Results 1 to 3 of 3
Thread: Need help with my fan
    Mar 2018
    Indiana
    2005 bmw 525i
    I have a 2005 BMW 520i , my fan is constantly running on high , soon as I start the engine the fan kicks on I changed oil temperature sensor coolant temperature sensor and AUC sensor nothing has worked people are telling me that I need to program the car and it made sense because there’s a message on my screen that says “head unit not “programmed correctly”
    Please help
    Jul 2011
    Arlington, VA
    2018 BMW M240i
    Why the document at the link is for the E46 it should give you info as to what’s wrong with your fan.
    https://drive.google.com/file/d/0B59...VlE/view?pli=1
    Charleston, SC
    '15 I01Rex , '11F25
    Are you taking about the aux fan for engine or the blower motor for the cabin. If its the aux fan in front of the motor, and the motor is the n51/52 then its most likely caused by a failing coolant pump. Some-one who has access to a good diagnostic scanner will be able to read the faults, usually: speed deviation coolant pump, blockage in cooling system or jammed coolant pump. Head unit not programmed correctly will have nothing to do with the cat overheating.
  1. Guys need help with my HVAC fan switch
    By Serge P in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 03-31-2012, 02:38 PM
  2. Need help with my computer ASAP
    By Perks in forum Off-Topic
    Last Post: 02-18-2003, 08:10 PM
  3. I Need help with my custom setup
    By DjLiTtLeGiRL in forum Car Audio & Electronics sponsored by Bavsound
    Last Post: 12-26-2002, 10:07 PM
  4. Need help with my steering wheel mod
    By gato in forum General BMW and Automotive Discussion sponsored by Intercity Lines
    Last Post: 09-07-2002, 03:48 PM
  5. I "NEED" HELP WITH MY 1984 733i
    By dgsm24 in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 04-14-2002, 05:33 PM
