Does anyone know if a pre-face lift drivers side front brake hardline will fit on a post face model?
#12 and #4's ?
http://www.realoem.com/bmw/enUS/show...diagId=34_0091
realoem.com shows them to be the same part numbers.
Tbd
34321115133
BRAKE PIPE LEFT
From:06/01/1976To:05/25/1983 (ENDED)Weight:0.038 kgPrice:Part 34321115133 was found on the following vehicles:
Yes the date range shows '76 thru '83. And the fitting itself has the common threads 10mm diameter and 1mm thread pitch.
Update, they fit!
thanks to John for bringing me lines since mine failed
