Hey guys I need some help before I tackle the 5 speed swap this weekend. So I bought a used ZF transmission and I have some play in the damn shifter. I have replaced every bushing and I even replaced the selector rod to a DSSR in the hopes of eliminating the play. Any help is appreciated. Thanks!
heres a video
https://youtu.be/qHxLAHlbI5E
If you want a really tight and notchy feel you will probably need an aftermarket SSK. I have a z3 shifter with all new bushings and solid trans mounts and it still has a bit a play.
1998 318i m52 swap 3.38 lsd, 1995 540i/6 speed (SOLD), 1993 325i, 1999 328is m-sport, 1996 328i GT35
The answer to your shifting problems
I agree, OP's setup looks like the "right" amount of play for a rebuilt stock shifter on a used transmission. Before I rebuild my M3's shifter, 5th sat in the same position as 3rd and I was pretty paranoid about accidental money shifts. A little bit of play is worth it for smoother shifts IMO.
You need to replace the shift detent bushing in the transmission. This is the reason people "money shift" from 5th to second and blow their engine.
