Page 10 of 10 FirstFirst 12345678910
Results 226 to 237 of 237
Thread: 2018 LSX into E36 build - 1998 328I
  1. #226
    Oct 2018
    Carlos MN
    1999 E36 LS1 1998 TJ LS6
    Just FYI. The older Ford Rangers that have a manual trans have a nice clutch resesvior. I used them on a couple projects. Like $5 at the local salvage.
  2. #227
    Mar 2004
    USA
    96 328is 6.0L
    From doing some research the spring that you removed is both assistant and resistance spring. It provides a bit of resistance at the initial pedal travel and then past about half way it turns into assistance spring. It is best seen when the clutch pedal has no hydrolics connected.
    But if it made your pedal feel good, then its a win.
  3. #228
    Mar 2018
    Arizona
    1998 328I
    Quote Originally Posted by bimerok View Post
    Ok that makes sense due to that pivot thing it's on, I'm gonna run without it a for a while, so far i'm loving the consistent feeling it has through the whole pedal travel, it's just a tad bit firmer too which I like
  4. #229
    Mar 2018
    Arizona
    1998 328I
    Today I installed a new clutch pedal, this was in part due to my frustration with my clutch issues lol. It's a mason engineering metal clutch pedal to replace the plastic one. It's touted as a "short throw" clutch pedal and it was expensive but reviews I had read were all saying it was totally worth it, best mod ever etc etc ... The feel of the clutch is the same as the plastic one to be honest, it does feel a bit shorter and the alignment is now just level with the brake pedal
    Here is a pic of side by side of the two, link to the details of the pedal here> https://www.masonengineering.net/pro...php?bmw_id=e36
    The cool thing about this all is that I am now a pro at removing/installing the clutch pedal assembly lol, i have done it 4 times now and to install this new metal pedal it took me about 15-20 mins from start to finish
    Quote Originally Posted by wbrentr View Post
    I dropped my pedals to install a new clutch MC. I ran into something similar as you did. I swear I was missing a part for the clutch spring, so I just removed it entirely hoping it wouldn't change much. I'm glad to hear it makes it better!
    haha glad I am not alone!!! Have you been running without it?
  5. #230
    Mar 2018
    Arizona
    1998 328I
    Not much to update, right now the thing that is bothering me as I'm driving the car more is the amount of "slop" in the steering, I did find another thread on bimmerforums that some have had slop using the flaming river setup as I have so i'm going to try to figure that out.
    I had my wife move the steering wheel back and forth in the "slop" area looks like everything moves as it should but the slop is in the steering wheel rack?
    Here is the video of the actual wheel slop
    Additionally here is what it looks like at the rack side
    Not sure if I should replace the steering shaft, adjust it or the rack/tie rods. I'm thinking since it's moving all the way to the rack that it's an issue with the rack though, any advice is appreciated.
  6. #231
    Apr 2012
    Florida
    2008 M5
    I've noticed a bit of slop using Flaming River setup on ours...still unsure if it is much to worry about or what it is caused by. Our slop is nothing like what you are showing in your video though. I almost wonder if the -3 degree camber is causal for our M3...
    Although you could take the opportunity to install a quicker Z3 rack like we did...
  7. #232
    Mar 2018
    Arizona
    1998 328I
    Quote Originally Posted by Tim Mc View Post
    Yeah looks like im gonna get a new rack and replace everything with it will look into the z3 one thanks!
  8. #233
    Mar 2018
    Arizona
    1998 328I
    Updates for this week
    Installed e46 330i front calipers/rotors along with my apex stud conversion kit that has been sitting on my shelve for a while. Took the car out for a spin and noticed the same as others have noticed when doing the upgrade, it has increased the pedal travel for the brakes, feels a bit weird.
    I do have an m3 brake master that i was going to swap in, after removing the NON m brake master i realized that the new one isn't going to fit with my lines..... My lines to brake master are M10 and M12... The m3 one are both m10, DOH!
    I found a thread were a guy recommended some pipe that has m12 on one end and m10 on the other, placed an order for that.... for now the car will be "down" until this line comes in and i can get my brakes working again lol.
    The other thing I have been trying out is to install a water temp gauge onto my stock cluster, I used my prosport water temp gauge that i bought a while back and my old NON m gauge cluster to cut up lol. So far it fits well!!!
  9. #234
    Houston, TX
    1997 M3 Sedan
    The gauge installation looks great.
    Sent from my iPhone using Tapatalk Pro
  10. #235
    Mar 2018
    Arizona
    1998 328I
    Quote Originally Posted by BigL350 View Post
    Thank you! it's coming out better than expected, i did test it out already and everything works!!! Since I confirmed it works the next step is cutting up my m3 gauge cluster and leaving it on permanetly. IT's going to be nice knowing the actual temps
  11. #236
    Mar 2018
    Arizona
    1998 328I
    This weekend I took the car out to the track again after the 210mm diff swap, made a total of 4 passes, first two passes my clutch was sticking to the floor on shifts, I found out that with my violent clutch stomps the mickey mouse clutch stop i had made from home depot elevator bolt and the metal clutch was causing the "stuck" i would push the clutch in so hard that it would rub up against the metal clutch stop and cause it not to come up.
    After removing the clutch stop the pedal would come back to normal.
    The last two runs were nearly identical, 12.8 time, 2.0 60ft and 110mph trap speed, I am still spinning a lil off the line. I am clutch dumping at 4,000 with the launch control and tires were at 18psi. Time between runs was taking too long so I called it at night and went home. I'll be back out next week and will try launching a lil lower in the rpm range to see if i can improve my 60ft.
    Looks like going from 3.91 ratio to 3.23 on the diff caused me about 6mph at the drag strip
    anywho, here's a vid of the run.
  12. #237
    Mar 2018
    Arizona
    1998 328I
    Not an update to my car but I did have the pleasure of meeting another local guy that has an LS e36!!! Met him through these forums and helped him install my old 3.91 LSD diff into his ride! Let alone the fact that I finally got to see another LS E36 in person other than my own but this one was actually the first e36 built by vorshlag with AC!!! I had seen their build thread of this car a few times so it was really cool to see it in person.
    I loved how quiet it was compared to mine at idle, such a sweet deep rumble, if i wasn't going turbo i would go with his same setup!
    More than anything it was fun wrenching with someone else, made stuff a hell of a lot easier and look forward to meeting up with Brian again!
  1. A Novice's Basic E36 Build ("Hans" the 1998 BMW 328is)
    By Spiffybeefcake in forum BMW Rides & Events
    Last Post: 11-12-2017, 07:54 PM
  2. e36 M52 1998 328i Intake Manifold with fuel rail. - No Longer Available
    By Skatebline in forum Engines, Performance Parts & Software
    Last Post: 05-04-2016, 01:20 PM
  3. E36 FS: BMWCCA SPEC E36 Build - 1997 328is (South Carolina)
    By Hellrot99M3 in forum Race Cars & Track Parts
    Last Post: 03-20-2012, 01:58 PM
  4. E36 FS: BMWCCA SPEC E36 Build - 1997 328is (South Carolina)
    By Hellrot99M3 in forum 3 series & Z Series
    Last Post: 03-04-2012, 06:55 AM
  5. CA legal LSx into E36 possible?
    By BlackbirdFabwrx in forum Engine Conversions
    Last Post: 02-26-2011, 05:15 AM
