold up
  14. #189
    Apr 2012
    Stuttgart, Germany
    1997 M3 / 5.3
    Strengthening the axles moves the failure point to the next weakest link...and so it begins! ;-)
  15. #190
    Mar 2018
    Arizona
    1998 328I
    so it begins indeed lol,
    210mm diff and subframe from a euro m3 getting boxed up and sent across the pond to me, hope to get it next week!
  16. #191
    Jul 2013
    FL Gulf Coast
    E36 - 1998 328iS - LS2
    ... a euro m3 getting boxed up and sent across the pond to me, hope to get it next week!
    Whats the ratio? And what other ratios are easily available should you want to swap?
  17. #192
    Mar 2018
    Arizona
    1998 328I
    Quote Originally Posted by TipsyMcStagger View Post
    It's the stock ratio for the euro evo m3 which is 3.23, all the ratios you would normally expect are avail if needed....going to see how this ratio works with the upcoming turbo build and go from there before swapping anything out, if that doesn't work i'll swap it out for the trusted 3.91 like i currently have.
  18. #193
    Mar 2018
    Arizona
    1998 328I
    On version 2.0 of the car build lol i will also be going hydroboost so i can remove the annoying brake booster that gets in the way when trying to remove my valve covers.
    Just go pictures of the setup assembled and will bolt right where the brake booster is, i'll take detailed pics of the install process in case anyone out there decides on it in the future.
    Hydroboost kit is from http://www.custompowerbrake.com, i emailed him and although it's not on his website he has done it for e36 before and all that's needed is for you to send him your brake pedal assembly so he can modify it to work with the kit below
  19. #194
    Jul 2013
    FL Gulf Coast
    Hydroboost kit is from www.custompowerbrake.com, i emailed him and although it's not on his website he has done it for e36 before and all that's needed is for you to send him your brake pedal assembly so he can modify it to work with the kit below...
    That link is no good. Did you get it from Elliot? If so, back when I was piecing mine together, I sent him a stock E36 eBay booster and a set of eBay E36 pedals to use for mock-up.
    As far as I know, until now, mine was the only E36 setup he'd done. Glad to see another.
    Elliot is a good guy.
  20. #195
    Mar 2018
    Arizona
    1998 328I
    link fixed, yup it's elliot's site! Got ahold of him after you referring him to me. Thanks again!
    I only had to send him my brake assembly so i'm guessing he's using the mock up plans from your build haha.
    DO you have pictures of how you set yours up? Was is pretty straightforward?
  21. #196
    Dec 2007
    SF bay area
    Across the lake you mean all the way from Illinois
  22. #197
    Jul 2013
    FL Gulf Coast
    Glad to help. I'm happy to see Elliot get some more E36 business. I think most of his clientele is the American muscle car crowd.
    I told him he could keep the E36 booster. I'm pretty sure he said he was going to make some notes or a jig at the time he did mine so he could duplicate it in the future.
    Insofar as hooking it up, the bolt-in is pretty straight forward. And the brake lines are no different than with the vacuum booster, obviously.
    I have some info starting here (and continuing in some posts after that) on making the hydraulic hoses. I thought about using JIC adapter fittings but I wanted to try to make it look more stockish, so I found an awesome custom hose shop nearby and used tube nuts with o-rings instead of JIC hose ends and fittings.
    For the return back to the reservoir, it's not uncommon to tee the return line from the hydroboost to the existing power steering return line. But I've read of some people having problems when doing so.
    I'm using LS2/GTO components so this reservoir, which is an aluminum duplicate of the OE plastic reservoir, might not work with your bracketry. But there are several aftermarket aluminum reservoirs available, and some already have two return ports;
    I bought an aluminum replacement power steering reservoir, drilled a hole and had an additional o-ring bung tig-welded on. This way, the hydroboost will return directly to the reservoir.
    I'm not sure if I have any pics of the reservoir in my thread so:
    Here's a pic of the reservoir out of the box.
    And here's one with the additional bung welded in
  23. #198
    Jul 2013
    FL Gulf Coast
    By the way, if you've never seen this diagram, it's pretty much all you need to figure out your plumbing.
    Again, the diagram depicts a return tee. But I eliminated the tee, instead using two direct return lines to the reservoir:
  24. #199
    Mar 2004
    USA
    96 328is 6.0L
    Not sure if this ever going to see a road course track, if so, I'd think twice about going hydroboost. The steering fluid is around boiling condition at the track, adding a booster into the loop will be even more cooking fun.
  25. #200
    Jul 2013
    FL Gulf Coast
    Wouldn't running a larger steering fluid cooler address this?
  1. A Novice's Basic E36 Build ("Hans" the 1998 BMW 328is)
    By Spiffybeefcake in forum BMW Rides & Events
    Last Post: 11-12-2017, 06:54 PM
  2. e36 M52 1998 328i Intake Manifold with fuel rail. - No Longer Available
    By Skatebline in forum Engines, Performance Parts & Software
    Last Post: 05-04-2016, 12:20 PM
  3. E36 FS: BMWCCA SPEC E36 Build - 1997 328is (South Carolina)
    By Hellrot99M3 in forum Race Cars & Track Parts
    Last Post: 03-20-2012, 12:58 PM
  4. E36 FS: BMWCCA SPEC E36 Build - 1997 328is (South Carolina)
    By Hellrot99M3 in forum 3 series & Z Series
    Last Post: 03-04-2012, 05:55 AM
  5. CA legal LSx into E36 possible?
    By BlackbirdFabwrx in forum Engine Conversions
    Last Post: 02-26-2011, 04:15 AM
