Results 1 to 25 of 36
Thread: New OEM-style Front&Rear Shocks&Struts?
    Mar 2018
    Millis, MA
    2002 325xi
    2002 BMW 325xi
    Hey, guys. I'm back again, and this time I've got a new front driver side CV axle, FSR, and I changed the rear differential fluid. NOW I'm looking to replace the stupid coil-over shocks/struts the previous owner had put in this beast. I never understood the point in slamming a car to the ground unless you plan on hitting the track. Track cars need the extra aerodynamic and rigid suspension. But on the streets? Hell no. I need a much smoother ride and an actual suspension that can take the beating of an everyday driver. The roads out here in the tri-state area are absolutely shitty; especially after all the plows these past few snow storms have tore up the roads.
    I'm starting to look up shocks/struts for my lovely newly owned E46. I noticed FCPEuro's site says the Bilstein B4 shocks/strust are basically OEM, but one step up, while still remaining very affordable, which is pretty much what I'm looking for. I just want my ride to be more comfortable and more at stock height. The following link is for the strut I was referring to from FCPEuro.
    https://www.fcpeuro.com/products/bmw...ring-19-220598
    If there's better options that are just as affordable, or more-so, please let me know. I know people like to brand-whore a bit (or a lot), and I welcome it (reasonably) because I don't know car suspensions whatsoever.
    Other issues I want to solve...
    - I need the plastic push-style retaining pin for the radiator (the one on the driver side). I lost the original one Anyone know where I can find some to buy for my E46?
    - I need screws for the transmission splash guard. Both kinds. Anyone know where I can find some to buy? Alongside the little mounts for them that slide onto the metal on the car that the screws actually screw into.
    Jul 2011
    Arlington, VA
    2018 BMW M240i
    Those (b6) are great shocks.
    Aug 2014
    Lawrence Kansas
    2004 325XI/2008 GL320
    I have the bilstein b4 on my xi. Rides like a dream. Be sure and buy new bump stops.
    Mar 2018
    Millis, MA
    2002 325xi
    Quote Originally Posted by MarcoZandrini View Post
    Unfortunately, not really affordable for me. I don't doubt they would perform amazingly, but I'm not looking to spend that much on a suspension system that would never get its full potential used.
    Quote Originally Posted by dhurley34 View Post
    Thanks for the info! I will definitely be sure to do that. Do they come with mounts as well? The current shocks/struts are like a purple color, so the mounts are also that color. It'd be a little awkward (at least for me) knowing that my shock/strut mounts are purple versus the OEM black-colored mounts. And on that note, are there any other hardware I should get besides the bump stops?
    Aug 2014
    Lawrence Kansas
    No they do not come with the mounts.
    Dec 2013
    Chicagoland area
    EXOTICS
    I would purchase a kit, since you are unfamiliar with all the bits and pieces necessary.
    Just make sure you are matching F-R Kits.
    Mar 2018
    Millis, MA
    2002 325xi
    Quote Originally Posted by MIKYZZ4 View Post
    You are correct. Apart from the struts themselves, the springs (the rear struts have no springs thankfully), mounts, and bump stops; I'm not sure what else is exactly involved with the shocks/struts of this car. What is/are the kit(s) called and where would I be able to find it/them?
    May 2010
    Honolulu, Hawaii
    '73 E9, '94 E34, '02 E46
    Well, um, duhh, try searching fcpeuro's site using keywords "shock kit"
    and you'll come up with this: https://www.fcpeuro.com/BMW-parts/32...rds=shocks+kit
    similarly other online vendors will have kits as well, ya think? Not to be hard on ya, but a little basic use of the "Search" function will bring things up quicker than I can type this up.
    Charlie
    Your mission, should you decide to accept it, is to add value to these threads, either by pictures or by descriptions, so the next person with the same or similar problem stands on your shoulders.
    Dec 2013
    Chicagoland area
    EXOTICS
    Here is a shock/strut package:https://www.turnermotorsport.com/p-3...ks-struts-kit/
    At a good price, only without the bits and pieces.
    Then pull up the Bilstein front strut kit, and order the remaining parts(bits&pieces)-minus the 2 B6 struts, from Turner:
    https://www.fcpeuro.com/products/bmw...chs-e46frontxi
    Same for the rear shock kit, minus the shocks&springs, to complete the order from Turner:
    https://www.fcpeuro.com/products/bmw...plex-06164kit2
    I hope you have the original BMW springs(F&R) as the coilovers do not use them.
    Are you sure you have a coilover kit installed, and not a shock/strut lowered spring combo?
    Mar 2018
    Millis, MA
    2002 325xi
    I'm like 99% positive they are coil-overs in the front (the rear have no springs) since their springs are much slimmer looking (as in don't take up as much of a circumference as OEM style springs). Below is a quick picture I took without taking the wheel off. You see how the top of it is pink/red/purple/whatever? It bothers me lol. This makes me believe I would need to order a whole front shock assembly for both sides as opposed to just the shock absorbers and transferring hardware over. The rear is just struts and bump stops it looks like, so a much cheaper replacement than the front.
    EDIT
    I would want to get something like this for the front (a whole assembly), right? Since in my situation, I have nothing of the original shocks/struts for the car. Just these lame coil-over shocks/struts the previous owner installed.
    https://www.carid.com/2002-bmw-3-ser...Wheel%20Drive)
    Dec 2013
    Chicagoland area
    EXOTICS
    Sorry, never heard of FCS,
    I would be leery of their quality.
    Mar 2018
    Millis, MA
    2002 325xi
    I was only putting it up for example's sake, just to demonstrate what I mean by a full assembly as opposed to just the shock absorber. If you have a suggestion for a full front shock assembly, that'd be great. I didn't see any on FCPEuro or TurnerMotorSport sites.
    Dec 2013
    Chicagoland area
    EXOTICS
    Enter the last 7digits of your VIN here:http://www.realoem.com/bmw/enUS/select
    Then click on the Front Axle and Rear Axle diagrams, you'll see your stock setup with part#'s.
    This way you have a better picture of what's required.
    Mar 2018
    Millis, MA
    2002 325xi
    This is the rear shocks. I know for a fact that they don't normally have springs to them. Parts 15-18 seem to be an "alternate" way of building? I'm not sure what's going on in that diagram exactly with parts 15-18. I know for a fact that the rear shocks don't utilize springs, though.
    http://www.realoem.com/bmw/enUS/show...diagId=33_0841
    Dec 2013
    Chicagoland area
    EXOTICS
    Yes they do, the spring sits atop the upper wishbones #13(L&R) side.
    http://www.realoem.com/bmw/enUS/show...diagId=33_0840
    That is why they are included in the rear shock kit link on post#9.
    Watch video and read blog tutorial.
    https://blog.bavauto.com/14307/bmw-d...lation-how-to/
    Dec 2013
    Chicagoland area
    EXOTICS
    Quote Originally Posted by legobumb View Post
    Correct-not directly connected.
    Mar 2018
    Millis, MA
    2002 325xi
    https://www.youtube.com/watch?v=wxO3WRgamYc
    I watched this guy do his front and rear struts/shocks and when he took out the rear shock (From 4:00 to 4:20 when he takes out the rear shock), there were no springs involved. Just a straight 1 to 1 replacement, carrying over the bump stop.
    But after watching that bavauto video, I see where the spring is located now. I'll definitely give it a look-see after replacing the rear shocks unless the previous owner also replaced the springs in the rear as well. I'm not 100% sure anymore until I can get another good look at everything without the wheels on. If you use coil-overs that lower the ride height the way they do, you'd have to use different springs, right? Or can you use the stock springs on the E46 with coil-overs?
    Dec 2013
    Chicagoland area
    EXOTICS
    Yes,but listen carefully to his comments between 3:40-3:53
    Mar 2018
    Millis, MA
    2002 325xi
    The part where he talks about the noise dampener being fragile?
    Dec 2013
    Chicagoland area
    EXOTICS
    Right after he takes the wheel off. (Sorry, on the video you posted)
    Mar 2018
    Millis, MA
    2002 325xi
    Supporting the axle before taking off the bolts? I already knew that, but thanks for making sure I don't destroy my car or kill myself lol.
    Dec 2013
    Chicagoland area
    EXOTICS
    "You want to get your jack underneath your suspension to support it,
    Otherwise the coilspring is going to shoot the thing down, once you disconnect the shock"
    This is spoken between the time on the video timer as indicated at bottom of YouTube window.(3:40 - 3:53)
    Mar 2018
    Millis, MA
    2002 325xi
    Yes. That's what I just said. Thank you.
    Mar 2018
    Millis, MA
    2002 325xi
    I found a complete front strut assembly on ebay. I've never heard of BOMPA. Are they decent?
    https://www.ebay.com/itm/Pair-2-of-F...VZiWPu&vxp=mtr
    Part #'s: 171581, 171582
    I also found another complete front strut assembly from FCS on rockauto.com
    https://www.rockauto.com/en/moreinfo...419207&jsn=396
    Part #'s: 1335835L, 1335835R
    I'd save ~$60 going with the BOMPA in this scenario.
    Aug 2014
    Lawrence Kansas
    Bilstein, KYB, Sachs, Koni, or OEM only.
  1. E60,E61 Brand New OEM Style 124 Rear Wheel- 18x9, et32
    By liilpa09 in forum Wheels and Tires
    Last Post: 02-19-2012, 06:17 PM
  2. E9x Brand New OEM GRAY Front & Rear Floor Mats
    By ZeroDfx in forum Interior Lighting & Body Parts
    Last Post: 01-03-2011, 05:57 PM
  3. WTB: OEM 95 E36 M3 front and rear shocks
    By cvc9216 in forum BMW Parts Wanted
    Last Post: 09-22-2009, 12:45 PM
  4. Brand new front and rear shock mounts e36 will fit e46 also
    By Tony325cibmw in forum Suspensions, Springs & Shocks
    Last Post: 01-11-2009, 12:02 PM
  5. Replies: 1
    Last Post: 04-11-2008, 09:33 AM
