Results 1 to 25 of 50
Thread: Timing Chain Guides
    Jan 2006
    Ashville, AL
    1999 540i/6
    Timing Chain Guides
    I am replacing timing chain guides on my 1999 540i. Two questions:
    1. Is the crank bolt right hand threaded?
    2. How do I know if the secondary chain tensioners should be replaced?
    Thanks for help.
    Andy
    JimLev's Avatar
    Sundance Mesa, NM
    00 540/6, '16 Highlander
    Quote Originally Posted by andy81563 View Post
    Thanks for help.
    Andy
    1) Yes, right hand thread
    2) The ones between the cams, might as well, they aren't expensive.
    Jan 2006
    Ashville, AL
    1999 540i/6
    Thank you, JimLev. I will be trying to get this project done over the next couple of weeks so I may have other questions/concerns.
    Apr 2017
    New York
    2001 540i 6MT
    JimLev's Avatar
    Sundance Mesa, NM
    And if you don't like reading lots of pages here is a video on how to time the 540tu engine.
    https://www.bimmerforums.com/forum/s...a-540tu-engine
    Sep 2013
    Tx.
    02 bmw 540
    Here’s a great thread with details of nuances you may encounter while performing the job.
    https://www.bimmerforums.com/forum/s...es-input/page2
    Jan 2006
    Ashville, AL
    1999 540i/6
    When removing the crank bolt, is the flywheel pin sufficient to keep the crank from turning or must you use a crank-holding tool on the front of the engine?
    San Jose, CA
    1997 BMW 540i 6 speed
    The Bentley manual shows the use of the BMW tool that engages the crank hub. The bolt is torqued circa 400 ft-lbs.
    Our Ole Buddy JimLev uses a 3/4 in drive socket and wrench.
    I don't believe the flywheel pin will withstand the force.
    Sep 2013
    Tx.
    02 bmw 540
    Proper procedure calls for the crank holder tool.
    But some have gotten away with just the crank holder. My GAS steel crank holder did not withstand the force, It bent!!
    I should have the crank holder tool tomorrow.
    Also if you have an impact, it should come right off.
    Your mileage may vary. All my bolts were very snug!! Or I haven’t worked on an engine in a long time.
    Jan 2006
    Ashville, AL
    1999 540i/6
    I have fabricated a steel plate that extends from crank hub over to mounting hole for belt tensioner. I presume that boss will hold. Thoughts?
    Jan 2006
    Ashville, AL
    1999 540i/6
    That plate worked great plus it helps to have a 1" drive socket.
    Sep 2013
    Tx.
    02 bmw 540
    Crank holder in place, my makeshift cheater bar with a 1/2 breaker bar.
    Jan 2006
    Ashville, AL
    1999 540i/6
    Trying to remove the camshaft drive sprocket bolts now. They are extremely hard to loosen. (Yes, I know they are left-handed threads). And, am having a hard time holding the cam so I can get some heft behind the wrench.
    Sep 2013
    Tx.
    02 bmw 540
    By sure to counter hold with a 27mm wrench. I sprayed some PB Blaster on the cam bolts for good measure. If you got the crank bolt off, you’ll get the cam bolts off.
    Jan 2006
    Ashville, AL
    1999 540i/6
    It looks like I may be in a mess with the oil pump. Since the drive chain was rather stretched, I decided to change it. When I went to remove the sprocket I have discovered that the mounting nut is stripped and it won't even come off. I know the threads on this bolt are left-hand. When I broke the nut free, it now just spins in one place. I guess I will have to replace the oil pump.
    Sep 2013
    Tx.
    02 bmw 540
    Hi Andy,
    Here is a video that will help with that procedure.
    https://youtu.be/ZQurYvYbrJM
    Sep 2013
    Tx.
    02 bmw 540
    https://youtu.be/t0mbjBX4RlU
    I’ll leave this here as well. How to adjust and clean your oil pump.
    Good luck,
    Cheers!!
    Nov 2011
    Greedland
    99 540i6, 02 X5, Tundra
    I'm 99% sure oil pump is standard thread
    E85 fueled, Eaton m112 supercharged 4.5L M62TU, TTV racing flywheel, Spec stage 2+ clutch, 88c thermostat, eibach sway bars, wavetrac 3.15 lsd, m5 steering box, Quantum 340lph fuel pump, Dinan camber plates, some powerflex bushings, Supersprint headers, M5 cats, 2001 gas pedal upgrade and many other things done. all diy by me
    Sep 2013
    Tx.
    02 bmw 540
    Quote Originally Posted by 1999 540i m View Post
    Yes the oil pump is standard thread. Turn counter clockwise to losen.
    Nov 2011
    Greedland
    Quote Originally Posted by Mannyf540 View Post
    That explains the guys stripped oil pump, that had to be hard to do!
    Jan 2006
    Ashville, AL
    1999 540i/6
    I have gotten the nut off the pump that holds the sprocket. Nut threads were stripped, not the threads on the pump shaft, so all I will need is a new nut. Note: these threads are LEFT HANDED, clockwise to loosen.
    Sep 2013
    Tx.
    02 bmw 540
    https://bmwtis.info/removing-and-ins...ngine-bmw-m62/
    The nut should be turned counterclockwise to losen. That is why your nut stripped.
    Jan 2006
    Ashville, AL
    1999 540i/6
    See attached. Threads are left-handed.
    Oil Pump e39.pdf
    I see the TIS shows different from the Bentley manual. Hmmm.
    Sep 2013
    Tx.
    02 bmw 540
    Fellow E39ers, which way does the nut turn.
    This is nuts!!
    Nov 2011
    Greedland
    I just dug out my spare oil pump, it is standard right hand thread, the bentley manual is wrong
  1. M30 timing chain guide rail
    By Racerhoze in forum 1988 - 1996 (E34)
    Last Post: 06-03-2009, 04:54 AM
  2. Replies: 0
    Last Post: 04-14-2008, 02:09 PM
  3. OH CRAP! Broken timing chain guide
    By KyleAwesome in forum 1991 - 1999 (E36)
    Last Post: 02-24-2008, 11:56 PM
  4. Help! Trying to remove timing chain guide rail on M30
    By bmwpower in forum 1988 - 1996 (E34)
    Last Post: 11-14-2007, 01:30 PM
  5. M50 Timing Chain Guide/Tensioner help
    By steelpig in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 06-06-2007, 10:18 AM
