Page 1 of 14 1234567891011 ... LastLast
Results 1 to 25 of 341
Thread: 2018 LSX into E36 build - 1998 328I
    Mar 2018
    Arizona
    1998 328I
    2018 - LS1 into E36 build - 1998 328I
    Please add me on IG @ls1_e36 to learn more about the build!!!!!!!!!!
    Hello everyone,
    Newish to the boards and would like to create a thread for my build, always wanted to have a project car and once I saw the kits and videos of LS1 into E36 I knew I just had to restore and build one I have had several Camaro's in the past and am familiar with domestic muscle cars, this swap was even more special to me as I plan to give this car to my son once he's of driving age.. I will make updates as I go about my build but for now here's all the parts I have bought and plan to use on my build
    About a month ago I purchased a silver 1998 328i and have been accumulating parts for my build, My plan is to rip out the old engine, get a full paint job in Lemans Blue and put the LS1 in, my plan is to get as much done as I would want to do and try to do things the best way possible.
    Engine
    • 1998 LS1 out of a Camaro - Full drop out from Hawks motorsports
    • Texas Speed Magic stick 4 Cam, valve springs, push rods and any other random mods needed to make the cam work
    • LS6 intake manifold
    • LS6 Valley cover with internal pcv
    • New LS7 Lifters and trays
    • All new gaskets for engine
    • High performance GM oil pump
    • LS2 Timing chain
    • New injectors
    Drive line
    • T-56 Magnum
    • LS7 clutch kit with steel flywheel
    • GM slave
    • BMW OEM master
    • Driveshaft - will be custom made by a local shop, still undecided if I should go steel or aluminum
    • 3.91 LSD differential
    Misc
    • Replaced the crappy aftermarket stereo with an M CD43 business radio and bluetooth module
    • Replaced various broken pieces such as broken vents, random trim pieces etc
    • ICS coil over kit
    • replaced suspension parts(Control arms, stabilizer bar links, tie rods and all bushings associates)
    • Wiring specialties pro harness
    Apr 2012
    Stuttgart, Germany
    1997 M3 / 5.3
    Ruly: Thanks for posting! Your intentions are not unlike ours...hope you post images - worth thousand words and gets more attention! Good luck and looking forward to your progress.
    Mar 2018
    Arizona
    1998 328I
    Pic of car how it looked the day I bought it
    Mar 2018
    Arizona
    1998 328I
    Engine when it first arrived
    Picture of engine tear down
    Start of engine removal
    Removed the headers and noticed these AWESOME welds.....
    Engine is fully out and on it's way to the paint shop!! Whole car including engine bay will be painted lemans blue
    Mar 2018
    Arizona
    1998 328I
    -Noticed guys were running the corvette fpr so i purchased that
    -ordered a new mishimoto aluminum radiator
    -ordered an electrical fan from becool.com
    -purchased a set of new wheels, will be running Apex ARC-8, 17x9.0 in front and 17x9.5 in the back
    -purchased a set of new tires, will be running BFG comp 2's 245/40/17 in front and 255/40/17 in the back
    -purchase an apex wheel stud kit
    Royalest of Oaks
    Mazda 3
    FYI - Imgur is one of those that doesn't work well with hotlinking/embedding images (similar to Photobucket). Flickr still works, and a few others...
    Mar 2018
    Arizona
    1998 328I
    Quote Originally Posted by LSxDreamer View Post
    dammit, i'll get em changed up. Thanks!
    Mar 2018
    Arizona
    1998 328I
    changed host to cubeupload
    Mar 2018
    Arizona
    1998 328I
    Updates
    Stopped by the paint shop and the car's body work is completed, will be hitting the paint booth on Monday
    Mar 2018
    Arizona
    1998 328I
    Block has been dropped off at a local machine shop, they will be doing the following
    • LS CR807 KING
    • LS MAIN bearing king BM5013
    • Oil plug and bar bell plus
    • Cam thurst plate
    • Front and rear covers and seals
    • total seal rings
    • cam bearings
    • torque and resize rods
    • APR rod bolts
    • torque plate hone with plateau finish
    • square deck block
    • serdi valve job
    • vat wash
    • micro fine polish crank shaft
    Apr 2012
    Stuttgart, Germany
    1997 M3 / 5.3
    Moving right along!
    I went with stock piston rings, file fit...which was expensive. Likely more than your Total Seal - better solution!
    Jun 2004
    Chicago
    99' M3 5.7L
    Looks like a nice project! FYI given your rear tire size you may experience clearance issues in the rear. If it's not too late ask the body shop to roll your fenders before applying paint. Good luck with the build!
    Mar 2018
    Arizona
    1998 328I
    Quote Originally Posted by lovnbmws View Post
    Thank you for the heads up, I actually had a shop roll them heavily just before it went to the paint shop. I haven't test fitted yet though but I'm hoping it will be fine
    Aug 2008
    fairfax,va
    E36 M3 TV/ E36 M3 CB
    Oh my god this is gonna be so epic, youre going all in! Can't wait to see this done, this is going to be one solid car.
    Mar 2018
    Arizona
    1998 328I
    Quote Originally Posted by alwaysbored786 View Post
    Thanks man, The wait is killing me but I am stoked about it all!!
    Mar 2018
    Arizona
    1998 328I
    Stopped by the paint shop and they have it all painted, next step is wet sanding/polish...all the after paint work
    Also had them paint my LS6 intake the same color.... figured if I hate it I could switch to a FAST system lol
    Royalest of Oaks
    Mazda 3
    Looking good!
    Apr 2012
    Stuttgart, Germany
    1997 M3 / 5.3
    Blue engine bay looks better than the exterior of my M3!
    Nice.
    Mar 2018
    Arizona
    1998 328I
    Stopped by the paintshop today to drop off some random interior retainers they needed that broke off during the tear down, also got to take home some of the pieces they painted. Here is the intake! NOTE: it's super dusty and didn't try to dust it off for the pics
    and other random one i took of the car
    Mar 2018
    Arizona
    1998 328I
    Car is now home from the paint shop, stil needs a few trim pieces which are on the way
    Mar 2004
    USA
    96 328is 6.0L
    Are the injector holes painted too? If so might be a good idea to clean them off the paint.
    Mar 2018
    Arizona
    1998 328I
    Quote Originally Posted by bimerok View Post
    Yes they are, they did a good job of masking certain things and not so great others..... Thank you for the heads up. I'll def do that.
    Mar 2018
    Arizona
    1998 328I
    Was excited to get the car back and test fitted a front wheel on the car, Went on just fine but as I tried to roll the car I noticed the inner rim is rubbing against my coil over :/
    Mar 2018
    Arizona
    1998 328I
    Finally got the engine back from the machine shop last week and started working on the car Friday, I pretty much spent all Friday/Sat/Sun/Monday working on it..... I had a buddy come over for an hour to help me with some stuff but overall I did all the work myself, my other jack became my best buddy as it helped me get the engine in haha.
    Here's what I got done so far,
    -Fuel filter installed and lines made, I copied Bimerok's setup as best I could, Thanks Bimerok for documenting your build, I have went through your giant thread multiple times. After the filter I have a 12" hard line in place then a soft line, The soft line is not long enough though so i need to figure that out.
    -Engine/tranny are in, getting it in was super easy and took me maybe 15-20 mins alone, I took it out only another time and then back in again after making some modifications to the t56 magnum
    -Headers, holy crap what a pain in the ass the driver side was, Being exhausted from working on the car all weekend and having a few beers in me I tried putting the header without removing the shift linkage... about 2 hours later after wrestling with the driver side header I finally realized I had to take the linkage apart...... after i did that the header slid in pretty easily.
    I tried to take as many pictures as possible but it was a hot weekend in Arizona, I was all alone and my main focus was simply getting r done. I'll try to document more as I make more progress.
    Pic of engine fresh from machine shop
    Going in
    After the engine was in for the first time. NOTE: The stock ac compressor will NOT work, it rest directly on the side and it scratched up my paint!!!! I was more pissed off because I had to grind off a piece of the stock bracket for the compressor in order for it to work with the mount lol. Wasted about an hour grinding the bracket including a trip to home depot for a grinder.... I have an order already in to use another bracket and a sanden compressor which is smaller.
    another shot of it in the car
    Header and intake installed
    Clearance
    Fuel stuff
    Mar 2018
    Arizona
    1998 328I
    OH forgot to mention, I also installed a 3.90 diff and ICS suspension
  1. A Novice's Basic E36 Build ("Hans" the 1998 BMW 328is)
    By Spiffybeefcake in forum BMW Rides & Events
    Last Post: 11-12-2017, 06:54 PM
  2. e36 M52 1998 328i Intake Manifold with fuel rail. - No Longer Available
    By Skatebline in forum Engines, Performance Parts & Software
    Last Post: 05-04-2016, 12:20 PM
  3. E36 FS: BMWCCA SPEC E36 Build - 1997 328is (South Carolina)
    By Hellrot99M3 in forum Race Cars & Track Parts
    Last Post: 03-20-2012, 12:58 PM
  4. E36 FS: BMWCCA SPEC E36 Build - 1997 328is (South Carolina)
    By Hellrot99M3 in forum 3 series & Z Series
    Last Post: 03-04-2012, 05:55 AM
  5. CA legal LSx into E36 possible?
    By BlackbirdFabwrx in forum Engine Conversions
    Last Post: 02-26-2011, 04:15 AM
