New here need help. Don't no where to post I have a bmw 2002 x5 e53 3.0d auto keep getting the trans fail safe
I have replaced the steering angle sensor as the fault wouldn't delete now it's won't changeout of 1st gear
Welcome to the forum.
Steering angle sensor codes do not typically store in the EGS (transmission computer). What codes do you have in the DME, the EGS, the transfer case, and the ABS?
Steering angle sensor codes are most often cleared by turning the steering wheel full left and then full right, unless the front end is out of alignment.
Chris Powell
BMWCCA 274412
[QUOTE=bmwdirtracer;29982244]Welcome to the forum.
The steering angle sensor was broke I took it apart and the little metal bits where broken and replace the yaw rate sensor
Baureihe : E53
Control unit : Dynamic stability control 4 wheel system
ECU : D_ABSKWP
JobStatus : IFH-0009: NO RESPONSE FROM CONTROLUNIT
Control unit : Transfer gear box Control unit
ECU : D_VGSG
ECU : D_0056
JobStatus : OKAY
BMW part number : 6756216
Hardware number : 51
Software number : 3
Supplier : Bosch
Supplier-No : 8
Coding index : 15
Diagnostic index : 17
Bus index : 42
Date of manufacture Week/Year : 26/1
Control unit : Gear box ecu GS19
ECU : D_EGS
Control unit : Motor
ECU : D_0012
JobStatus : OKAY
BMW part number : 7789376
Hardware number : 53
Software number : C0
Supplier : _?_
Supplier-No : -13825
Coding index : 01
Diagnostic index : 16
Bus index : 60
Date of manufacture Week/Year : 38/01
Control unit : Steering angle sensor
ECU : D_0057
JobStatus : OKAY
BMW part number : 6750126
Hardware number : 4
Software number : 3
Supplier : Kostal
Supplier-No : 2
Coding index : 1
Diagnostic index : 20
Bus index : 60
Date of manufacture Week/Year : 4/2
Control unit : Air suspension
ECU : D_00AC
JobStatus : OKAY
BMW part number : 1092396
Hardware number : 0
Software number : 65
Supplier : Kostal
Supplier-No : 2
Coding index : 6
us index : 6
Date of manufacture Week/Year : 7/2
Control unit : Tyre pressure control
ECU : D_0070
Control unit : Light check modul
ECU : D_00D0
JobStatus : OKAY
BMW part number : 6914648
Hardware number : 0
Software number : 43
Supplier : UTA
Supplier-No : 6
Coding index : 19
Diagnostic index : 13
Bus index : 0
Date of manufacture Week/Year : 11/2
Control unit : Active Light Control E46
ECU : D_0066
Control unit : Headlight vertical aim control
ECU : D_009A
JobStatus : OKAY
BMW part number : 8375964
Hardware number : 131
Software number : 5
Supplier : Helbako
Supplier-No : 7
Coding index : 3
Bus index : 5
Date of manufacture Week/Year : 8/2
Control unit : Rain- light sensor
ECU : D_00E8
JobStatus : OKAY
BMW part number : 6923954
Hardware number : 40
Software number : 32
Supplier : Kostal
Supplier-No : 2
Coding index : 2
Diagnostic index : 10
Bus index : 0
Control unit : Multidrive Sunroof
ECU : D_0008
Control unit : Electronic vehicle immobilization III
ECU : D_0044
JobStatus : OKAY
BMW part number : 6905667
Hardware number : 3
Software number : 8
Supplier : UTA
Supplier-No : 6
Coding index : 81
Diagnostic index : 81
Bus index : 7
Date of manufacture Week/Year : 10/2
Control unit : Central information system
