Results 1 to 9 of 9
Thread: Front-end Fiasco
    Houston, Tx
    '78 320i
    Front-end Fiasco
    I found a euro vendor on ebay and I was able to acquire pretty much all the rubber I'll need for the front-end. I also picked up some eurometric steering rack bushings.
    2 questions...
    Where are yall finding the rubber ringed washers- 31351115805
    I found 2 on ebay but Im thinking of trying to DIY some... I just dont know if I'd get good sustainable adhesion from a 3m type polyurethane
    Second, on the steering rack bushings, is there typically anything else that needs to be replaced? I found these bushings - 32111118474 as part of the steering damper but Im not sure I need to go that far.
    Jun 2016
    Austin, TX
    1978 323i
    Don't forget new "securing plate"s 32111116553 and
    parts #1 and #18
    http://www.realoem.com/bmw/enUS/show...01#32111118474
    Houston, Tx
    '78 320i
    Thank you, that wasnt on my radar. I found tie rod ends for cheap on rock auto. to be honest I dont think mine are busted but I will see.
    Front end does need a sharp refresh. Im hoping new rubber in bushings and those rubber washers do the trick.
    Nov 2007
    Sacramento, California
    1980 BMW 320i E21 M10B18
    Cool
    What condition are the control arms ball joints ?
    Randy
    Houston, Tx
    '78 320i
    Unverified but they pass visual inspection. I went cheap(er) and bought the inner/outer rubber mounting/bushing. I didnt wanna buy whole new arms, especially since I have the early and you cant find them easily. Rockauto and other reputable parts vendors SAY they have the control arms but they are for the LATE models.
    Pioneer, CA
    73' tii 79 320i 73'2002
    Bavarian Autosport used to sell an "anti shimmy" kit which mostly consisted of the sway bar to control arm washers with extra thick rubber. I just searched their website and couldn't find anything. I think a spacer of urethane would work just fine.
    Unfortunately early model control arms are hard to come by. bavauto only has the left side. Which is part of why I swapped to an early front subframe in my 79.
    Houston, Tx
    '78 320i
    Quote Originally Posted by tlapham View Post
    I had an 81 sport parts car. This was way back when I didnt know much of the E21. Had I known I would have gotten the rear subframe to support the updated control arm, the larger sport sway bars, etc.
    Oh well... It will always be a slight regret.
    Sep 2015
    Massachusetts
    E21 327i, E46 325iT/5
    Someone on here was going to re-make them. Keep searching for Bavauto shimmy kit or similar.
    Houston, Tx
    '78 320i
    Do we have any polyurethane makers? Maybe Jester would be interested in making a batch. The part seems to be NLA. Unfortunately I only have 2 wahsers. I wonder if I can mate this up with a poly washer or not.
  1. Front End Alignment
    By 97m3/4 cosmos-mulbry in forum 1992 - 1999 M3 (E36)
    Last Post: 02-08-2005, 02:37 AM
  2. Front End Cover - Feedback
    By hotbimmer in forum General BMW and Automotive Discussion sponsored by Intercity Lines
    Last Post: 09-16-2001, 11:52 PM
  3. I'm tempted to 'Pam' my front end.
    By John (PA) in forum General BMW and Automotive Discussion sponsored by Intercity Lines
    Last Post: 09-07-2001, 10:38 PM
  4. High Speed Front End Vibration
    By M3inSC in forum 1992 - 1999 M3 (E36)
    Last Post: 07-16-2001, 04:40 PM
  5. Front End Alignment?
    By Tritium in forum General BMW and Automotive Discussion sponsored by Intercity Lines
    Last Post: 06-03-2001, 12:04 PM
