Page 2 of 2 FirstFirst 12
Results 26 to 33 of 33
Thread: (M60 Folks) Leaking HG??
  1. #26
    Jun 2017
    Denver, CO
    325xi; 740i
    I wish it were done... I got it all back together again yesterday, excited to have my car back again to find again today that it's still leaking in the same damn place. I don't have my high powered flash light to look at the valley pan again but when I looked at it yesterday after driving there was steam but no water to be seen.
  2. #27
    Jun 2017
    Denver, CO
    325xi; 740i
    Well, sad day. I have a dead M60 now, I checked the oil again after trying to fix the coolant leak for the fourth time and the level went up significantly and there's clearly a mix on it. The bearings are still a-okay so I will be putting her into long-term storage while I move then bring her down with me and at least replace the head gaskets but ill likely do an entire engine build.
    New Daily:
    2011 Audi A6 Avant 3.0T prestige. 1 of 368
    ----FOR SALE-----
    04 BMW 325xi 143k
    The Fun car:
    94' BMW 740i 308k miles
    Fresh 72k mile engine with all new seals. True E34 Manual Trans Engine Harness. 6spd Transmission Swap, Getrag 420G. RHD LW Single Mass Flywheel. E39 M5 Clutch. E39 M5 Shifter. Factory Car Phone. Factory 6CD Changer. Factory Electric Sunshade. Not So Factory Factory Electric/Heated Rear Seats. E38 Heater Valves. E43 M5 calipers/brakes
    Sold:
    1996 Oldsmobile Aurora; 194k miles but with a bad paint job and dented fender resulting in a payout to buy the 740i
  3. #28
    Sep 2013
    Oceanside
    95 540i/6
    I wouldn't be surprised if the heads got a little tweaked after that bounce off the red zone. Mine did that twice and I had to take 10 thousandths off them to get them flat again. Aluminum ain't cast iron.
  4. #29
    Jun 2017
    Denver, CO
    325xi; 740i
    Possibly but it never ran hot and never had a problem with it before. Not burning coolant either, no pressure in the cooling system while cold. I now have an E46 DD too.
    New Daily:
    ----FOR SALE-----
    04 BMW 325xi 143k
    The Fun car:
    Sold:
  5. #30
    Sep 2013
    Oceanside
    95 540i/6
    For sure. I thought you said it did go to red though. I never really noticed a coolant level loss on my car, but the car would run normal, then all of a sudden start to skyrocket up. Bleeding it was a pain in the ass and eventually the car got bad enough that the coolant would never stabilize in the expansion tank. Oddly enough, it never turned the head gasket leak fluid the yellow that indicates an exhaust leak into the coolant chamber.
    But as soon as I flattened the heads, installed new gaskets and topped it up, it became perfectly well behaved.
  6. #31
    Jun 2017
    Denver, CO
    325xi; 740i
    Finally got around to the final analysis of the engine to finally close the case. Decided to take the valve cover off my old engine tonight and found the head gasket was in fact leaking, water is evident in the oil even up in the head. I inspected the tops of all the head bolts and found one of the heads of the head bolts snapped off causing a separation of the head and block under operating temps.
    New Daily:
    ----FOR SALE-----
    04 BMW 325xi 143k
    The Fun car:
    Sold:
  7. #32
    moroza's Avatar
    moroza is offline MORΩN ΛABIA BMW CCA Member
    BFE
    E34T
    Fascinating. How many miles, and any indication that the head bolts were touched since it left the factory? Do you have a recall Alusil block?
  8. #33
    Jun 2017
    Denver, CO
    325xi; 740i
    Quote Originally Posted by moroza View Post
    That is the original 308k mile nikasil block. From what I can tell they look factory, no tool marks to be seen on them. This engine was very well cared for as evident by the lack of "staining" on the walls inside the head and what is present is easily wiped off with a paper towel.
    Perhaps I'll upload pictures tomorrow when I get them off my phone.
  1. sigh M60 oil leak
    By Nguyen in forum 1988 - 1996 (E34)
    Last Post: 03-19-2019, 11:55 AM
  2. 2004 545i M60 Oil leak - What else should I replace?
    By jjvallee in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 04-17-2011, 09:33 AM
  3. low coolant, can't find leak = HG ?
    By Tlow98 in forum 1992 - 1999 M3 (E36)
    Last Post: 12-28-2008, 10:25 PM
  4. M60 oil leak maybe camcover gaskets??
    By Francis740 in forum 1988 - 1994 (E32)
    Last Post: 05-29-2008, 07:04 AM
  5. Coolant Leak HG Off.
    By M3Scharged in forum 1992 - 1999 M3 (E36)
    Last Post: 12-26-2007, 12:56 AM
