Results 1 to 6 of 6
Thread: SPEAKER SYSTEM UPGRADE HELP!!! 02 BMW 325i with standard 10 spk system
    Mar 2018
    Orange, CA
    2002 BMW 325i
    Exclamation SPEAKER SYSTEM UPGRADE HELP!!! 02 BMW 325i with standard 10 spk system
    Hi all, This is my first time posting on here. Thank you in advance for any replies!
    I own an 02 BMW 325i with standard 10 spk stereo system and I just want to replace
    the subs in the rear deck.I believe the two front tweeters, two rear door tweeters, and
    2 mid ranges should be fine. Can anyone guide me through on what speakers i should
    get , what I am going to have to do, and Do I need a new amp?
    Jan 2016
    Ca
    2001 525it
    Bav sound they make direct fit speakers
    San Jose, CA
    00 750IL, 01 740IL
    Problem with e46 sound system isn't the speaker, but the weak oe amp, unless the speakers are damage, try amping it with an aftermarket amp, active. You'll be surpised how much better stock speakers sound.
    Sent from my VS995 using Tapatalk
    Mar 2018
    Orange, CA
    2002 BMW 325i
    Thank you @asianvenom and @jclausen
    my rear deck subs have a tear around the
    whole thing so I’m assuming it’s that one
    but overall I’m looking for a good replacement
    and a new amp.
    Jul 2011
    Arlington, VA
    2018 BMW M240i
    Be advised that the factory amp contains the crossovers. So, if you install an aftermarket amp you’ll have to install crossovers. Btw, crossovers split the audio signal into frequency bands so that each speaker gets the audio frequencies it’s designed to handle. Also, the factory head unit output signals are “balanced differential” and not the typical RCA line level signals. So the aftermarket amp has to be able to handle those signals. I installed a JL 400/4 amp. Most JL amps will handle balanced differential signals.
    San Jose, CA
    00 750IL, 01 740IL
    I said "active", use a 4 channel amp, power your front mid woofers, and tweeters (or your stock subs). Leave the stock amp to power the rest of the stock speakers. You will notice an improvent.
  1. need opinions and help, 2006 bmw 325i with high miles
    By tbensley in forum 2006 - 2012 (E90, E91, E92, E93)
    Last Post: 06-20-2011, 09:35 PM
  2. need opinions and help, 2006 bmw 325i with high miles
    By tbensley in forum General BMW and Automotive Discussion sponsored by Intercity Lines
    Last Post: 06-20-2011, 12:53 PM
  3. e36 rare~~Blue BMW 325is with many M3 upgrades
    By miroxz in forum BMW Cars For Sale / Wanted
    Last Post: 02-11-2007, 09:54 PM
  4. 99 ///M3 system upgrade.... Help with AMP!!
    By DDEM3 in forum Car Audio & Electronics sponsored by Bavsound
    Last Post: 03-22-2004, 10:03 AM
  5. Purchasing BMW 325is with high miles, please help!
    By Quiksilver7 in forum 1991 - 1999 (E36)
    Last Post: 01-08-2004, 02:32 PM
