Results 1 to 22 of 22
Thread: Ihka unit Problem solved?
    Nov 2016
    Burgas city,Bulgaria
    e34 525tds touring 1992
    Hallo to everyone. I had Problem before with the ihka. The Problem is that the air conditioner doesnt want to make Cold. First I checked the System it was okay,after i noticed that the heater valves were dead so I installed e39 heater valves and on the end still no Cold in summer. So i have tried friends unit from working Car and voala it worked! So now I wanted before buying other unit to Check the Old one and... Check this. The Temp Sensor was with a lot of dust A LOT. Could this be the Problem? The Electronic plate and condensators are Looking good.
    Sent from my VTR-L29 using Tapatalk
    Jan 2005
    Japan
    11/88 E32 750iL+98 E36M3
    That is most probably the problem, broken temperature sensor. On my website I have pics of a broken temperature sensor, it had cracks and the temperature was always changing, no matter what the settibg was.
    See fixes>>climate control>> Room temperature thermistor http://twrite.org/shogunnew/topmenu.html
    There is a small motor with a fan that passes cabin air over this thermistor -- so with age the thermistor can become incredibly dirty. Carefully clean it with brake cleaner. Check that the solder joints are not cracked.
    Glass bead NTC G540 thermistor,10k
    RS Stock No. 528-8558
    Manufacturer EPCOS
    Manufacturers Part No. B57540G0103J
    resistance readings are also shown on my website
    Great White North
    various
    Thanks for that Shogun.
    As one of the few here who own and maintain an IHKA system it's great to have your knowledge as a resource here.
    Jan 2005
    Japan
    here more pics of AC control innards, takes some seconds as recovered with wayback machine http://web.archive.org/web/200206091...w.com/ac_cont/
    Nov 2016
    ok so I already changed the Ihka unit and we got cold air as well..but we got 2 more problems .On the left side the air flow is less (maybe 1/2 )than the right side could this be step motor ? and Second the aux fan doesn't work(it wasn't working also before the change) could this be relays -my motor is m51d25 (1992 yr touring)? where they sit and how they look.First I checked the fuses and they looked fine. ...Ahh.. This ihka kills me pls guys help .
    Nov 2016
    Any advice?
    ATX
    Sundry old Grrrrmans
    Test aux fan first: http://www.nmia.com/~dgnrg/page_20.htm
    For airflow problem on left (driver) side, is it half speed from all vents (top, middle, bottom, etc)? Could be an issue in the control unit dial, or if it is one vent then likely stepper motor.
    - Brent
    www.angry-ass.com
    Quote Originally Posted by danespann View Post
    Every E34 needs the same things in the end.
    Jul 2016
    Brandon
    92 M5
    Could be a broken stepper motor mount also. Quite common apparently.
    Jan 2005
    Japan
    If the airflow is different: I had that on my E32, the stepper motor bracket on the driver side was not strong enough anymore and slipped out of position, I fixed it with a zip tie, so far so good. Better fixes here
    http://www.bimmerboard.com/forums/posts/200205/
    or broken flap bracket http://www.bimmernut.com/forum/showt...light=cold+air
    Nov 2016
    Ok so I checked the relay on low speed and it was ok. So at the end I decided to change the resistor I removed it and on it there isnt any sign (from the years) what resistor should i buy?
    Gesendet von meinem VTR-L29 mit Tapatalk
    Nov 2016
    Here it is
    Jan 2005
    Japan
    http://bmwfans.info/parts-catalog/E3...tional_blower/
    repair kit reistor 64121388069 MAGNA or resistor 17401373177 BOSCH or from Beru, here you can buy in Germany https://www.autoteiledirekt.de/oenum...401373177.html
    Nov 2016
    Does matter which one I will choose?
    Nov 2016
    My Fan is the plastic one. Looks like that one (not my pic)
    Jan 2005
    Japan
    all fans have plastic blades, use your car VIN and check on www.realoem.com the part number and buy that part number. The items is under heating/aircon
    Nov 2016
    Ok so Im gonna buy the Bosch resistor, but now one guy told me to put it in a better place where will get enough cool air and wont burn that fast, any advice guys from you?
    Jan 2005
    Japan
    Install it at the same place, no problem for the next 10-15 years, there it get's cooled as the air goes into the radiator, and the place is quite good protected against water.
    Nov 2016
    Thanks a lot Shogun
    Jan 2005
    Japan
    BTW: you could also buy a complete new no name auxiliary fan for less than $100.
    If the present aux fan is already 25 years old, then better buy a complete new one which comes with a new resistor.
    Most old aux fan die when the magnets inside the motor get lose and block the motor, they are glued on and over the years they get lose and block the aux fan, fuse usually blows, but I have seen also some cars where the amp was not enough to immy blow the fuse and the fuse box melted and the wires.
    Nov 2016
    Eh I checked all my fuses are with ampers exactly what they need to be. Now you scared me
    Jan 2005
    Japan
    In such a case, we made a repair guide to open the motor and re-glue the magnets here on the German E34 forum https://forum.e34.de/thread.php?thre...=zusatzluefter
    with date 17.08.2015 I also posted the sizes of the carbon brushes when I disassembled an aux fan made 1988 from my E32 750 just for fun to check all the details. But I bought a new col. aux fan from an online shop, made in Taiwan, works now 3 years without any problem.
    Nov 2016
    I ordered already the original Bosch resistor. I checked the Fan directly with + cabel and it works smoothly so at this moment i wont do anything Else. Thanks a lot Again Shogun
    Greetings from Bulgaria
  1. Ground Control - Problem Solved Now!!!!!!
    By E30 Stu in forum Vendor Comments & Supporting Vendor Info
    Last Post: 01-09-2003, 05:56 PM
  2. infamous window problem solved
    By sardil in forum 1992 - 1999 M3 (E36)
    Last Post: 11-25-2002, 09:41 AM
  3. Rattle problem....solved!
    By ToneCapone in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 08-29-2002, 02:04 PM
  4. Sluggish after shifting, problem solved
    By gbeale in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 05-29-2002, 09:54 PM
  5. M-contour wheels problem solved!
    By ele in forum 1992 - 1999 M3 (E36)
    Last Post: 09-11-2001, 12:38 AM
