Hi all,
I'd be grateful if anyone could share any knowledge of what the difference might be between the two codes please ..
The story so far - Get an ABS / DSC yellow warning triangle when driving, so pull codes and see 5F00 (Wheel-speed sensor, plausibility, rear right) and 5F70 (Engine management: interface) so checked wiring and applied WD40 as per the instructions that others have kindly provided on the forum. Cleared the codes and took it out to test following the work and get another ABS/DSC warning triangle, so pull the codes again and now get 5E4A (Wheel-speed sensor, plausibility, rear right) on its own.
It seems the WD40 and unplugging + replugging changed something, but what ??
Is it worth shelling out for a new sensor on the offchance ?
MOT is coming up soon so ...
Thanks in advance
Mud
