Results 1 to 2 of 2
Thread: Help with expansion tank to water pump hose E30 87 325is
    Mar 2018
    columbia,sc
    87 325is
    Hi everyone,
    Last weekend I did a timing belt on my E30. After getting a new water pump and a new OEM hose that goes from the pump to the expansion tank installed, it was leaking at the pump. Anyone know if any tricks or have any advise on how to get the hose to seal good? Its a steady drip off the hose right were it connects to the pump, and the clamp appears to be tight.
    dworthy's Avatar
    Nov 2010
    Grafenwoehr, Germany
    16 220i 05 325it 05 M3
    Welcome to the Forum!
    Well make sure you have the hose and clamp positioned properly. The waterpump should have ribs on the outlet pipe, and normally I like use a little bit of coolant on the hose to allow it to seat all the down. Typically there should be about a full inch that goes into the hose, and I like to place the hose clamp about half an inch from the end.
    Now to ensure the hose is tight, try to twist it a little. Will it move? Also are both parts OE or OEM? Same manufacturer? I have seen some aftermarket parts say they are OE/OEM quality and not be the truth.
    Darin
    Current:
    Past:
    79 525 euro Green/Green RIP
    M-Flight Member
  1. e36 328i -- expansion tank to block return hose too long?
    By sid the sloth in forum 1991 - 1999 (E36)
    Last Post: 05-22-2016, 10:35 AM
  2. Help! Coolant leak from expansion tank to water pump
    By Jared9392 in forum 1996 - 2003 (E39)
    Last Post: 05-13-2012, 08:15 PM
  3. Need help with a purchase and water pump...
    By justinp95 in forum 1991 - 1999 (E36)
    Last Post: 09-03-2008, 01:05 PM
  4. Thermostat to water pump hose ID
    By shadyduk1979 in forum 1975 - 1983 (E21)
    Last Post: 03-15-2007, 01:29 PM
  5. help with removal of the water pump pulley.... dont laugh
    By turbotec in forum 1991 - 1999 (E36)
    Last Post: 10-23-2004, 02:24 AM
