Studio RSR is proud to release our
Tesseract(F82) BMW M4 roll cageDesign and Engineering
StudioRSR has developed an outstanding rollcage / rollbar (half-cage) for the M4 (F82 chassis) to fulfill motorsport, HPDE, and track-day needs. Increased chassis rigidity and safety combined with a modern design befit of the BMW M4, makes the StudioRSR Tesseract roll cage the premium option available in the market.Attachment 625231
Attachment 625232
Attachment 625233
Designed and manufactured in-house, StudioRSR uses the latest manufacturing technologies to create this upgrade with **NASA Racing specifications**and wide-radius bends. There is zero metal crimping and zero tubing wall failure that is often seen from alternative roll cages. The Tesseract half-cage is100% bolt-infeaturing a 4-point optimum mounting design with form-fitted brackets specific to the F82 chassis. Professional installation is recommended, but installation is made easy with chromoly interlocking tubing clamps, zero welding, and all necessary hardware included. Additionally, street-spec classed vehicles can retain their rear seats if preferred. Available in-house at StudioRSR or shipped direct to you or your preferred Dealer/Installer internationally. The Tesseract half-cage consists of 2 main pieces making installation and shipping even easier.
Key Features
Please PM, email, or call for Special Forum Pricing- 100% bolt-in
- Rear seat Compatible - Fits with rear seats installed (*note: rear side bolsters require slight modification to fit)
- NASA Racing spec w/straight leg version (**as of 2016.5 rulebook, not sanctioned)
- Street/HPDE spec w/Tesseract bent leg version
- 4-point half-cage
- 6 steel brackets form-fitted to the F82 chassis
- Made with latest manufacturing technologies
- Wide-Radius bends = even stress distribution, no metal crimping, & no tubing wall failure
- Designed with optimum bolt locations to factory mounting points
- Signature designed Studio RSR Tesseract angled rear legs
- Proprietary designed integrated chromoly tubing clamps
- Heavy-duty DOM steel 1.75" x .120 wall thickness all-around
- All Grade-8 mounting hardware included
- Installation instruction included
- This product is intended for Off-Road use only
- Product photos may vary from actual item
- StudioRSR Terms & Conditions apply (see link below to Terms & Conditions)
- 100% Made in USA
- Powdercoated in Red, White, Yellow, or Black at no additional cost
info@studiorsr.com
