Results 1 to 3 of 3
Thread: RealOEM accuracy regarding transmission?
    Oct 2007
    Boca Raton, Florida
    89'750iL,98'740iL,00'M5
    Ive got a seller on craigslist thats parted out a beautiful purple on purple E38 with 95,000 miles. I need the transmission and been on the hunt for a while.
    His is a 03/98 740i. I put in his VIN into Realoem and found that the only option for a transmission is the 24001423193 5HP24. My 09/97 built 740iL has 24001423193 as well as 24001423305 which is the tranny for the shorter rear diff which my car does not have. Question is, should his transmission be a perfect match for mine or do I still need to get the exact model number off of both transmissions to match? My worry is a change in TCU connector on the transmission end...
    BMW 7er Website www.7er.com
    1989 BMW 735i Schwarz (sadly, sold) // 1989 BMW 750iL Cirrusblau Metallic // 1998 BMW 740iL Oxfordgrün Metallic // 2000 M5 Carbon Schwarz ///
    IL
    2000 740i sport
    Quote Originally Posted by SergeBMW View Post
    I think as long as its pre facelift to prefacelift you should be good... My 02 98 has one installed from a 97 IIRC and all was good. I replaced fluid, filter and gasket and trans mounts at the same time...
    Sent from my SM-N910T3 using Tapatalk
    Oct 2007
    Boca Raton, Florida
    Yea ill be doing the same as well. Honestly with these transmissions, I would really like to do a rebuild but thats just too much money on my E38 which really isnt in the greatest shape. Not going to lie, im a bit afraid of opening the oil pan on the donor transmission and finding parts of the drum. It is a low mileage car though so it should be fine.
    Thank you for the input.
  1. Question regarding Transmission issues
    By magnumty in forum 1988 - 1996 (E34)
    Last Post: 07-27-2012, 11:58 PM
  2. differences between 325e and 325es regarding transmission
    By lortech in forum 1983 - 1991 (E30)
    Last Post: 05-20-2011, 09:08 PM
  3. transmission compatability question and realoem
    By uk525td in forum 1988 - 1996 (E34)
    Last Post: 02-23-2010, 04:00 AM
  4. Another newbie question regarding transmission removal.
    By Einundzwanzig in forum 1975 - 1983 (E21)
    Last Post: 03-20-2008, 11:17 PM
  5. Regarding Electronic manual/automatic Transmission
    By justomega in forum 1982 - 1988 (E28)
    Last Post: 11-05-2006, 03:04 PM
