Results 1 to 17 of 17
Thread: New Exhaust
    Dec 2013
    San Antonio
    850,76 2002 &530,84 633
    New Exhaust
    I decided to take the BMW for a complete dual 2.5" ss exhaust system. The car still had the original exhaust system except for the cats. Cans were rotting so it was time to replace exhaust now that I have the car on the road.
    I must have stopped in or contacted at least six shops around my city and I found a small place where the owner does all of the work. Shop does excellent work and they started on the car Friday and should have it finished tomorrow. I am using 18" Vibrant resonators and one-into-two 2.5" Magnaflow cans at the back. Shop is fabricating the dual downtubes, Y-adapters, X pipe, and the rest of system using mandrel bent 304 ss tubing.
    Jun 2012
    Woodstock, GA
    2001 BMW 540i6
    That’s pretty. I have an eisenman exhaust on mine and have been considering removing the resonator. I know it’ll sound good I just don’t want it to drone. Interested to know how yours sounds when it’s done.
    Sep 2010
    Augusta, GA
    92 850, 95 840, E90 M3
    Me too!
    Hurt
    Current project working on the E31 rebuild.
    1992 BMW 850i, 1995 E31 840ci, 2008 E90 M3, 2008 750Li
    Nov 2013
    Whitney, TX
    97 850CI
    Great looking work so far. You may want to tell Tim that the actual jacking points are under the rockers, and not where he is lifting the car. That floor brace is not string enough and will deform.
    Desecrator of all things Sacred
    Indianapolis, IN
    93 850Ci, 09 Caddy SRX
    Quote Originally Posted by 72tpik5 View Post
    Great looking work so far. You may want to tell Tim that the actual jacking points are under the rockers, and not where he is lifting the car. That floor brace is not strong enough and will deform.
    Good catch!
    1993 850Ci.....18 years & 165,000 miles and counting!
    Dec 2013
    San Antonio
    I was concerned about location of lift arms, but for some reason he could not get the arms adjusted to fit under the rockers.
    Jun 2012
    Woodstock, GA
    2001 BMW 540i6
    That’s the frame. Nothing wrong with lifting it there. It’s probably more sturdy there than anywhere else really.
    Dec 2013
    San Antonio
    I am suppose to pick up the car this evening. Will be curious to see if I notice any change in engine power. Some people believe this engine needs more back pressure and I dont have enough experience to know any better, but, I always had the notion that less back pressure equals more power. And, this engine was available in Europe without cats so leaded fuel could be used. I can always add in high flow cats if needed. The fella at this shop does have a chassis dyno so maybe I should put it on there one day. He also suggested running a stand-alone ECU!
    Jun 2012
    Uk
    1994 850csi rhd
    The old back pressure myth ) What you need is an exhaust system that keeps the exhaust flowing at its highest velocity without causing too much back pressure. Too large (zero back pressure) a pipe will cause exhaust gases to slow, too small and they will also be too slow. There is a calculation based on engine size you can use, BMW had it pretty much spot on. The only thing overly restrictive on the system is a section of the header where it's welded and the Cats.
    No performance benefit for an X pipe on a V12, that's purely for killing annoying sounds at certain RPMs.
    Factory ECUs can be tuned easily and are ultra reliable.
    Quote Originally Posted by JDP530 View Post
    Jun 2012
    Woodstock, GA
    2001 BMW 540i6
    Back pressure is never good for any engine.
    Jul 2002
    AZ & CO
    Too many ;-)
    I must have stopped in or contacted at least six shops around my city and I found a small place where the owner does all of the work. Tim does excellent work and he started on the car Friday and should have it finished tomorrow. I am using 18" Vibrant resonators and one-into-two 2.5" Magnaflow cans at the back. Tim is fabricating the dual downtubes, Y-adapters, X pipe, and the rest of system using mandrel bent 304 ss tubing.
    Not a lot of “muffling” in that system, so it should be pretty loud. Good bang for the buck going with a custom-built set up, too. Hope the sound is what you were looking for. Post some clips and let us know how it turns out!
    Dec 2013
    San Antonio
    Quote Originally Posted by Budget M3 View Post
    I picked up the car last night and it is a little loud at idle and up to about 1500 rpm or about 20 mph. But at higher speeds is pretty darn quiet just cruising along. I will try to capture some audio files this weekend but I still having issues with engine going into trans fail-safe mode.
    We used Magnaflow cans and 18" Vibrant resonators and a Summit 2.5" tubing kit plus some extra bends, tips, and clamps. Total cost of kit was about $900 and he charged me 12 hours labor.
    Nov 2013
    Whitney, TX
    97 850CI
    Good looking work at a decent price IMHO. I am soon to be in Whitney, and it might be worth the drive to San Antonio to see this gentleman.
    Dec 2013
    San Antonio
    Shop will probably charge another hour or two for labor because they realized quote was less than the time involved to complete the work. I offered to pay the difference but they didn't want to charge me anymore than original quote.
    Apr 2012
    Austin, tx
    1997 BMW 840, 1995 850
    Thanks for the link. He's less than an hour from me, I'll be paying him a visit.
    Dec 2013
    San Antonio
    Here's a pretty good and accurate audio clip of new exhaust while sitting in driveway. Phone did not record it well so I used a GoPro but it was sitting on a metal stool so you hear a bit of vibration from camera on stool. Exhaust note is much, much quieter on the road at 2000rpm and higher. I did not have my remote microphone here at the house but I will retrieve it from my race car this weekend and get some audio while driving around. Stool was about five feet behind car sitting about 18" off the ground.
    <span style="color: rgb(29, 33, 41); font-family: Helvetica, Arial, sans-serif; font-size: 14px; white-space: pre-wrap;">
    Jun 2012
    Woodstock, GA
    2001 BMW 540i6
    That’s a pretty exhaust but I’m convinced there’s no way to make these V12s sound good lol
  1. when did Dinan change to the new exhaust
    By T///MW in forum 1992 - 1999 M3 (E36)
    Last Post: 09-27-2001, 01:17 PM
  2. Looking for a new exhaust system
    By BP SCM3 in forum 1995 - 2001 (E38)
    Last Post: 09-05-2001, 09:37 PM
  3. Help needed to find new exhaust for 320i
    By Harry in forum General BMW and Automotive Discussion sponsored by Intercity Lines
    Last Post: 09-04-2001, 01:22 AM
  4. Just installed new exhaust on my E36 328...got a Q (m)
    By JuBu in forum General BMW and Automotive Discussion sponsored by Intercity Lines
    Last Post: 07-15-2001, 11:57 PM
  5. Need New Exhaust
    By SG_M3 in forum BMW Parts For Sale
    Last Post: 04-11-2001, 07:02 PM
