Results 1 to 8 of 8
Thread: Will I damage my E46 if.....
    Mar 2005
    usa
    BMW 325 Ci sport package
    I drive it without the Mass Airflow Sensor “plugged in?”
    It runs like new when I unplug it.
    Error codes indicate a bad sensor but changing it made no difference; sputters and chugs along when plugged in. A friend will help me look for other problems in a few weeks. The car is 17 years old and is kept for sentimental reasons. A dealer fix will probably cost a ton. Not a daily driver so increased fuel consumption is not an issue, just concerned about additional damage.
    Thank you,
    Jim
    Mar 2016
    Portland, OR
    2002 325Ci Cabriolet
    No, it won't damage the car. I've seen posts where owners had it unplugged for more than a year.
    dworthy's Avatar
    Nov 2010
    Grafenwoehr, Germany
    16 220i 05 325it 05 M3
    It will only make the car run rich, thus plugging up your cat.
    So do yourself a favor, get the intake smoke tested, or do a visual test of that big black rubber boot after the MAF. I bet there is a rip/tear in that thing.
    Darin
    Current:
    Past:
    79 525 euro Green/Green RIP
    M-Flight Member
    Jan 2016
    Ca
    2001 525it
    That's because the airmass sensor is not the problem, need to do a complete dx on lt
    Aug 2014
    Lawrence Kansas
    2004 325XI/2008 GL320
    Mine wont even run with it unplugged.
    Mar 2016
    Portland, OR
    It will only make the car run rich...
    Not so fast. With the MAF unplugged, the DME will go into a default mode. Not necessarily rich or lean, just a default mode. But yes, do fix the problem that is causing the car to run poorly with the MAF plugged in.
    dworthy's Avatar
    Nov 2010
    Quote Originally Posted by All2kool View Post
    And yes, Default is rich.
    Darin
    Current:
    Past:
    M-Flight Member
    Dec 2013
    Chicagoland area
    EXOTICS
    +1
    It will only make the car run rich, thus plugging up your cat.So do yourself a favor, get the intake smoke tested, or do a visual test of that big black rubber boot after the MAF. I bet there is a rip/tear in that thing.
    Yes,it will cause damage-to your cat converter!
    An intake leak is the most likely, caused by a crack in the rubber intake boot, or the associated hoses.
    Yes, rich is the default setting.
  1. e90 wheels - will they fit my e46?
    By alpinex in forum Tire & Wheel Forum sponsored by The Tire Rack
    Last Post: 10-09-2007, 01:57 PM
  2. Will this damage my car's paint?
    By propr`one in forum Car Detailing and Show & Shine Prep sponsored by Autogeek.net
    Last Post: 05-04-2006, 11:08 AM
  3. Will it hurt my engine if.....
    By turb02 in forum 1992 - 1999 M3 (E36)
    Last Post: 05-04-2005, 03:48 PM
  4. Replies: 4
    Last Post: 10-18-2004, 11:58 PM
  5. 18" wheels, will they fit my car if....
    By Bond, James Bond in forum Tire & Wheel Forum sponsored by The Tire Rack
    Last Post: 06-11-2002, 10:08 PM
