Bavarian Soundwerks
Results 1 to 4 of 4
Thread: E36 Mystery Parasitic Drain
    Jan 2015
    Upstate South Carolina
    1997 BMW M3 Sedan
    Hi Guys,
    I'm in need of some help. I have an assumed power drain on a car that I cannot track down.
    I say assumed because the car had a problem draining the battery when sitting for a week +. The battery tested ok multiple times but ultimately went bad and has been replaced. The question now seems to be if the battery was always bad or the parasitic drain killed the battery.
    I have a meter on the car and I read about a 120 mA drain when the car is asleep. That seems like too much but I cannot find any information which says what is normal.
    I have pulled every fuse I can find, under the hood and under the column without any impact to the current draw. I have unhooked the black cable from the fuse box because I read about some which saw a change when that is removed, again no change. I had the alternator unhooked completely to ensure it was not a bad diode, again nothing.
    I have suspected the parasitic drain was connected to the EWS system going bad, which happened roughly the same time as the drain was noticed. The EWS read was flashed out of the DME but I have not removed any of the hardware. However, I have disconnected fuses on the EWS circuit without effect. Generally that would debunk my theory.
    Any help, experience, advice is appreciated!
    Jul 2011
    Arlington, VA
    2018 BMW M240i
    Yes, 120ma is way too much. Typically, 40-50ma is what you should see. You’ve done your homework and done all the usual suspects. Does the drain remain constant or does it vary?
    Jan 2015
    1997 BMW M3 Sedan
    Constant as can be.
    I’m stumped.
    Jul 2011
    Arlington, VA
    2018 BMW M240i
    Has the car ever suffered water damage? Have you disconnected the starter as it’s connected directly to the battery?
  1. Replies: 9
    Last Post: 02-25-2012, 08:58 PM
  2. Dice Unit = Parasitic Drain on Battery?
    By ATLBMW1 in forum 1996 - 2003 (E39)
    Last Post: 01-11-2008, 10:23 AM
  3. mysterious battery drain
    By n thomas33 in forum 1983 - 1991 (E30)
    Last Post: 12-11-2007, 06:12 PM
  4. another parasitic drain
    By damone6969 in forum 1991 - 1999 (E36)
    Last Post: 05-29-2007, 09:52 PM
  5. Parasitic Drain on Battery?
    By seth gecko in forum 1992 - 1999 M3 (E36)
    Last Post: 03-04-2006, 09:17 PM
