Results 1 to 5 of 5
Thread: Humming noise
    Mar 2018
    Laval, Quebec Canada
    2000 Z3 roadster 2.8 L
    Humming noise
    My 2000 2.8 L Z3 with automatic transmission has developed a high pitch humming noise when running at a steady constant speed (any speed). Noise disappears upon acceleration and deceleration.
    Can anyone help.
    Feb 2016
    tempe, az
    1998 Z3M, 2006 330i
    Differential??? In buying older cars, I usually just change the diff fluid to Redline or Royal Purple. It quiets them down, and it's good preventative maintenance.
    Kent, Ohio
    1998 M Roadster
    Does the noise change when turning or lane changing? Is the noise present at idle? Does the noise change depending on what speed you are going? Does it change depending on what RPM your are at?
    Jul 2004
    Houston, TX
    36 Cylinders
    Is the car new to you?
    The old GM transmission fitted to the 99-2000 automatics loves to resonate in the cabin and creates a whirring sound especially when not accelerating or decelerating; because of the way it was mounted. BMW had released documents a long time ago addressing this noise, and some alternate transmission mounts were used.
    It could be that.. or something else.
    -Abel
    - 2000 Z3: Many Mods.
    - 1999 S52 Estoril M Coupe
    - 2016 Mini Cooper S
    Denver, Colorado
    MRster / Z4 M4i / X5 M50
    Some after market cold air intakes can whistle.
    2002 M Roadster, Steel Gray Metailic, Gray Nappa Leather, Black Soft Top, Steel Gray Metailic Hard Top, TC Kline Double Adj Shocks with H&R Springs, Stromung Exhaust, SSR Type C Wheels. Looking for a new home.
    2022 Z4 M40i, Misano Blue Metallic, Prem Pkg, Driver Assistance Pkg
    2023 X5 M50, Phytonic Blue, Black Extended Merion Leather, Driving Asst Pro Pkg, Park Asst Pkg, Exec Pkg, Climate Comfort Pkg.
  1. Humming noise
    By richter in forum 1991 - 1999 (E36)
    Last Post: 11-07-2005, 02:31 PM
  2. Anyone encountered a humming noise from there diff?
    By Raff in forum 1983 - 1991 (E30)
    Last Post: 07-22-2005, 02:13 AM
  3. 2001 325i Rear End Humming Noise
    By isetta in forum 1999 - 2006 (E46)
    Last Post: 06-28-2005, 10:31 AM
  4. Humming Noise from Behind, Help.
    By nvsage in forum 1991 - 1999 (E36)
    Last Post: 03-12-2005, 01:06 AM
  5. Humming noise in 1st gear???
    By DominikM3 in forum 1992 - 1999 M3 (E36)
    Last Post: 08-21-2004, 02:48 PM
