Page 8 of 8 FirstFirst 12345678
Results 176 to 177 of 177
Thread: 2018 LSX into E36 build - 1998 328I
  1. #176
    Mar 2004
    USA
    96 328is 6.0L
    Quote Originally Posted by RulyLSX View Post
    Why does it just creep forward? I would think that with one still turning that it would just spin the single one? Is it a speed sensor thing or a differential thing?
    Eventhough you have LSD diff, it still doesn't have nearly enough locking power to move 3000+lb car when the other side has zero resistance. So all it can do is slip the clutches while giving tiny bit of motion.
    When looking at your video it reminded exactly what I had and filmed, but on passanger side. I wanted to say I had this happen to me few months ago, but looking at the date of my post it was almost a year ago https://www.bimmerforums.com/forum/s...7#post29845457
  2. #177
    Mar 2018
    Arizona
    1998 328I
    Quote Originally Posted by octanematty View Post
    Hey rusty, long time lurker here, definitely an inspirational build given how quickly you sorted the swap out.
    Are you going for a 210mm diff? Considered a ford8.8 swap instead? Custom Axles aren’t cheap but long term it will probably be cheaper and lighter
    Thank you man, comments and feedback like that make the build all that much better! Especially considering I too was a lurker for a while before my build!
    I am going 210mm, i sourced and have a EVO e36 210mm diff and subframe on the way, will be running that along with all poly bushings, hoping to get that next week and hope to have her back up and running before the end of oct.
    The plan will be
    Drop rear end
    remove bushings from doner m3 evo rear end
    have parts sent off to be sand blasted/powdercoated
    install new bushings
    install new rear end
    SEND IT
    Quote Originally Posted by bimerok View Post
    LOL i do remember that video, what did you end up doing after that? 210mm or replace the axles?
    Quote Originally Posted by Tim Mc View Post
    I would expect you are relying on the limited slip to provide forward movement...depending on its 'break away' may not be enough to drive the car. On Subaru's if you break an axle, you lock the center diff and let the car act as front wheel drive.
    ya that makes sense, i knew the sticky tires would cause problems, Honestly I was expecting at LEAST a few pases before that happened, not on the first launch lol . oh well
  1. A Novice's Basic E36 Build ("Hans" the 1998 BMW 328is)
    By Spiffybeefcake in forum BMW Rides & Events
    Last Post: 11-12-2017, 06:54 PM
  2. e36 M52 1998 328i Intake Manifold with fuel rail. - No Longer Available
    By Skatebline in forum Engines, Performance Parts & Software
    Last Post: 05-04-2016, 12:20 PM
  3. E36 FS: BMWCCA SPEC E36 Build - 1997 328is (South Carolina)
    By Hellrot99M3 in forum Race Cars & Track Parts
    Last Post: 03-20-2012, 12:58 PM
  4. E36 FS: BMWCCA SPEC E36 Build - 1997 328is (South Carolina)
    By Hellrot99M3 in forum 3 series & Z Series
    Last Post: 03-04-2012, 05:55 AM
  5. CA legal LSx into E36 possible?
    By BlackbirdFabwrx in forum Engine Conversions
    Last Post: 02-26-2011, 04:15 AM
